Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4?
I have been looking at potentially getting a new TC that is optimized for lipos and brushless. The main 2 chassis that I came up with are the JRXS and the E4. I currently have a TC5 and have to add weight on the battery side to get it to balance properly. Although this is not a problem, I thought that maybe trying something else may be fun to do.
Which one do you prefer and why? I currently run rubber carpet and will be running rubber asphalt once the weather gets better. I run with a 10.5 BL motor.
Check this out for your TC5: Lipo weights for TC5
Here is my car with it installed: Link
It works quite well, especially if you couple it with the Diggity Designs Lipo tray here.
I hope that helps.
I hope that helps.
Or if IFMAR okays lipo, the 2009 XRay will probably be optimized for lipo.
i would probably wait and see what xray comes out with for their next car, hopefully it will be geared more towards li-pos. keep the tc5, losi doesnt even have an on road program any more no factory drivers.
Losi Type-R.
The best designed car so far.
losi type r foam tire on carpet maybe so, outside rubber tire tc5.
For now, nothing better than a Type R over all...parts are very cheap, and easy to get and in abundance, and the car is very easy to work on and drives smooth and easy.
