23T motor thread >
23T motor thread
23T motor thread
Old 06-30-2005, 01:02 PM
  #976
stridervc's Avatar
Default Great thread!
Hey guys.
Thanx for all the great info you've provided! I've been running silver can up till now, and have been thinking of getting a 23 turn motor. Thanx to this thread i've decided on the Tamiya TZ, i was going to get the RZ before. I'm getting the tamiya because i'd like to enter the tamiya cup too.
As a newbie to rebuildable motors, is there any special breakin procedure i should follow?
Fred
stridervc is offline
Old 06-30-2005, 03:12 PM
  #977
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by stridervc
Hey guys.
Fred
3 volts for 8-10 mins... and make sure you use some bushing oil on the bushings
-Dave
JDM_DOHC_SiR is offline
Old 06-30-2005, 05:38 PM
  #978
miniracer's Avatar
hi, anyone know whats the performance of the dinkyspeed 23t evolution 2 motors?
miniracer is offline
Old 06-30-2005, 05:46 PM
  #979
loopedeloop's Avatar
Originally Posted by tornado
LR motor should be geared around 7 ish and LT perhaps around 5.6 - 5.4 should be ok for that track size. One more thing......is the comm burnt ?
No Funnily enough. the comm was fine.
I have been obviously undergearing the LT motor tho.
Geoff
loopedeloop is offline
Old 06-30-2005, 06:01 PM
  #980
They are a hand tuned version of the Orion Katana 23t motor.. they are "OK". .. .. but you could do beter with ALEX Racings new FLAT OUT motors
-Dave
Old 06-30-2005, 10:58 PM
  #981
stridervc's Avatar
-Dave
Thanx Dave
Old 07-01-2005, 06:15 PM
  #982
miniracer's Avatar
-Dave
thanks for the insight! which of the FLAT OUT do you recommend? read the website and there quite a few versions. its a medium sized track and best gearing with my prism pinkdot (laydown torque) before was 6.10 to give you an idea of the size.
Old 07-01-2005, 08:04 PM
  #983
Man that pick dot is OLD..anyways I would try out the FLAT OUT S-TA... itsw a very good stand up Torque motor with a good amount of RPM too
-Dave
Old 07-02-2005, 03:56 AM
  #984
miniracer's Avatar
-Dave
it is old , would you know the difference between the S-TA and the S-T as I noticed on the website the A tag which is aluminum to the different motors. thanks
Old 07-02-2005, 04:04 AM
  #985
I`m using that same motor right now with very good results.. my local track is about 35m for the straight and a tech. infeild..and I am gearing it in the 5.7~5.8 range
-Dave
Old 07-02-2005, 04:15 AM
  #986
miniracer's Avatar
-Dave
thanks
Old 07-02-2005, 02:56 PM
  #987
thanks
No problem
Old 07-06-2005, 08:29 PM
  #988
miniracer's Avatar
hi dave, what gearing should I start with a Flatout L-RA? the lhs did not have any S-TA so I got the L-RA.
what can you say about the new Kawada Vx-r?
Old 07-06-2005, 11:42 PM
  #989
I hope you like RPM.. because that motor has a bunch.... I would start your gearing at about 6.5 and then go up or down .2 to match your track size... also make sure to cut the comm after every 3 runs and check the brushes too.
-Dave
Old 07-07-2005, 02:03 AM
  #990
miniracer's Avatar
-Dave
Great! Thanks!
