Old 07-06-2004, 07:19 AM   #601
jedi's Avatar
Default Hi Dave!
What did you gear your Tamiya motors at? TZ? RZ? And how long is the straight in your tracK Thanks!!!
jedi is offline   Reply With Quote
Old 07-06-2004, 07:29 AM   #602
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Hi Dave!
35m straight.
tz 5.6~5.8
rz 6.1~6.4
that should get you in the ball park..ech motor is a bit different ...but the TZ was a better performer as far as lap times were..it felt better all over the track..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-06-2004, 08:33 AM   #603
PizzaDude's Avatar
Dave,
What's the difference between these Tamiya's and the previous ones?
Regards,
Pizza
PizzaDude is offline   Reply With Quote
Old 07-06-2004, 08:35 AM   #604
jedi's Avatar
Default Dave
Thanks for the info. Have you tried the Orion Speed Demon TS motor? How does it compare to the Katana TS? And how does the Katana compare to the Tamiyas? Thank again.
Old 07-06-2004, 11:52 PM   #605
rice's Avatar
Default Re: Dave
jedi,
planning on getting all the 23t motor?
i heard that you hav 2 23t motors coming from manila.
rice is offline   Reply With Quote
Old 07-07-2004, 04:02 AM   #606
Thumbs up Ones I have to let go
Have a look guys these are going on sale in the for sale thread... just thought I would give you guys the 1st look
-Dave
Old 07-07-2004, 04:22 AM   #607
jedi's Avatar
Hi Dave! I see you have a Kawada VS-R motor. How do you find it? I have one too but I can't seem to get it to run well. How is yours doing? What springs and gearing are you using? Please be patient with all my questions but I feel there's no one better to ask than the 23 turn motor guru.
Rice: I am a far second to you. Hehehehe!!!!!!
Old 07-07-2004, 04:32 AM   #608
I find it to be very fast!! I gear mine in the 5.8 range with a track that has a 35m straight.. but I have gone to 5.6 at times..as for the springs I use a lighter oneon the negative side
-Dave
Old 07-07-2004, 04:58 AM   #609
Default Re: Dave
Similar but the newer Katana TS has 3 less laminations on the rotor stack and the bushings are newer like the new Yokomo 23T motors
but as far as performance is conserned(SP?)..the TS katana has a slight bit more RPM but the Torque is the same
-Dave
Old 07-07-2004, 10:53 AM   #610
rice's Avatar
jedi,
lets compare note this friday's nite race about the tamiya tz and rz motors.
jdm,
got any results on your luna motor?
Old 07-08-2004, 05:46 PM   #611
rice's Avatar
jedi,
are you runing ur new tamiya 23t later?
Old 07-08-2004, 09:00 PM   #612
jedi's Avatar
rice, i may run them if they get here in time for me to tune and gear them properly. You?
It's better to be lucky than to be good......when it comes to getting a clean run in qualifying!
Old 07-09-2004, 06:35 PM   #613
rice's Avatar
jedi,
run my tz on lst nite race geared it around 6.33 also my luna.
runs great its all arnd motor "torque and rpm"
Old 07-09-2004, 07:04 PM   #614
Originally posted by rice
jedi,
6.33..????? How big is the Straight at your track.??? You might be under gearing that motor... I was gearing mine at 5.8 a couple of days ago with no problems in heat and such... the Straight at my track is 35m
-Dave
Old 07-09-2004, 07:21 PM   #615
jedi's Avatar
Default Dave,
Geared my TZ last night at 5.8+ and lacked a bit of infield punch. Tried 6.0+ and found it much better all around. Fast on the straight and punch in the infield. Rice and I were both fast all around. Track straight was 35 meters with a 28 meter back straight and a tight infield. Will try a one tooth smaller pinion next time.
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
Brushless motor thread crono man Electric On-Road 52 05-24-2005 05:28 PM
Motor Glitch (Different Thread) DOMOisCOOL Electric On-Road 6 03-16-2004 08:58 PM
Stock Motor Thread March Electric On-Road 41 09-15-2003 11:10 AM
21T Motor Thread Raikonnen Electric On-Road 2 08-03-2003 08:50 AM
