23T motor thread
#917
hi guys
anyone knows the ratings for the capacitors & scotty diode if i were to get them from hardware store?
thx
thx
#919
Hi guys,
Can you give me a good web site with a large choice of mod/stock motors!!
Please, I've found a few but still looking for more
It would really help
Cheers!!!!!
Cheers!!!!!
#920
I have a question regarding 23t motors:
My local track has a stock sedan class. Last sat night during a heat, I was standing with the announcer watching the race when we saw one car that had substantially more punch coming out of some of the slower corners.
After the race, the announcer called this car up to the announcers booth. The motor was NOT any "stock" motor I'd ever seen.
The can was black in color and had cooling slots that resembeled a Orion core stock. (several small slot on an angle). The armature was flat on the end, like a mod motor and did not extend out the end bell like current generation stock motors.
The guy running it insisted it was stock, but was disqualified. The driver was japanese and spoke little english. I actually think it may have been a misunderstanding versus an attempt to cheat.
My question is this:
Is a 23t motor a "stock" motor in Japan?
What type of power does one of these motors put out compared to a Monsterstock or a 19t?
Does the discription of the motor sound like anything you guys have heard of?
#921
wow, what a mighty misunderstanding indeed.
Yes, most of the asia-pacific countries follow the japanese stock motor rule of 23T single wind, machine winding with bushings and fixed timing.
You can identify these motors with the rounded shaft ends, whereas the 27T Roar stocks have tapered ends.
They are indeed much faster than 27T stockers, and while I've only raced with the trinity monster stocks, these 23T's are a step ahead in terms of speed and torque.
In terms of power and speed, the 23T stock motors should be slower than 19T spec motors, although the difference is not large.
Not your race organisers' fault for having allowed a 23T into a 27T race, it's the duty of the racer to ensure compliance, but this is a just a misunderstanding(or ignorance).
#922
anyways I have tuned many of 23T motors and I can tell you that some properly tuned ones will hang if not flat out pull on some of the top hand tuned 19T motors that are out right now
-Dave
#923
#924
Originally posted by DJB
hey whats the main area you should concentrate on in tuning a stock motor?? like where wouldnt you try to tune it and where are the areas where big improvments can be gained??
-Dave
BTW there are a few good pic`s it took about 4-5 pages back that show you where to start
#925
Thanks Guys!!!!
Thanks Guys!!! That was just the info We needed!!!!
Think you may have helped put out one of those california wildfires.............
Lee Caldwell, So Cal Raceway
#926
Some stock motors can blow the socks of a 19T even the Reedy Quad Mag! Even lower wind motors!!
One time I raced at our local track, I htought it was stock 27t----- it was stock 23t!! My monster stock was like a 540 motor running with the modified!
Here is something to look at: will work with a 23t also
http://www.motortuningsecrets.com/tunestockmotor.html
#927
is this stock motor anygood? anyone have tried it? te label is kinda cute Toyomiti Edition 23T
#929
Re: Brushes
Originally posted by tomdav
Dave are these the atlas brushes that work so well.
ATLAS,980YEN,MH7-078 SPRINT SILVER BRUSH NO TERMINAL
There not cheap.
There not cheap.
-Dave
#930
Originally posted by EngTat
is this stock motor anygood? anyone have tried it? the label is kinda cute Toyomiti Edition 23T
It's a older design 23T motor from ATLAS... but it has plenty of RPM and gearing is similar to a 27T monster stock because it has a split stack arm and it"s a bit shorter on the stacks to so the windings a r shorter(basically a 21~22Turn motor ).. gear between 6.6~7.2 Range (depending on track size and motor condition)
-Dave
