23T motor thread >
23T motor thread
23T motor thread
Old 11-11-2003, 06:11 PM
  #361
alch's Avatar
Dave,
What motor would you recommend for Yatabe?
The Yoko LT is hands down the best out of the motors i have, pretty much the same as the Luna LII.
I am keen to try another if you have any recommendations
Just picked myself up a comm lathe too (Kose), the switch that is supplied doesn't fit through the hole though!!!
The Atlas brushes suitable fo the LT?
Cheers
Alch
alch is offline
Old 11-11-2003, 06:20 PM
  #362
Kenneth Tan's Avatar
Anyone knows the performance difference between the Tamiya Type RR and Tamiya Type RR (Gun Metal Case)? Are they supposed to be geared the same? Thanks.
Kenneth Tan is offline
Old 11-11-2003, 07:47 PM
  #363
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
the chrome can RR has the standard core and can be geared about 1~2 teeth down from the RR(gunmetal can) which has a 3mm core..the newer RR has more RPM all over the place....
-Dave
JDM_DOHC_SiR is offline
Old 11-11-2003, 07:54 PM
  #364
Originally posted by alch
Dave,
Cheers
Alch
Gearing\Motor for Yatabe....hmmm ....here ya go
Xenon Griffon Gold= 5.10 if you have good batteries 5.3 if you don`t
Tectro 3 port Laydown=5.25G bats/5.45N bats
LR 5.5~5.7G bats /6.0 N bats(this motor will get hot no mater what the final drive ratio is but it moves
ECHO PQ 5.1G bats/5.4N bats
thats should get you started
also I can help you out with the Kose lathe.. it fits I might have to make a trip to Tokyo to show ya
-Dave
Old 11-11-2003, 08:24 PM
  #365
alch's Avatar
Thanks for the info...Might give the Xenon Kin a go this friday..
I was looking at getting a temp gun too, any recommendations? Couldn't find too much on the subject.
Really? From what i could tell, it should fit through the hole on the right, then you secure it with the nut, but the thread of the switch doesn't fit through the hole.. see attached pic (Thats as far as it goes, nut is off too!)..
I should go, but the hole is just a fraction to small, i thought of just filing it down, but i shouldn't really have too! Plus i dont have a file!
Heading off to RC-Champ/Supa Rajicon shortly, getting the Ctx-m for Asimo.
Alch
alch is offline
Old 11-11-2003, 08:33 PM
  #366
alana07's Avatar
Trader Rating: 53 (100%+)
Default 23t in a 1/12
hi dave,
any tips on gearing a yok 23t RSL on a 1/12 pan car? main purpose is just for bashing, sometimes races too!!
the brushes + springs are kit items, hoods aligned and motor fitted with bearings.
thanks.
alana07 is offline
Old 11-11-2003, 08:46 PM
  #367
-Dave
Thanks Dave, so meaning the chrome RR can geared with a final ratio of 5+ while gun metal RR at 6+?
Old 11-11-2003, 11:11 PM
  #368
alch's Avatar
Dave,
The Kose lathe i got is a new design (Shiny Finish), i took it back to the shop (Rajicon) and explained to them the problem, they got 3 other out and tried to put the switch in, but none of the fitted.
So..... They had one of the older model's left which doesn't look as good as the new design (Matt finish) and just swapped it over...
So all is good.
I also picked up a Xenon Kin, so will give it a go this friday at Yatabe!
Cheers
alch is offline
Old 11-12-2003, 12:04 AM
  #369
Dave,
So all is good.
Cheers
Make sure that you break that motor in good before you go all out with that gearing I'd say take it on th eeasy side of the gearing around 5.5 for abuot 3~4 packs then after that skim the comm and if you can reserate the brushes and gear away at it
-Dave
Old 11-12-2003, 12:07 AM
  #370
Mid 5's for the Chrome and lower 6's for the Gun metal
-Dave
Old 11-12-2003, 12:10 AM
  #371
Default Re: 23t in a 1/12
Originally posted by alana07
hi dave,
thanks.
I have yet to try 23T stocks with my new 1/12 Car...but I'll be able to dabble with it this weekend...and see what type of roll out you would need along with a gear ratio .
-Dave
Old 11-12-2003, 12:20 AM
  #372
alch's Avatar
Will do! Thanks for the advice
This will be my first time using a lathe, will get someone at the track to watch over me..
Reserate the brushes? Please explain!
I was looking for some comm drops too, couldn't find any though.
You said in an earlier post that Atlas market them, but i couldn't find it, does Rajicon or Champ stock it?
Cheers
Alch
alch is offline
Old 11-12-2003, 12:44 AM
  #373
Cheers
Alch
No No Atals makes some bushing lube thats in the Blue bottle ... Also ECHO makes some nice Comm drops( TQ Drops )
-Dave
Old 11-12-2003, 01:05 AM
  #374
alana07's Avatar
Default Re: Re: 23t in a 1/12
-Dave
thanks dave, pls report on your findings, i'll be going to dabble w mine also this weekend, provided it doesn't rain.
alana07 is offline
Old 11-12-2003, 01:12 AM
  #375
Default Re: Re: Re: 23t in a 1/12
What do you do your roll outs in metric or standard..?? I have figured it out in metric for 46~44mm rear tires right now .. a few more hours and I should have it all worked out pretty good...I hop you have some small spurs 92~96T 64P
-=Dave
