Old 03-15-2008, 05:26 AM   #1
LOW ET's Avatar
Trader Rating: 97 (100%+)
Default tire warmers?
do you guys still use tire warmers for rubber tire touring car racing? if so, what are you using and where are you getting them from?
LOW ET is offline   Reply With Quote
Old 03-15-2008, 05:47 AM   #2
stiltskin's Avatar
Trader Rating: 102 (100%+)
I use the MuchMore Type S warmers for rubber carpet racing. Depending on the track conditions, they are very helpful for the first 5-10 laps. I usually plug them in for about 15 minutes and then unplug them from the power supply 5 minutes before the race, but still leave them on the tires. If they stay too hot, you will scrub alot of speed. Once traction comes up on the track, the warmers don't seem to have as much effect.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-15-2008, 05:48 AM   #3
Drifting101's Avatar
yea sure are the best i would say is the one made by much more and is about 200 dollars and is like a station that does alot more than just tires or the easy temp controllers and cups for 100 dollars. I like to use rc mart
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 03-15-2008, 08:19 AM   #4
SammyZ's Avatar
Trader Rating: 138 (100%+)
you want muchmore ctx-w IC controlled tire warmers. You get a 120 day warranty, front and rear tires are independantly adjustable, its a car stand, and it looks sick on your pit table. Set you back $200.
SammyZ is offline   Reply With Quote
Old 03-15-2008, 12:48 PM   #5
LOW ET's Avatar
is rc mart the only place to get the muchmore setup? everywhere else i looked doesn't have any. i heard some bad comments about ordering from rc mart so is there anyone in the usa that has them?
Old 03-15-2008, 02:22 PM   #6
You could also try something alittle less expensive.
http://www.integy.com/cgi-bin/webc.c...=2980&p_catid=
Dual temperature control, with 4 strap style warmers (Not the cups) for $80 retail. I picked mine up on ebay for $40 shipped. Works great.
Shawn68z is offline   Reply With Quote
Old 03-15-2008, 02:22 PM   #7
Trader Rating: 24 (96%+)
do tire warmers provide any value on high grib asphalt racing?
nemix is offline   Reply With Quote
Old 03-15-2008, 02:34 PM   #8
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Many times they are just used to help bake the traction compound into the tire.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 03-15-2008, 04:17 PM   #9
Much More is the way to go, they make two type, the electronic (expensive) ones as shown in a previous post but they also make a cheaper version that uses an analog controller instead of the digital one.
_pilot_ is offline   Reply With Quote
Old 03-15-2008, 07:08 PM   #10
JimmyMac's Avatar
If you run on a track where it takes 1, 2 or 3 laps for the tires to hook up/warm up during a race or qualifier, then you should try out some tire warmers. I use them to bake in traction compound for those initial laps. Helps a lot. And you don't really need to take a warm up lap or 2. I use the cheap Eagle ones posted above and hook them directly to my power supply. But I would love to have some MuchMore cup style. If you get the MuchMore ones, be sure to get the correct size. Take off/RP cups are smaller than the Sorex cups. (Since both have different tire diameter, MuchMore made 2 different sizes to fit them correctly.)
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-15-2008, 07:16 PM   #11
If you happen to have the Large tire warmer cups (like me) and the smaller tires, put a blue paper towel in the cup before you place it over the tire. Works well enough. I don't plan on buying the small ones as Take-offs are dead.
Old 03-15-2008, 10:49 PM   #12
SammyZ's Avatar
I know for a fact you can get them at rcmart.com, rcmarket.com.hk, rc-mushroom.com, and by the end of the month towerhobbies.com will have them!
Old 03-16-2008, 04:27 AM   #13
FX Racing's Avatar
I think they are a waste of money because what if the track is dirty and dusty and you clean the track and still get no grip at all it has more to do with your car setup to gain the traction and they dont enhance the performace of your car by much unless you race mod or competing for world championships
FX Racing is offline   Reply With Quote
Old 03-16-2008, 10:51 AM   #14
SammyZ's Avatar
lol
Old 03-16-2008, 03:38 PM   #15
Skiddins's Avatar
If your setup is crap you will gain little, but if you've got the setup they can make a huge difference over the first few laps.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
F/S: Much More CTX-W IC Tire Warmers fav0re R/C Items: For Sale/Trade 1 09-02-2008 08:26 AM
Tire warmers Drifting101 Australia Wanted to Buy 3 08-14-2008 07:06 PM
FS: NIB Reedy Tire Warmers, plus some Speedmind Tire Warmers. Mustangz R/C Items: For Sale/Trade 1 03-25-2008 11:11 PM
MM Tire Warmers DTM.inc Australia For Sale/Trade 5 11-25-2007 11:25 PM
Tire Warmers blewer R/C Items: For Sale/Trade 5 07-05-2005 06:13 AM
