23T motor thread >
23T motor thread
23T motor thread
Old 07-23-2003, 04:48 PM
  #76
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Exclamation Also...
Can you say Epoxy balanced rotors on a 23T Stock motor!!!
-Dave
JDM_DOHC_SiR is offline
Old 07-23-2003, 04:56 PM
  #77
OSherman's Avatar
Default Re: Also...
-Dave
interesting spiral'd slots dividing the poles and the comm...
less arching possibly?...any comments?..
OSherman is offline
Old 07-23-2003, 05:16 PM
  #78
Default Re: Re: Also...
well I have tried the same series of motor that has the standard slit in the rotor and ...the spiral`d rotor seems to have more power everywere!! also the motor pulls more amps too
-Dave
Old 07-23-2003, 05:37 PM
  #79
Korey Harbke's Avatar
WHOA, thats cool. I might have to get one of those just to try out and see how it is! Where can I get one of those over here in the States?
-Sushi Boy
Korey Harbke is offline
Old 07-23-2003, 06:54 PM
  #80
analyzer's Avatar
Default Re: Also...
-Dave
HPI stock 23 turn (orion made) is also epoxy balanced. Not bad.
analyzer is offline
Old 07-23-2003, 10:03 PM
  #81
davioh's Avatar
dave: are they better than the yokomo's?
davioh is offline
Old 07-23-2003, 11:00 PM
  #82
blixelX's Avatar
found that no 1 here is talking bout the tamiya's motor... is tamiya's one very poor???
blixelX is offline
Old 07-23-2003, 11:29 PM
  #83
TA03 Drive Hard's Avatar
My guess this improves the surface contact between the comm and the brush which provides an almost continuous flow of current resulting in the increase of amp draw...
ted
TA03 Drive Hard is offline
Old 07-23-2003, 11:33 PM
  #84
I use the tamiya motors myself... i actually race them at my lhs... imho, they shouldnt be used with batteries that cannot keep the punch... using matched pack/cells will do much better... and dont over gear them... i fried a super stock type r... temped @ 275 degrees f... burnt the comm, fried the wires... i could not change my ratio because i did not have an extra pinion but i like the tamiya motors
ted
Old 07-23-2003, 11:41 PM
  #85
blixelX's Avatar
ted
what is the gear ratio u use??
blixelX is offline
Old 07-23-2003, 11:47 PM
  #86
Well at the time i burnt the motor it was a 112/51 i have a ta04-trf... it was fast but it could not handle slowing in the turns and then full throttle... if i had been street/drag racing then i wouldnt have had that prob but right now im using p2k2 120/40...
Old 07-24-2003, 03:02 AM
  #87
the Yokomo SR has just a tad bit more rpm( 2000 rpm more ) but the ECHO PQ puts the power down in the infield and my lap times are much faster with the ECHO motor...and I can gear this motor in the 5.5 range and it Rips...but 8 mins is kind of a pinch with the batterys that I have heheheh
-Dave
anyways the Yokomo, Xenon and ECHO new motors just are AWESOME!!!! they really over power the new ATLAS motors....
Old 07-24-2003, 06:45 AM
  #88
alucard's Avatar
Default kawada 23t
anyone try the new kawada 23t balck rotor motor? this motor looks promising. my LHS can get only a few types of 23t so this is the latest in my country. hope to hear so feedbacks.
alucard is offline
Old 07-24-2003, 07:06 AM
  #89
Default Re: kawada 23t
the Black Rotor Kawada 23T`s a re not to bad...you can gear them 1~2 teeth larger on the pinion 48P and still have the same run time and punch....also a bit motr RPM from them..... but it`s still the same arm under the black coating unlike the new Yokomo and ECHO rotors which are new ...but if you do get the new style 23T from Kawada...get the Laydown version....best overall power and RPM
-Dave
Old 07-24-2003, 07:49 AM
  #90
Disney's Avatar
Default Re: Re: kawada 23t
-Dave
yes this is good i been using it,,,,
Disney is offline
