23T motor thread >
23T motor thread
23T motor thread
Old 06-26-2004, 10:06 AM
  #496
Curtis Schlaht's Avatar
Default Re: Re: JMRCA 23t Motor Specifications
Originally posted by JDM_DOHC_SiR
Hi Curtis..
I`ll be able to answer some of your questions ...but I`ll have to do some research on the other ones
timing is at 24 deg
they have compression welded comm tabs
Bushings only( Yokomo has some awesome low friction ones now)
max price is 4000 Yen
4 arm blanks are available
3mm 6 port(RPM BLANK)
3mm 3 port(TORQUE BLANK)
4mm
5mm
3 comm styles
9mm comm(mid size)
7.6mm comm( small or STD comm )
7.6mm Spiral comm ..
epoxy balancing is leagal so is drilling
As far as the brushes go they "CAN NOT BE SOLDERED ON" eyeor ring terminals only...but you can use double shunt wires
It seems Like Sagami Micro has the Best deal since they make 90% of all the parts for the motors now..
I hope this helps a little
-Dave
Thanks for the reply Dave, As always you’re a plethora of information…
Can you direct me to a link containing the rules and specs for the 23t motors….
Do you know if the fan used in the Tectro 23t motor is there own design, meaning they have this piece manufactured rather than purchasing it OEM….
Thanks,
Curtis Schlaht Jr.
Fukuyama Motorsports
Curtis Schlaht is offline
Old 06-26-2004, 03:29 PM
  #497
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Re: Re: JMRCA 23t Motor Specifications
Originally posted by Curtis Schlaht
Thanks for the reply Dave, As always you’re a plethora of information?E
Can you direct me to a link containing the rules and specs for the 23t motors?E
Do you know if the fan used in the Tectro 23t motor is there own design, meaning they have this piece manufactured rather than purchasing it OEM?E
Thanks,
Curtis Schlaht Jr.
Here is a link to the motor specs for building
http://www.jmrca.com/stock_motor.html
as for the Fan..Sagami Micro makes them
-Dave
JDM_DOHC_SiR is offline
Old 06-27-2004, 12:45 AM
  #498
Wink New Vs Old
Here is a shot of the New 3mm core Rotor with 9mm(mid comm) that Xenon is using now(right rotor) and the Rotor on the Left is the Echo Based screw comm Ti coated shaft 4mm core rotor that they use to use(left rotor)..
Enjoy.
-Dave
Old 06-27-2004, 12:50 AM
  #499
Default Re: New Vs Old
Enjoy.
-Dave
Woops forgot the pic
Old 06-27-2004, 07:19 PM
  #500
tornado
Guest
Posts: n/a
Enjoy.
-Dave
What is the difference in performance Dave ?
Old 06-27-2004, 07:24 PM
  #501
Default Re: Re: New Vs Old
The newer 3mm core rotors (Higher RPM and they seem to have a bit more torque... might be something with the laminations)
-Dave
Old 06-27-2004, 07:30 PM
  #502
tornado
Guest
Posts: n/a
Default Re: Re: Re: New Vs Old
-Dave
Is the new arm similar to the yoks ? The can and endbell is.
Old 06-27-2004, 07:32 PM
  #503
Default Re: Re: Re: Re: New Vs Old
the arm is the same on the yokomo's but the Comm is Smaller on the Yok. series
Still testing the Newer Xenon Ceribious series motors...
-Dave
Old 06-27-2004, 07:34 PM
  #504
tornado
Guest
Posts: n/a
Default Re: Re: Re: Re: Re: New Vs Old
-Dave
Aso! Got one of the Ceribious....Red dot....will be testing it this weekend. How's urs so far?
Old 06-27-2004, 07:50 PM
  #505
Default Re: Re: Re: Re: Re: Re: New Vs Old
It nees some serious help ... It seams the gearing that Xenon recommends is off quite a bit... they say to gear in the 6.8~7.2 range... but try around 5.9-6.4 range ..also you should try to shim the rotor inside the cans magnetic feild also adjust the brush hoods..also there is a lot of play with the brush in the hood on the + & - side
the most RPM and torque I was able to get from this motor so far was 30500 Rpm @7.2V and about 8amps @ 7.2V...
but the torque curve on this motor on my fantom dyno is very narrow
-Dave
Old 06-27-2004, 07:57 PM
  #506
HPC II's Avatar
JDM, can you tell me about the new Katana motors? We are receiving ours in a day or two.
HPC II is offline
Old 06-27-2004, 08:04 PM
  #507
Stick with the TS and SS version... the TS version is awesome ..very good and similar in performance to the Yokomo ST
-Dave
Old 06-27-2004, 08:16 PM
  #508
HPC II's Avatar
JDM, appreciate your response.
What do you normally do to a 23T once you get one new? And what are the important points to maintain the performance of the motor?ie, speed, torque, etc...
HPC II is offline
Old 06-27-2004, 08:30 PM
  #509
1st thing Align the the brush hoods and get rid of all of the slop in the negative side of the hood... also try a bit siffer spring on the + side... for starters... theres a bunch more but.... .. . . .. thats another time
-Dave
Old 06-27-2004, 08:56 PM
  #510
tornado
Guest
Posts: n/a
Default Re: Re: Re: Re: Re: Re: Re: New Vs Old
-Dave
Wow! looks like quality control in Xenon is slacking or what ?
