23T motor thread >
23T motor thread
23T motor thread
Old 07-15-2004, 09:29 PM
  #646
glide 1's Avatar
Default Hi Dave,
I ran a Katana SL last week and it was ballistic!!! i geared it 6.3 for the first heat and for the 2nd heat i geared 6.58, did better overall times with 6.58 gearing. broke the lap record at our local track too
i thought the SL (laydown ver.) would be a torque motor but it seemed to top out well rpm wise on the straight, (equal to the t-maxx at least). Question: what type brushes come with the motor? coz they are very good!!, only complain is is that as the serrations wear out, there seem to be a slight loss in performance aswell. Reedy 766 (with hole) are the best laydown brushes i've tried so far, i wonder if it would work for this motor too....any comments dave?
glide 1 is offline
Old 07-16-2004, 07:12 AM
  #647
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Hi Dave,
The SL really has a lot of RPM your geared it right with the 6.5... on my SS i have geared it some times at 6.9 because this thing cranks out almost 39000rpm!!!
as far as the brushes go.. the are based off a atlas silver sprint They are Very good brushes also when the face wears out your losse a bit off the top but gain a bit more in torque so gear up after that happens...
no coment on the Reddy brush...but I`m using a bunch of FUkuyama Prototypes in some of my laydown motors with very good results across the board
-Dave
JDM_DOHC_SiR is offline
Old 07-16-2004, 10:13 AM
  #648
glide 1's Avatar
Default jdm,
thanks, will keep an eye out for those atlas sprint brushes, also will try gearing up with the stock brushes now that the serrations have worn. i'll probably cut and use the same brushes till i find the atlas's.
Wow!! 39,000 rpm...did not know 23t motors revd that high
those fuks brushes out on the market yet??
glide 1 is offline
Old 07-19-2004, 11:06 PM
  #649
Neil Rabara's Avatar
Default Re: New versions of 23T stocks for 2004
Originally posted by JDM_DOHC_SiR
Have a look
-Dave
JDM, what do you know of the Tamiya 23T with stand up brushes? Sorry I know the part number.
Neil Rabara is offline
Old 07-20-2004, 01:21 AM
  #650
Default Re: Re: New versions of 23T stocks for 2004
Sure do ... give me a few mins and I`ll PM it to you and post it here
-Dave
Old 07-20-2004, 03:25 AM
  #651
DerekEngland's Avatar
Dave,
Any information you can provide on the Tamiya motor would be appreciated here too.... Also, do you have any info about the motor with laydowns too???
DerekEngland is offline
Old 07-20-2004, 07:43 AM
  #652
Turbonium's Avatar
Trader Rating: 27 (100%+)
i think the part #s may be like 53697 and 53698. saw these on Champ's website. Rz type and TZ, with RZ being the laydown brushes....
Turbonium is offline
Old 07-20-2004, 08:15 AM
  #653
Default Re: Re: Re: New versions of 23T stocks for 2004
-Dave
Thanks Dave, let me know.
Old 07-20-2004, 02:36 PM
  #654
Default Re: Re: Re: Re: New versions of 23T stocks for 2004
TZ part# 52696... 23T Stock Standup Torque(enduro)... But don't let this scare you away from this motor it has quite a bit of..... how would you say...B@lls
Not a bad motor at all I can turn just as fast of lap times with the standup motor as I can with the RZ(rpm base)laydown motor
-Dave
Old 07-20-2004, 02:52 PM
  #655
Dave,
Do you have any tuning suggestions on brush, springs, etc?
Old 07-20-2004, 04:18 PM
  #656
Default Re: Re: Re: Re: Re: New versions of 23T stocks for 2004
-Dave
Please PM what you did to prep the motor and anything that might improve performance.
Old 07-20-2004, 04:42 PM
  #657
Originally posted by Nonstopone
Dave,
Sure do but most tricks might not be legal for TCS Races .... If you don"t use it for that series race I can help out
-Dave
Old 07-20-2004, 04:43 PM
  #658
Default Re: Re: Re: Re: Re: Re: New versions of 23T stocks for 2004
I have all of my Motor ...info's at home ...I"ll PM it to you after I get off work
Old 07-20-2004, 07:56 PM
  #659
Turbonium's Avatar
well, i think the rules state that any brush/spring combo may be used, but prolly no timing mods, or arm swaps.
Old 07-20-2004, 08:01 PM
  #660
If thats the case... I'll post the tricks to them here a bit later then
-Dave
