23T motor thread >
23T motor thread
23T motor thread
Old 06-24-2004, 07:31 AM
  #481
jdm thanks for the input.
i think in europe 19t should be the new 27t stock class then have 12t limit for racers who want it and then open mod ie no limit.
this would be a lot better in my personnal view.
trf racer is offline
Old 06-24-2004, 07:37 AM
  #482
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
No problem ...thats what this board is for to swap idea`s and such ..also to help each other..
-Dave
JDM_DOHC_SiR is offline
Old 06-24-2004, 09:00 PM
  #483
Curtis Schlaht's Avatar
Default JMRCA 23t Motor Specifications
Hey guys:
Iím hoping someone here can help me out, I'm looking for rules and guidelines that JMRCA uses for there 23T motor specifications, any help here would be appreciated... Iím Particularly interested in these specs, max wire diameter, min wire length, max timing, compression welded comm tabs only or is braise and soldering permitted, are bushings only allowed, is there a max retail price like ROAR has set for our stock classÖ Thanks
Curtis Schlaht Jr.
Fukuyama MotorSports
Curtis Schlaht is offline
Old 06-24-2004, 11:58 PM
  #484
PizzaDude's Avatar
Originally posted by PizzaDude
Dave,
What is the difference between the new Tamiya 23t compared to the older versions?
Any additional info?
Ben2Ben
Any on-track info yet.
Thanks guys.
Pizza
PizzaDude is offline
Old 06-25-2004, 12:10 AM
  #485
Sorry Pizza.
I have not got around to testing some of the newer Tamiya motors yet
but I can ask around to try one out..
-Dave
Old 06-25-2004, 12:22 AM
  #486
Default Re: JMRCA 23t Motor Specifications
Originally posted by Curtis Schlaht
Hey guys:
Iím hoping someone here can help me out, I'm looking for rules and guidelines that JMRCA uses for there 23T motor specifications, any help here would be appreciated... Iím Particularly interested in these specs, max wire diameter, min wire length, max timing, compression welded comm tabs only or is braise and soldering permitted, are bushings only allowed, is there a max retail price like ROAR has set for our stock class?EThanks
Curtis Schlaht Jr.
Hi Curtis..
I`ll be able to answer some of your questions ...but I`ll have to do some research on the other ones
timing is at 20 deg
they have compression welded comm tabs
Bushings only( Yokomo has some awesome low friction ones now)
max price is 4000 Yen
4 arm blanks are available
3mm 6 port(RPM BLANK)
3mm 3 port(TORQUE BLANK)
4mm
5mm
3 comm styles
9mm comm(mid size)
7.6mm comm( small or STD comm )
7.6mm Spiral comm ..
epoxy balancing is leagal so is drilling
As far as the brushes go they "CAN NOT BE SOLDERED ON" eyeor ring terminals only...but you can use double shunt wires
It seems Like Sagami Micro has the Best deal since they make 90% of all the parts for the motors now..
I hope this helps a little
-Dave
Old 06-25-2004, 12:48 AM
  #487
PizzaDude's Avatar
Originally posted by JDM_DOHC_SiR
Sorry Pizza.
-Dave
If you would.
Ild be most thankfull...
regards,
Pizza
Old 06-25-2004, 05:47 PM
  #488
xray racer's Avatar
Trader Rating: 22 (100%+)
hey JDM,
mind if i get some more info off you?
i was told by a guy down here that the 23t motors dont mind heat, so he said that you can basically gear em up and up adn up... as long as the comm doesnt discolour???
he just said to not worry about the heat of the motor when it comes off the track, but rather just the colour of the comm and as long as its normal... your fine....
could you expand on this at all??? or is it correct
thanx in advance
robbie
xray racer is offline
Old 06-25-2004, 05:48 PM
  #489
xray racer's Avatar
sorry .... another Q,
generally speaking... are the stand-up brushed 23t motors better than the lay downs???
and could you breifly explain the difference ???
thanx again...
robbie
Old 06-25-2004, 06:02 PM
  #490
Originally posted by xray racer
hey JDM,
thanx in advance
robbie
Yes .."SOME" 23T motors can stand prolonged heat...due to the magnets in them...Basically most of the ECHO Based Motors and a few Atlas ones... they are the ones with the 4mm core rotors also...but I would say if the motor gets above 90deg cels. it`s way to hot and there will be a noticeable power drop...
as far as gearing goes with thesemotors.. you can gear them buy laptime and temp.... 75-85deg is were I run mine at ..
but take some care when these things get hot!! I have seen some melt endbells..when over geared
-Dave
Old 06-25-2004, 06:18 PM
  #491
thanx again...
robbie
it`s mostly personnal preferance..but 90% of the guys here in Japan Run the Stand Up brush..reason #1. Good overall power and similar power to a laydown motor. #2.NO DRAG BRAKE affect... (trust me try a yokomo LT and you`ll see what I mean )#3 amp draw is less to a degree..and for 8min heats you need some good run time batteries to moke time with most Laydown 23T motors.#4 more power can be madewith the standup brushed motors with a couple tricks with brush hood adjustment.
-Dave
Old 06-25-2004, 07:04 PM
  #492
P2
P2's Avatar
Trader Rating: 15 (100%+)
Default Team TECTRO 23t
Dave,
I bought this Suer Real Stock Team TECTRO motor in Japan last fall and the track owner said it was very fast....it cost a little bit more too. It has a sagami endbell and laydown brushes. Have you tested these and are they any good? What's a good gear ratio for a large track?
Thanks,
Paul
P2 is offline
Old 06-25-2004, 07:13 PM
  #493
P2
P2's Avatar
Default Re: Team TECTRO 23t
Here is a pic of the arm:
P2 is offline
Old 06-25-2004, 08:10 PM
  #494
Originally posted by P2
Dave,
Thanks,
Paul
the TECTRO Motor is very good......but they have been band from JMRCA due to Tweeked comms and the timing is a bit more than 24 deg...but they do have all of the nice bells and whistles..The Fan at the end of the Arm is a nice feature that the new KAWADA motors now use with there black rotor and the TECTRO Rotors are the new 3mm core ones also, now for gearing the Motor...it depends on what version you have ...Torque ver. or RPM ver.
Torque ver. 5.4~5.6 large track maybe around 5.2 if your track is huge
RPM ver. 5.6~5.9 same size track
-Dave
Old 06-25-2004, 08:14 PM
  #495
Default Re: Re: Team TECTRO 23t
Yep...you have the RPM Version..
-Dave
