Old 08-14-2004, 10:21 AM   #751
lem2's Avatar
Default JDM_DOHC_SiR
Hi!!! Do you also run 1/12th scale pan cars?
If so what rollout are you using with these 23t motors?
Or what spur / pinion combinations are you using?
Thanks!
Lem
lem2 is offline   Reply With Quote
Old 08-14-2004, 03:47 PM   #752
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: RPM on 23T motor
Originally posted by GTTurbo
I just bought a Tamiya RZ motor, and trying to tune it to get a higher RPM.
What is the highest RPM that a 23T motor can do?? And why it is so low compare to a moster 27T?
Also, does anyone know what is the timing deg on the RZ, because I don't think it is 24deg.
Thanks in advance
Well lets see if I can help you..
the highest RPM a 23T motor can do?? well I have a few yokomo LR`s that can turn over 43000rpm as far as low rpm on your RZ compared to a 27T motor..the RZ has to be gear very different than a 27T...but it will be just as fast with more torque than a 27t motor due to the fact that the cars are very diiferent on the 23T ..for example the 27T rotor is very light about 35 grams on average due to the split type laminations..and the 23T rotor will always have a full stack rotor that is about 52 grams on average... so due to the fact that the 27t rotor is lighter it has a bunch more RPM..but what it gains in rpm it`s loosing in torque..
Basically I would put any 23T motor against any 27T motor...or19T motor that "I" own any day of the week...much more of a solid motor
as fas as the timing goes the 23T motors have only 20 deg of timing
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-14-2004, 09:33 PM   #753
gcooper's Avatar
Default Re: Re: RPM on 23T motor
If given a choice I would prefer the 19t bb motor with 24 deg advance vs a 23t bushing motor with 18 degree advance. Then again maybe you know something about tweaking the 23t to beat the 19t?
Coop
gcooper is offline   Reply With Quote
Old 08-14-2004, 11:00 PM   #754
GTTurbo's Avatar
43,000 rpm
How on earth did you get that?? This is with the spiral comm and ligther lamm??
Care to pass on some of the secret? Have you ever tuned the RZ yet?
Thanks Dave...
GTTurbo is offline   Reply With Quote
Old 08-15-2004, 01:36 AM   #755
Default Re: Re: Re: RPM on 23T motor
Coop
I do know a few things about the 23T motors that "can" make them very fast
-Dave
Old 08-15-2004, 01:42 AM   #756
43,000 rpm
Thanks Dave...
The LR is the king of RPM for the 23T`s that are out now a little brush magic and a some hood adjustments with a little spring tweaking and you can get 40000+ rpm form the LR..
as far as the RZ goes.. I know if a few tricks but it will not come near 40000 RPM... the most I have been able to get from the RZ is about 37000 ish
-Dave
Old 08-15-2004, 08:58 PM   #757
Rob Mincey's Avatar
Dave - Were those pictures what you needed? Looking forward to some of your "tweaks."
Rob
Rob Mincey is offline   Reply With Quote
Old 08-15-2004, 09:07 PM   #758
Rob
I"ll have some to send your way.. here tonight
-Dave
Old 08-15-2004, 09:13 PM   #759
Rob Mincey's Avatar
Rock!
Rob
Old 08-16-2004, 01:08 PM   #760
Neil Rabara's Avatar
Dave, YGPM.
Neil Rabara is offline   Reply With Quote
Old 08-21-2004, 04:39 AM   #761
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
hey guys
I just bought a super stock type R and a comm stick and some fantom 315 brushes. when the brushes get worn can i re serate them or do i have to get new ones. and with the comm stick how many turns should i need to do before the comm is nice and shiny??
thanks
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 08-22-2004, 10:20 AM   #762
Rob Mincey's Avatar
Dave - you have those pics ready for me?
Thanks again!
Rob
Old 08-22-2004, 11:22 PM   #763
Dave, YGPM.
Old 08-23-2004, 12:04 AM   #764
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Originally posted by DJB
hey guys
thanks
Always run new brushes. It really isn't worth the effort to try and rebuild a brush. Personal opinon, chuck the stick and bum a lathe off of someone. In the long run, a stick will promote a groove in the comm. The stick just cleans the comm surface, it doesn't give you a fresh surface to work with.
mafiaracers is offline   Reply With Quote
Old 08-23-2004, 12:11 AM   #765
Originally posted by Neil Rabara
Dave, YGPM.
back to you with answers to your questions
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
Brushless motor thread crono man Electric On-Road 52 05-24-2005 05:28 PM
Motor Glitch (Different Thread) DOMOisCOOL Electric On-Road 6 03-16-2004 08:58 PM
Stock Motor Thread March Electric On-Road 41 09-15-2003 11:10 AM
21T Motor Thread Raikonnen Electric On-Road 2 08-03-2003 08:50 AM
