Old 07-19-2005, 09:40 PM   #1006
work's Avatar
What are the difference of the Kawada Vs, Vx and Vt motors?
work is offline   Reply With Quote
Old 07-19-2005, 10:47 PM   #1007
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by tornado
Nice track !! 5.3 top start off with.
5.3??? ..maybe 5.5
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-19-2005, 10:51 PM   #1008
VT 3mm core 3 port rotor High Torque
VS 3mm core 6 port rotor High RPM
VX 4mm core 6 port rotor Torque/RPM
Old 07-19-2005, 11:49 PM   #1009
work's Avatar
Dave
Any idea how the Kawada compares to the other 23T? Especially the Vxr?
Old 07-19-2005, 11:52 PM   #1010
Dave
I myself prefer the Torque based 23t motors... I don't care for the VXR... just doesn't have enought get up and go for me out of the corners.. no matter how much I tweek it...
-Dave
Old 07-20-2005, 12:17 AM   #1011
tornado
Guest
Posts: n/a
Originally Posted by JDM_DOHC_SiR
5.3??? ..maybe 5.5
-Dave
Old 07-20-2005, 12:19 AM   #1012
tornado
Guest
Posts: n/a
Originally Posted by canto54
Thanks, I also have a Yok Tmax FSR, which one should I use and how to gear the FSR on the same track?
I'm a new uer aof these motor. For the 1st test I do, I find them very impressive and my friends can't believe I was running 23T...
Hv not tried that yet. ....anyway with the LR gearing is around 7ish and I would safely start off with around 7.4-7.5
Old 07-20-2005, 03:46 AM   #1013
maxepower's Avatar
Default 23 T
Tamiya's RZ 23 turn works great but you need to tweek the motor to get maximum power. I've seen a tweeked 23 turn blow past a 19 turn like it was standing still!
Downside the motor gets real hot if you gear it too low!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 07-20-2005, 07:49 AM   #1014
Send a message via AIM to canto54
5.3??? ..maybe 5.5
-Dave
Yes, I ran 5.5 and the motor was really impressive. Thanks for your help.
canto54 is offline   Reply With Quote
Old 07-20-2005, 12:27 PM   #1015
diha's Avatar
Default Stock motors
Hi Guys,
Anyone running HPI R2 motors?
Any commend?
Which is better? Standup or laydown brushes?
Does it really affect the performance?
diha is offline   Reply With Quote
Old 07-20-2005, 01:04 PM   #1016
rbboy's Avatar
Send a message via MSN to rbboy Send a message via Yahoo to rbboy
DAVE: hey there! i just got a new Kawada VS.. i understand from your post that this motor is high rpm, i used to run a Katana ss that i geared with a 5.52 ratio at a local track... any suggestions for the kawada vs? also, i have a new Alex RD flat-out would you know of this motor too? my track has a 45-meter back straight and is not so technical hope you could help thanks!
Carlo
www.xtremerchobbiesph.net
rbboy is offline   Reply With Quote
Old 08-19-2005, 04:17 AM   #1017
ttso's Avatar
Just got a new motor, Orion SV2 23x2T 25000rpm. Was this high rpm or high torque? start with 5.5 or something else?
ttso is offline   Reply With Quote
Old 08-20-2005, 02:05 AM   #1018
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
Default Tamiya RZ rpms
hey guys
i tryed a new spring and brush combo on my Tamiya RZ last night.. and the results surprised me a litte
std springs, std brushes (seratted though) pulled 29000 revs
std springs, fantom 315 brushes brand new pulled 25-26000 rpm
trinity purple pos, trinity red neg, fantom 315's pulled 25000rpm
are these numbers good for a 23T stock motor or is this motor past its prime??? i have no idea what to expect having only raced 540 before.
thanks
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 08-21-2005, 06:43 PM   #1019
Rod M's Avatar
what is the difference between the TZ and RZ Tamiya ?
Rod M is offline   Reply With Quote
Old 08-21-2005, 07:59 PM   #1020
Joehwee's Avatar
Originally Posted by diha
Hi Guys,
Any commend?
I have been using the HPI R2 TL in my Pro4 geared at 5.55 and the motor run very well. Not too sure the difference in perform between the standup and laydown
HB Racing - OS Engine - VP Powermaster - Nosram - Sanwa - Schumacher Racing - HPI Racing - CapricornRC - Dualsky - Savox - AKA - Juc Racing - Team Orion - SMJ - MM Spec - Muchmore Racing
Joehwee is offline   Reply With Quote
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
Brushless motor thread crono man Electric On-Road 52 05-24-2005 05:28 PM
Motor Glitch (Different Thread) DOMOisCOOL Electric On-Road 6 03-16-2004 08:58 PM
Stock Motor Thread March Electric On-Road 41 09-15-2003 11:10 AM
21T Motor Thread Raikonnen Electric On-Road 2 08-03-2003 08:50 AM
