23T motor thread >
23T motor thread
23T motor thread
Old 07-21-2004, 09:55 AM
  #676
prodrive's Avatar
Default 23t for tb evo 3
what is the best gearing for tb evo 3 if you are using mirage prism pink dot? what spur and pinion should i use, and range of ratio
prodrive is offline
Old 07-21-2004, 01:28 PM
  #677
DerekEngland's Avatar
Originally posted by tamiyadriver
hello... my name is wes... and im an rc-aholic.
Hey Wes..... Tell us when our meetings will be.... I think we all need some therapy!!!!
DerekEngland is offline
Old 07-21-2004, 05:28 PM
  #678
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by jedi
Dave, would you know if the HPI TS and Orion Katana TS are the same motor? The only visible difference aside from the color and the sticker are the bushings. The HPI TS has the regular bushings while the Katana TS has the serrated bushings. Both are Top based motors and both have "TS type" stickers on them. Thanks.
This thread should be renamed "ASK DAVE" with the questions we all ask you.
I belive the new Katana ha differnt mags in it and the HPI Rotor is a TOP based one..but I think the New Rotor is a Sagami micro one.?? Because they have the newer style balanceing cuts on the arm .. Have not done any testing of the 3mm core HPI TS..?? Might have to pic one up from my buddy that runs one to test out
-Dave
JDM_DOHC_SiR is offline
Old 07-21-2004, 05:42 PM
  #679
jedi's Avatar
Thanks Dave, as always. If you do try out the 3mm HPI TS, please let me know what you think of it.
jedi is offline
Old 07-22-2004, 03:50 AM
  #680
xray racer's Avatar
Trader Rating: 22 (100%+)
hey JDM
just wondering... i have an oppurtunity to get ANOTHER 23t hahah
its a MIRAGE Linear of Power motor
would this motor be better than the atlas progress and luna stc-s glory ltd that i just bought???
i'll await your response as i'll do a trade off if its better
the track we run on is fairly flowing... so it doesnt really need GOBS of torque
let me know
thanx
robbie
xray racer is offline
Old 07-22-2004, 04:04 AM
  #681
Originally posted by xray racer
hey JDM
let me know
thanx
robbie
Hmm which version of the Mirage is it.?? red dot yellow or blue..
I belive it is a older version of the Mirage.so it will have a4mm core..but the Yellow dot verion really has a lot of top end and it has laydown brushes..
My favorite Hybrid motor is the Blue Star... really good motor
-Dave
Old 07-23-2004, 07:12 PM
  #682
xray racer's Avatar
hey another Q dave. haha sorry
with my luna stc-s... it has a bit of play up wards but not down...
i read that tha magnetic field in motors will usually pull it down if anything... so is there any point in removing the play upwards?? or is it fine as is???
also... the negative hoods on all my 23's have a very SMALL amount of play in them... is it worth TRYING to get rid of all of it by squeezing the hoods carefully with pliers?? i dont have a proper tool so thats my only option really
or is it not really woth the trouble?? there is bugger all play its not like its cocking very far
thanx again
robbie
Old 07-23-2004, 08:54 PM
  #683
Team EAM
Trader Rating: 79 (100%+)
Ok for all you guys overseas that run 23 turn motors. IF i were to get a case and hand tune them would you be interested? Our Boy Dave is trying to talk me into it but I want to make sure there is enough demand before I plunk out anymore cash!!
EA
EAMotorsports
EAMotorsports is offline
Old 07-23-2004, 10:34 PM
  #684
fai
Regional Moderator
fai's Avatar
Dave: I've done your mentioned tricks to my Yoko LT and tested it on track! Amazzzzing!!
Hope I don't 'crush' the -ve side too much... HaHa
Thanks!
How about all other racers??!
fai is offline
Old 07-23-2004, 10:39 PM
  #685
rice's Avatar
dave,
the mirage with a laydown b. and the other side is standup b. what can say abt this motor? performance likewise.
rice is offline
Old 07-23-2004, 11:02 PM
  #686
KoE
KoE's Avatar
EA
EAMotorsports
count me in
KoE is offline
Old 07-24-2004, 04:17 AM
  #687
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
Default gearing suggestions
hey guys i just have received a super stock type R motor and for TCS im racing on a short concrete track with my tb evo3. any suggestions on how to gear the motor as this is my first time with one of these guns. is it similar to a 540 in ratio??
DJB is offline
Old 07-24-2004, 04:33 AM
  #688
Thanks!
Hi Fai
Glad that some of the tips I posted are working for you all
-Dave
Old 07-24-2004, 04:34 AM
  #689
rice's Avatar
Default Re: gearing suggestions
i suggest you start at 6.3 to 6.5 for a short track. i've tried that gearing an works great.
rice is offline
Old 07-24-2004, 04:35 AM
  #690
gearing is very different than the 540.. start with 6.0 and gear fron there up or down a tooth..
-Dave
