23T motor thread >
23T motor thread
23T motor thread
Old 10-11-2003, 04:58 AM
  #316
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Sushi Boy
Hey Dave,
Any new news on the 23T stuff? I'm thinking abotu getting one to mess around with over here in the states. Which seems to be the best high RPM based motor out there? Or even the best all rounder? I can get the Tamiya's around here, but are those any good??
-Sushi Boy
Most RPM
LR and SR Yokomo
Best all around
ECHO PQ
and
Xenon Momo
most Torque
Yokomo ST and LT
and Xenon Kin
-Dave
JDM_DOHC_SiR is offline
Old 10-13-2003, 10:18 AM
  #317
Default 23T real
Who have been used 23T REAL new stock motor<6 port,3 port>?
bambaa is offline
Old 10-13-2003, 10:51 PM
  #318
Default Re: 23T real
There are 4 types of Tectro 23T stocks they are very similar to the new Yokomo series...the 6 Pole type is rather nice... Lots of torque..... and the motor stays quite cool
-Dave
Old 10-13-2003, 11:07 PM
  #319
JDM, got a pic of the Luna STC-X 23T and how does it compare to say the Atlases?
ZER01 is offline
Old 10-14-2003, 12:01 AM
  #320
The STC-X is a great 23t laydownbrush motor that has a very wide torque curve..gear it around 5.3~5.5
the ATLAS motors are good to......there's just to many to choose from
-Dave
Old 10-14-2003, 12:29 AM
  #321
Exclamation Compare
23T REAL 6port motor VS 23T yokomo LT motor.What's more HP?Thank you
bambaa is offline
Old 10-14-2003, 12:38 AM
  #322
Default Re: Compare
LT by far
Old 10-14-2003, 02:39 AM
  #323
[email protected],
How is the Mirage Stock?? Tested some??
MARKANO is offline
Old 10-14-2003, 07:02 PM
  #324
Barry White's Avatar
Hi Dave,
I have a couple of questions. With the motors with one stand up and one lay down brush wish one is on the positive and negative side?
K.O. have some kind of Booster. Does it help in stock, and in modified also why does KO drivers don't use it. Not legal I heard? Becouse I saw a KO booth on an expo and they gave a demo and it seemed to make a motor be as fast with less apm draw. True?
Thanks,
Barry White is offline
Old 10-20-2003, 08:29 PM
  #325
lee82gx's Avatar
anyone know why the whole thing inside the Kawada V-Stock R is black?
any comments on that as i have the laydown version but it's still not been tested yet(i need track time
lee82gx is offline
Old 10-21-2003, 12:20 AM
  #326
sac
It could be part of what Kawada calls r-coating ,it helps with cooling ,I'll check mine and see ,i have never taken it apart before .Kawada is using this process on all there motors now,including there newer 23t motors.If the motor has the new DSE connectors .then it does have the r-coating,and it helps to reduce heat.
www.kawadamodel.co.jp
www.kawadaracing.com
sac is offline
Old 10-21-2003, 02:31 AM
  #327
lee82gx's Avatar
yeah that's what i can deduce from the japanese brochure...mine does not have the DSE connectors.
does it really have any effects?
lee82gx is offline
Old 10-21-2003, 01:10 PM
  #328
LeoChan's Avatar
Default DAVE :
I'm use SR or real 6 port motor use which bursh & spring best ?
Putnam bursh bester ?
Thanks !
LeoChan is offline
Old 10-21-2003, 11:47 PM
  #329
sac
Default r-coating
I have talked to people who have a Kawada 23t motor ,one that has the r-coating and one that didn't and they said that there was a slight temp differrence between them.So i would have to say that the r-coating works,and you know what they say a cooler motor = more power.
As for the DSE connectors i wish other motor companies would do something similiar to there motors,just makes for a great connection .
sac is offline
Old 10-22-2003, 01:45 AM
  #330
Default Re: DAVE :
Thanks !
Which Tectro 6 port motor stand up or Laydown.???
But I am using the Putnam X-brush for both the +&- on the SR and I noticed a bit more Torque and RPM with this brush and the Standard Springs
-Dave
