23T motor thread >
23T motor thread
23T motor thread
Old 05-28-2005, 04:19 AM
  #961
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
THe Brushes that would work really well are the ATLAS 079 brushes.. kind of soft.. but they have good power and are not too hard on the comm.. also one more thing you might want to try with the RZ is to bring the gear ratio in the 6.2 range with that size track
On rc mushroom ive only been managing to find the atlas 080 brush. Is this the same sort of thing or whats the difference with this brush??
DJB is offline
Old 05-28-2005, 11:03 AM
  #962
Originally Posted by the flash
JDM,
I just got a Tamiya Dynarun Super Touring Motor to use in the Modified class race. Do you know how many turns this motor has? The manual does not specify any information about the number of turns...... Also, is this motor the TORQUE type or the RPM type? What Final Drive Ratio should I start with? The track that I run my car on is a bit technical, with some twisting turns and a straightaway about 35 meters long... I would really appreciate info on this matter....
if i am not mistaken it is 14 x 2 motor
EngTat is offline
Old 05-28-2005, 11:06 AM
  #963
tornado
Guest
Posts: n/a
Try this link : http://rc-mushroom.com/product_info....oducts_id=2569
Old 05-29-2005, 06:15 AM
  #964
DJB
DJB's Avatar
hey hey it works thanks heaps
DJB is offline
Old 05-30-2005, 08:05 AM
  #965
tornado
Guest
Posts: n/a
Of Course Matey !!
Old 05-30-2005, 03:54 PM
  #966
Mr-Tamiya1's Avatar
do you know any links where i can purchase 23turn motors?
Mr-Tamiya1 is offline
Old 05-30-2005, 07:48 PM
  #967
tornado
Guest
Posts: n/a
Try this....
http://www.rcmart.com/catalog/defaul...ath=421_293_39
you're welcome!
Old 06-27-2005, 07:41 PM
  #968
loopedeloop's Avatar
wow good thread guys!
I got two 23t yoko from hongkong 1x23lr, 1x23lt grey can with blue heatsinks on endbell.
They both seem to run a lot hotter than my kawada 23t
(for the same gearing)and create more heat from battery and esc.
Is this typical??
they dont seem any slower just run a lot hotter
loopedeloop is offline
Old 06-27-2005, 07:45 PM
  #969
DJB
DJB's Avatar
maybe that particular motor is not supposed to be geared hard or run hard for long periods of time. Have you tryed a fan. I nicked one from my spare pc and attached it to my car and the motor is alittle cooler not that much but still the less heat the better. make sure the bushing are ok too they might be tight being a new motor and all.
DJB is offline
Old 06-27-2005, 08:22 PM
  #970
tornado
Guest
Posts: n/a
Is this typical??
What gearing were you runnnig on these motors and what is the track size ?
Old 06-27-2005, 08:37 PM
  #971
LazyBug's Avatar
Is this typical??
Yokomo 23T motors do have RPM and Torque type with either laydown and standup brushes. They should be geared differently.
LazyBug is offline
Old 06-27-2005, 11:29 PM
  #972
Hi Guys
We run my #1 son's car at 6.08 fdr ( kawada vx-r) rollout approx 32mm on hpi sprint on a fairly open asphalt track ,straight about 60mtr long with easy infield, maybe 130 mtr total length.I'm guessing as it is a carpark track and slightly different every week .This motor runs a bit hot and has less runtime than #2 son
We also run #2 sons car at 6.11 ,(kawada vx-r) in an xpress jnr with same approx rollout 32mm.It isnt as hot after 5min run.
(Both of these cars are capable of comparable times as others running in our 12t class).
It is when we change to either yokomo t-max LT or LR motor( we have both) that the heat difference becomes noticeable.
I have noticed that both yoko's use laydown and the kawada standup brushes. Maybe that has something to do with it or maybe the ceramic bushes in the yoko are tighter and take more running in?Or does the yoko just prefer to rev higher?.
Anyways thanks for your replies and keep up this informative thread.
Old 06-27-2005, 11:37 PM
  #973
No we dont run fans
and yes I have wondered about the bushings on the yoko's , maybe they are a motor that just keeps on getting better/looser as you use it.
Old 06-28-2005, 05:04 AM
  #974
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
No we dont run fans
THe bushings on the Yokomo 23T`s are a very low friction bushing.. that if not properly oiled every few runs will wear out a bit faster than the standard style bushing
-Dave
JDM_DOHC_SiR is offline
Old 06-30-2005, 07:50 AM
  #975
tornado
Guest
Posts: n/a
Hi Guys
LR motor should be geared around 7 ish and LT perhaps around 5.6 - 5.4 should be ok for that track size. One more thing......is the comm burnt ?
