23T motor thread >
23T motor thread
23T motor thread
Old 08-19-2003, 04:20 AM
  #196
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: HIGH RPM 23T
Originally posted by xray racer
hey every one
i race in the meca challenge in australia , its one of very few 23t classes we have, but everyone loves it. i was wondering if some of you, most probably JDM dohc, because he seems to know almost everything , if any of you could please tell me what motor out of this list has the most rpm or is the fastest, as these are the only ones i am accesible to :
ATLAS:
progress
solid
force pink
splash gold team edition
KAWADA:
Vstock
Vstock R
VS stock
VS stock R laydown
VX stock R
YOKOMO:
TMAX zero RST
TMAX zero R
TMAX zero SR
TMAX zero LR
TMAX zero ST
TMAX zero LT
in particular to JDM_DOHC_SiR, if you think there are others that are faster than those in the list, could you please post a link or inform me of how to contact the particular shop, preferrably online, so that i can order one,
thanx everyone
any info would be appreciated
thanx
robbie
OK..
Lets see what you have to play with...so.....you want RPM.....?? How bigh is the Track is it bigger than 160M long.?? or is it smaller.... RPM is mice ..but Power is better...
but fron the list that you have I would have to say the newer Yokomo`s would have to be the better option.. The SR and ST are really good motors and they will last almost 10mins on a good GP3300 pack...also,,....if you don`t mind drag brake you can try the LR or LT they have just a slight bit more power at the reduce of efficiency..
-Dave
JDM_DOHC_SiR is offline
Old 08-19-2003, 06:20 AM
  #197
FUK_WRX's Avatar
Default Luna Glory blue version
Hello im planning to use a team luna glory in a high speed track, should i gear it same gearing as high rpm 27t stock motors such as the trinity monster, matrix v10r ??
What do you think is the ideal gearing for a 414M2 ??
What preperation should be done before using the motor ?? The instructions are in japanes thats why heheee
All help would be appreciated.
FUK_WRX is offline
Old 08-19-2003, 03:14 PM
  #198
Trader Rating: 24 (100%+)
Just a question folks. I posted a comment about 23t motors on the 19t thread. One persons comment was that 23t could never be popular in the U.S. and they felt that the current categories of 27t stock, 19t spec and outlaw Mod were just fine they way they are. So what are your thoughts??? Is 23t the better way to go ?? How are your race classes set up as far as motors go??
Evoracer is offline
Old 08-19-2003, 07:54 PM
  #199
Neil Rabara's Avatar
I feel that it is a natural progression. The need for speed is in all of us, without the expenses of modified.
Neil Rabara is offline
Old 08-19-2003, 08:05 PM
  #200
Lets put it this way I have a few 19T`spec motors that have been Tweaked By a few Reputable motor tuners and none of them can touch some of the "Newer " 23T motors that I have....
no BS.
-Dave
Old 08-19-2003, 08:14 PM
  #201
Default Re: Luna Glory blue version
The LUNA 23T motors..come in many types... I would have to say if you have the STC-R or S or X type them you should be gearing in the 5.5 range...if you have the limmited version of the SI LI SII or LII then gearing shouldn`t go lower than 5.7
but I think you might have the
one of the following
Pink 5.5
Blue 5.2
Gray can with Blue endbell 5.3
this should get you by ...but check the temp of the motor after 4~5 mins and look at the brushes to see if you are gearing it right for you track
-Dave
Old 08-19-2003, 08:34 PM
  #202
FUK_WRX's Avatar
Default Re: Re: Luna Glory blue version
Pink 5.5
Blue 5.2
-Dave
Thanks dave, i got the X version
Do i have to do any preperation for it like cut the comm and align the hoods ??
Thanks again for your help.
FUK_WRX is offline
Old 08-19-2003, 08:43 PM
  #203
Default Re: Re: Re: Luna Glory blue version
The Luna motors come pretty well aligned form the factory...also they come 3d Balanced after Yokomo is done with them...also the brush thats in that version is rather good too
but I would try to break in the bushings and try to Align the hoods is you want the best out of it.. ...Your going to low that motor.... but start the searing at 5.5 and go down from there..
-Dave
Old 08-19-2003, 08:52 PM
  #204
FUK_WRX's Avatar
Default Re: Re: Re: Re: Luna Glory blue version
-Dave
Will do thanks again what brushes can be used in this motor ?? I have access with team altlas and reedy brushes will they do ok can you recommend ??
FUK_WRX is offline
Old 08-19-2003, 08:56 PM
  #205
Default Re: Re: Re: Re: Re: Luna Glory blue version
I think that the brushes are the standard Yok` ones..but the ATLAS Sprint silvers work very well
just run the stock ones and when they go bad replace them with the ATLAS ones..
-Dave
Old 08-20-2003, 04:30 AM
  #206
FUK_WRX's Avatar
Default Re: Re: Re: Re: Re: Re: Luna Glory blue version
-Dave
Thanks dave you surely are the dr of the 23t motors considering how many motors you had in that box
FUK_WRX is offline
Old 08-20-2003, 08:58 AM
  #207
hey dave
was wondering what bushing oil you recommend
and what comm drops to use as well, on our 23T motors
versa is offline
Old 08-20-2003, 09:26 PM
  #208
Originally posted by versa
hey dave
Orion free rev`s for oil and Tribro for com drops and some times bushing lube... but for bushing breakin I just use Luna Moly beraing grease
-Dave
Old 08-21-2003, 10:12 AM
  #209
How about a metal polish to help break in the bushings?
Old 08-22-2003, 05:32 AM
  #210
that works also..I just like the moly grease a bit better... you might want to use the polishe after .??? ....
Just a thought
-Dave
