23T motor thread >
23T motor thread
23T motor thread
Old 07-07-2005, 04:06 AM
  #991
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by miniracer
Great! Thanks!
No prblem... let us know how you like your new motor
-Dave
JDM_DOHC_SiR is offline
Old 07-07-2005, 06:51 PM
  #992
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
hey dave
Would trinity purple springs work well with the standard tamiya brushes on the super stock type RZ? Or consquently would the purple springs work better with the atlas 079 brush as i was asking about before? or would both these things be waste of time... if so what springs are best?
DJB is offline
Old 07-07-2005, 07:03 PM
  #993
Originally Posted by DJB
hey dave
The springs that come with the RZ are quite stiff.... I think that they are a little bit stiffer than the Trinity Purples.. try them out ... but if you get more arcing of the brushes with them I would go back to the standard spring
-Dave
Old 07-07-2005, 07:05 PM
  #994
DJB
DJB's Avatar
thanks... also should i muck around with a harder spring on the positive side and weaker one on the negative or is this not really worth it. thanks heaps
DJB is offline
Old 07-07-2005, 07:07 PM
  #995
I would give it a try and see what works better for you on the track..stick with the same gear ratio though...when you try this out and check the temp when you come off the track
-Dave
Old 07-07-2005, 07:09 PM
  #996
DJB
DJB's Avatar
My motor gets warm to hot during a run so ill test the rollout from there with the mods. Thanks for the advice ill give it a whirl
DJB is offline
Old 07-08-2005, 07:10 AM
  #997
Let us know how it runs
-Dave
Old 07-09-2005, 12:51 AM
  #998
DJB
DJB's Avatar
i didnt get a chance to run it because there was no class because of the skool holidays but it sounded alright on the power supply.
question about the comm tho, whats the approx number of runs you should use it before you cut it. It isnt geared too hard approx 46 pinion on a 96 tooth spur on a TB evo 3. i think thats about 5.42 im not sure. The comm in sections seems to be lightly black and then near the lines that are down the comm its much heavier. any reasons for this?? thanks
DJB is offline
Old 07-09-2005, 01:21 AM
  #999
3~4 runs max with that motor before you need to cut the comm.... I would try a final drive 5.5 if you can.. or change to a 45t pinion gear
-Dave
Old 07-09-2005, 01:38 AM
  #1000
DJB
DJB's Avatar
damn three to four runs thats rather short lol but thats what i expected. Is there any other spring/brush combo that could devlop some more torque from this motor as my track is quite tight. The atlas brush and the std spring seem they should work really well for rpm although on my track it cant be used to its full advantage.
the pinion should be right i put a 44 on last time... have to dig up the 45 one
DJB is offline
Old 07-13-2005, 11:10 PM
  #1001
im totally new to 23t motor. wats the best 23t motor out thats available online? and where i can get spare armatures for em since i dun havea comm lathe. is the kawada vx 'r' any good? where can i get a replacement armature for it?
mocky is offline
Old 07-14-2005, 12:43 AM
  #1002
work's Avatar
Anyone here with experience running Kawada VX 23T? How does it compare to Atlas Force or Katanas?
work is offline
Old 07-15-2005, 03:26 AM
  #1003
Default Yok TMAX FLT gearing
Hi,
I'd like to know to gear my new Yok FLT on a track with a 40m straight line.
There are pics og the track here: http://membres.lycos.fr/mrclongwy2/m...onpistemrc.htm
Julien
canto54 is offline
Old 07-15-2005, 04:37 AM
  #1004
tornado
Guest
Posts: n/a
Originally Posted by canto54
Hi,
Julien
Nice track !! 5.3 top start off with.
Old 07-15-2005, 06:05 AM
  #1005
Thanks, I also have a Yok Tmax FSR, which one should I use and how to gear the FSR on the same track?
I'm a new uer aof these motor. For the 1st test I do, I find them very impressive and my friends can't believe I was running 23T...
canto54 is offline
