Old 08-03-2003, 10:39 AM   #136
Default Re: Re: Aussie 23t class
Originally posted by JDM_DOHC_SiR
Have you tried R-10 or Pro Shop Futaba in Tokyo..they do international orders
-Dave
if that doesn`t work PM me for details
i might take you up on that offer in about 2 months if they still dont stock it here or anywhere online so dont forget what you said!
versa is offline   Reply With Quote
Old 08-04-2003, 09:33 AM   #137
davioh's Avatar
hey dave
i'm wondering...does the amount of spaces at the front and end of the armature make a difference? and i blasted my motor with video cleaner and it wasn't as smooth as it was before...then it got a bit better when i put some royal oil in it...how exactly do you maintain the motor? (with out a comm lathe)
davioh is offline   Reply With Quote
Old 08-04-2003, 11:05 AM   #138
LeoChan's Avatar
Send a message via ICQ to LeoChan
Default Brush ?
Do you have use Putnam brush ?
Mid silver & High silver ?
Thanks !
LeoChan is offline   Reply With Quote
Old 08-04-2003, 11:27 AM   #139
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by davioh
hey dave
I usually Clean my motors after every run to get the most out of them...also I try to keep as little play as possible in the Arm..... because less movement = more power...to some exstent i have about 0.2~0.3mm play in the Arm...also try to use a different oil that Royal Oil!!!!!!! thats just to thin for bushings and stock motors..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-04-2003, 11:41 AM   #140
davioh's Avatar
-Dave
diff oil? what do you suggest?
Old 08-04-2003, 11:48 AM   #141
Team Orions` Free Rev`s Bearing and Bushing Oil.... does the trick for me..
Old 08-04-2003, 11:48 AM   #142
Neil Rabara's Avatar
I've never run a 23T spec motor at all. What gearing is needed for this beast to work correctly? Oh, BTW, it's a Tamiya 23T motor.
Neil Rabara is offline   Reply With Quote
Old 08-04-2003, 11:54 AM   #143
Which Tamiya 23T motor...??
the R of the RR..and if it`s the RR which one..the chrome can or the Black chrome can...
if it`s the Chrome RR then it has a 4.5mm Core and you can gear it in the 5.6~6.1 range...... but if it`s the Black Chrome can RR then it has the 3mm Core..and you`ll need to gear it in the 6.2~6.7 Range...
-Dave
Old 08-04-2003, 12:55 PM   #144
-Dave
Thanks Dave
Old 08-04-2003, 12:56 PM   #145
Thanks Dave
No problem
Old 08-04-2003, 03:15 PM   #146
LeoChan's Avatar
Default Dave :
Mid silver & High silver which one for 23T RACE bester ?
Your Real rpm type have how many rpm & use which gear ratio ?
Thanks !
Old 08-04-2003, 11:21 PM   #147
dave,
how about 23t type T (tamiya) ratio?
thanks.
-shah
shah285 is offline   Reply With Quote
Old 08-04-2003, 11:24 PM   #148
davioh's Avatar
Default ask dave
haha this thread should be renamed ask dave!
Old 08-04-2003, 11:34 PM   #149
davioh..
got any answer??
Old 08-04-2003, 11:38 PM   #150
blixelX's Avatar
-Dave
how bout the tamiya super stock type R?
blixelX is offline   Reply With Quote
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
Brushless motor thread crono man Electric On-Road 52 05-24-2005 05:28 PM
Motor Glitch (Different Thread) DOMOisCOOL Electric On-Road 6 03-16-2004 08:58 PM
Stock Motor Thread March Electric On-Road 41 09-15-2003 11:10 AM
21T Motor Thread Raikonnen Electric On-Road 2 08-03-2003 08:50 AM
