23T motor thread >
23T motor thread
23T motor thread
Old 08-23-2004, 02:48 AM
  #766
Dave: TCS is coming up in oz soon... 23turns only (new rule for gt1 here in oz). Was wondering how do the newest tamiya 23ts compare against each other?
thanx...
Dragonfire is offline
Old 08-23-2004, 09:50 AM
  #767
Rob Mincey's Avatar
Dave - you've got PM.
Rob
Rob Mincey is offline
Old 08-24-2004, 04:23 PM
  #768
over gear's Avatar
Trader Rating: 18 (100%+)
Default Re: Re: Re: Re: RPM on 23T motor
Originally posted by JDM_DOHC_SiR
I do know a few things about the 23T motors that "can" make them very fast
-Dave
Can you share the speed secret?
over gear is offline
Old 08-24-2004, 04:40 PM
  #769
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
The LR is the king of RPM for the 23T`s that are out now a little brush magic and a some hood adjustments with a little spring tweaking and you can get 40000+ rpm form the LR..
as far as the RZ goes.. I know if a few tricks but it will not come near 40000 RPM... the most I have been able to get from the RZ is about 37000 ish
-Dave
what voltage was this at?
dontfeelcold is offline
Old 08-24-2004, 05:39 PM
  #770
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: Re: Re: RPM on 23T motor
7.2 volts on a Much More Motor Master
JDM_DOHC_SiR is offline
Old 08-25-2004, 02:24 AM
  #771
thanx...
Old 08-25-2004, 05:49 AM
  #772
Rob Mincey's Avatar
The new RZ is more RPM based, while the TZ is more of a torque motor, from what I understand. Also, the RZ has laydown brushes while the TZ has standup brushes.
Rob
Old 08-25-2004, 04:44 PM
  #773
Default atlas
what doyou guys think about an atlas progress is is a good motor ir was my freind ripped of
pink panther is offline
Old 08-26-2004, 04:18 PM
  #774
DZ
Default LR AND SR YOKOMO"S
Hi guys,
Is there any differnce between the LR and SR in the yokomo range, besides the brushes? are the cans different? or maybe the arms?
Cheers Damien
DZ is offline
Old 08-26-2004, 06:43 PM
  #775
Default Re: LR AND SR YOKOMO"S
Originally posted by DZ
Hi guys,
Cheers Damien
The Yokomo SR and LR are pretty much the same motor.. Both of them have a 3mm core rotor with 6 ports and the can has the same magnet...it's just that the endbell is different ...AKA Laydown vs Standup these motors seem to like the new 3600 batteries better than the 3300 GP cells..?? but the ST and LT like the GP 3300 cells better.. kind of weird.. but I can turn faster laps with the SR and LR with the Sanyo 3600..?? don"t ask
-Dave
Old 08-26-2004, 07:03 PM
  #776
Neil Rabara's Avatar
Dave, I got the handout motor for the TCS and am tuning it. Love the brushes you sent me. I've discovered that they work better after the cross sectional serrations are almost gone.
Neil Rabara is offline
Old 08-26-2004, 07:12 PM
  #777
a couple drops of tribro and wipe the brush off when you are breaking in to brushes and they will rock
Glad that you like them ...but if you like those you will love the newer ones with more silver
-Dave
Old 08-26-2004, 07:20 PM
  #778
I haven't received the motor you sent me yet. Since, I have the spec motor, I am going to focus on that. When I get yours, I'll return it to you.
Old 08-26-2004, 07:37 PM
  #779
OK that will work
-Dave
Old 08-26-2004, 08:18 PM
  #780
tornado
Guest
Posts: n/a
Default Re: Re: LR AND SR YOKOMO"S
-Dave
Very recently in Japan there was a benchmark test on the new Sanyo 3600 and GP3300 in comparison. The results shows that the Sanyos perform better and higher voltage than the GPs at 20A discharge which is suitable for Stock Racing. GPs shows more performance at 30A discharge and this would appeal to boys running modified.
So guys...racing Stock...23T...Sanyo is ur cells I'm getting 2 myself. and stick to ur GPs if you're running modified.
Bryan
