Old 08-21-2005, 08:00 PM   #1021
Red RSX's Avatar
Originally Posted by Rod M
what is the difference between the TZ and RZ Tamiya ?
most significant..
TZ = stand up brush
RZ = Laydown brush
Red RSX is offline   Reply With Quote
Old 08-21-2005, 08:16 PM   #1022
ttso's Avatar
Originally Posted by ttso
Just got a new motor, Orion SV2 23x2T 25000rpm. Was this high rpm or high torque? start with 5.5 or something else?
I tried it this weekend, best gear ration is about 5.3. However the motor doesn't have any topend rpm, the losend/mid torque is good but topend..... is there topend at all? I guess the problem is because the timing, "competition" stock motor usually come with about 20' timing preinstalled, SV2 is 0' timing. However, race rule prohibit timing adjustment, so.. this motor is no good for me to join race.
ttso is offline   Reply With Quote
Old 08-22-2005, 12:31 AM   #1023
ford_racing's Avatar
Send a message via MSN to ford_racing
Runninng a trqack with the 27t stock motors are approx 28mm rollout, what sort of rollout should I use for a Tamiya 23 turn?
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 08-23-2005, 04:05 AM   #1024
Trader Rating: 69 (100%+)
Got these from the box ...
Tamiya TZ specs:
RPM at no load = 26,500rpm(7.2V)
Torque at best efficiency = 500gf-cm(7.2V)
Tamiya RZ specs:
RPM at no load = 27,500rpm(7.2V)
marvi is offline   Reply With Quote
Old 08-23-2005, 04:21 AM   #1025
Hardriven RC's Avatar
Go for the same rollout like the one for the 27t Stock.
Hardriven RC is offline   Reply With Quote
Old 08-23-2005, 04:38 AM   #1026
A 23 turn can pull a much higher rollout than the stocker, try 3-5mm higher rollout.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-24-2005, 12:30 AM   #1027
thank you all
ARC R11
Yokomo YRF001
AE B5m
Old 08-24-2005, 10:20 AM   #1028
When you say you're gearing at 5.5 what does that mean? I'll assume it's a calculation for Rubber Tire cars but I know nothing about Rubber Tires at all. I run foams and always go by rollout in mm or inches. So when I talk about a Monster Stock I run around 1" total rollout and/or 25.4mm's. How would I convert 5.5 into xxxmm's of rollout?
Thanks!
Nitro-Boy is offline   Reply With Quote
Old 08-25-2005, 06:24 AM   #1029
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Thanks!
a rubber tire's diameter is about 64mm
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 08-25-2005, 09:58 AM   #1030
Thanks alana!
So if I'm doing this right then this conversion should get me to the equal rollout:
Rubber:
2.5 Gear
96 Spur
43 Pinion
Tire 64mm
Gear Ratio 5.58
Rollout 36.02mm
Foam:
2.5 Gear
96 Spur
48 Pinion
Tire 58mm
Gear Ratio 5.00
Rollout 36.44mm
Are you guys really running 36+mm of Rollout w/23-Turns?
Old 08-29-2005, 05:03 AM   #1031
Can anyone verify this is correct?
Thanks!
Old 08-30-2005, 01:02 AM   #1032
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
sometimes i run a rollout in the 35+
it works well i had plenty down the straight and kept up through the infield
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 09-04-2005, 10:22 PM   #1033
Rod M's Avatar
what sort of Spring/brush combo is best for the Tamiya RZ?
Rod M is offline   Reply With Quote
Old 09-04-2005, 10:27 PM   #1034
Korey Harbke's Avatar
Yeah, I gear mine pretty similar to a reedy quad mag..... They can pull a pretty tall gear.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-05-2006, 06:37 PM   #1035
curious mind's Avatar
Originally Posted by loopedeloop
Hi Guys
We run my #1 son's car at 6.08 fdr ( kawada vx-r) rollout approx 32mm on hpi sprint on a fairly open asphalt track ,straight about 60mtr long with easy infield, maybe 130 mtr total length.I'm guessing as it is a carpark track and slightly different every week .This motor runs a bit hot and has less runtime than #2 son
We also run #2 sons car at 6.11 ,(kawada vx-r) in an xpress jnr with same approx rollout 32mm.It isnt as hot after 5min run.
(Both of these cars are capable of comparable times as others running in our 12t class).
It is when we change to either yokomo t-max LT or LR motor( we have both) that the heat difference becomes noticeable.
I have noticed that both yoko's use laydown and the kawada standup brushes. Maybe that has something to do with it or maybe the ceramic bushes in the yoko are tighter and take more running in?Or does the yoko just prefer to rev higher?.
Anyways thanks for your replies and keep up this informative thread.
Hello sir, just happen to be trying a freinds 23T motor. its a Kawada VX-R 23T, just want to know its characteristic, i mean is it a RPM or torque motor? The local race track is something like 116ft x 96ft total size, having sweeping runs and technical layout. Hope you can help me with some information so i can gear the motor correctly. tnx sir
curious mind is offline   Reply With Quote
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
Brushless motor thread crono man Electric On-Road 52 05-24-2005 05:28 PM
Motor Glitch (Different Thread) DOMOisCOOL Electric On-Road 6 03-16-2004 08:58 PM
Stock Motor Thread March Electric On-Road 41 09-15-2003 11:10 AM
21T Motor Thread Raikonnen Electric On-Road 2 08-03-2003 08:50 AM
