23T motor thread >
23T motor thread
23T motor thread
Old 04-13-2004, 09:54 PM
  #406
S-T-R-l-K-E-R's Avatar
Default reddish com?
this is a sign that the com has over heated. 1st thing to check is the gearing. the com will turn red if the car is overgeard. if you absolutly think that your gearing is right then most probably its your springs. normally what i would do is move to a harder spring.
just my .02
S-T-R-l-K-E-R is offline
Old 04-13-2004, 11:14 PM
  #407
alana07's Avatar
Trader Rating: 52 (100%+)
Default Re: reddish com?
just my .02
if the comm has overheated, then the brushes must be discoloured too. i've come across reddish comms too, but the brushes are okay, no discolouration. so does this means that the motor is geared right to the maximum??
alana07 is offline
Old 04-14-2004, 01:35 AM
  #408
Ares17's Avatar
Default 23T High Torque
Which 23T high torque motor is good for the TLT 1? Thank you.
Ares17 is offline
Old 04-14-2004, 01:55 AM
  #409
Default Re: Re: reddish com?
the comm heats up faster than the brushes cause its not only metallic in nature but also of its rotating action like disc brakes in a real race car it glows red.
most probably since it hasnt heated up yet enough to discolor your brushes you are geard just right. try to install slightly heavier springs.
-if you have been using your motor for quite some time now you might want to change to new springs.
-if your motor is new and spring tension is still good try adding more tension by streching your spring more around 180* for the spring on the positive side and less for the spring on the negative side.
commutator
copper-yellow-orange-red-blue-purple. yellow is the color of the comm once it has started to over heat.
Old 04-14-2004, 04:06 AM
  #410
alana07's Avatar
Default Re: Re: Re: reddish com?
commutator
thanks for the advice,
i'm using team luna LU-85, speed version standup brush, less than 10 packs through it. by the 4th pack, i noticed the reddish comm, drop a teeth since then and so far so good.
alana07 is offline
Old 04-16-2004, 03:08 AM
  #411
AN
Hello!
Will Putnam Blue Stock Brush and Putnam Green Stock Brush work with the 23T Yok LT and are they better then the yok stock brush?
What is the difference between the blue and green ones?
/AN
AN is offline
Old 04-16-2004, 07:33 AM
  #412
AN
...and Atlas Laydown sprint silver
/AN
AN is offline
Old 05-27-2004, 01:53 PM
  #413
KoE
KoE's Avatar
pushing this thread back up since JDM has returned to the joint dang he has a lot of catching up to do
KoE is offline
Old 05-28-2004, 01:53 AM
  #414
evaa's Avatar
hi guys,
i know this was probably asked and answered before, but cant help but wonder, how do you minimize the really strong cogging effect of 23T motors. i ran a 23T last night and the cogging effect was so strong, it semmed like the car was braking whenever i released the throttle, your suggestions would be really invaluable, tanx
evaa is offline
Old 05-28-2004, 03:12 AM
  #415
AdR|aN's Avatar
evaa.
Did you try with other motors?
Sometimes the problem arises from the motor itself.
I race 23t stocks and had never this cogging problem.
I am also using the same ESC ur using.
You can try softer brush springs and adjust the armature free play in the can.
Hope it helps
AdR|aN is offline
Old 05-28-2004, 03:39 AM
  #416
KoE
KoE's Avatar
Originally posted by evaa
... it semmed like the car was braking whenever i released the throttle...
try switching to standup-brush motor if u r currently using laydown-brush motor
KoE is offline
Old 05-28-2004, 03:44 AM
  #417
KoE
KoE's Avatar
sorry...double post
KoE is offline
Old 05-28-2004, 07:14 AM
  #418
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
hi guys,
Which 23T Motor are you using that is causing this Drag Brake affect ...if it's a torque based one and it has laydown brushes you can do a few things but I will need to know which one it is 1st ..also if you only like using a laydown brush motor....and you want less drag brake...try using the RPM version they are much better off throttle....
-Dave
JDM_DOHC_SiR is offline
Old 05-28-2004, 10:47 AM
  #419
glide 1's Avatar
Default JDM_DOHC_SiR
Are the yokomo t-max LT and Mirage Prism (pink dot) essentially the same motors? I do not notice much of a differenc except for the packaging.
Also the Mirage RS2 , the 1 with one laid down and one standup brush hood any different to the pink dot with both laid down hoods?
What brushes do you recommend for these 2 motors?
glide 1 is offline
Old 05-28-2004, 12:06 PM
  #420
Default Re: JDM_DOHC_SiR
The LT and Pink Dot are pretty much the same motor ..just different brushes and a bit softer spring on the - side on the Hybrid one..
as for the Mirage RS2 or Blue Star.... . It's one of my new favorites...it has all of the Power of a Laydown Torque Motor but does'nt have the high drag brake affect of a Laydown Torque motor..... on average I get about 20000 Rpm @ 5 volts & 5~7 apms of draw from the Blue Star.... and they like to be geared around 5.4~5.7 depending on the track layout and grip conditions
-Dave
