Old 03-14-2008, 12:53 PM   #1
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Default How to protect front of touring car body?
I heard from someone that you should protect the front of your touring car body using fiberglass and shoe goo. How do I go about doing this? I want to protect the wheel wells and other parts of the front of my MazdaSpeed body from cracking during crashes. The simple answer is to not crash but that isnt a solution that works for me.
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 03-14-2008, 01:01 PM   #2
shoogoo is your friend. I use them in the fender right above the front tires and parts of the bumper that have acute angles. Lasting pretty good.
redbones is offline   Reply With Quote
Old 03-14-2008, 01:07 PM   #3
Trader Rating: 38 (100%+)
Look at the painting tutorial on the front page of this site.
or8ital is offline   Reply With Quote
Old 03-14-2008, 01:09 PM   #4
razzor's Avatar
reinforced duct tape or alluminium tape works well.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-14-2008, 01:42 PM   #5
SWTour's Avatar
...things for us NON Pros to help save bodies.
Use a GOOD/FIRM type Foam bumper (P-Dub work great for touring cars - I use BEEFY BUMPERS on oval cars) large ones work best, shaped to the inside of the body with no gap between the body and the bumper.
If your car has a place to do it - use a body support post under about the center of the hood area about an inch in front of the windshield. This helps keep the body from being able to flex and crack at the wheel wells.
Shoe goo on the inside of the body in the areas that are prone to cracking can also be done BEFORE the body is painted, because you can apply paint over shoe goo, but you can also apply the shoe goo after a body is painted (Be careful though because some paint will be affected and get messed up by shoe goo)
NOTE: The higher density the foam bumper, and the better it shaped to the body to prevent body movement...the better the protection will be.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 03-14-2008, 01:52 PM   #6
Kinda the same idea:
I soaked some strips of cloth in epoxy and laid it down on the body. Works pretty well.
deskwarmer is offline   Reply With Quote
Old 03-14-2008, 01:57 PM   #7
P2
P2's Avatar
Trader Rating: 15 (100%+)
Get some reinforced aluminum tape:
http://www.top-racing.jp/showProduct...&ProductID=181
You can order some from www.topracingusa.com and they will ship to your door. Better yet, have your LHS order some for all
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 03-14-2008, 01:57 PM   #8
racingboy14's Avatar
Trader Rating: 25 (96%+)
I use shoe goo on a piece of figerglass cloth in the fenders and after its dry I cut off the excess.
Bk Graphics Custom Painted Bodies
Email me at [email protected] for a custom quote!
We also do vynil mask sheets!
racingboy14 is offline   Reply With Quote
Old 03-14-2008, 01:58 PM   #9
razzor's Avatar
i would think the epoxy idea would make the body a bit too stiff to absorb impacts.
Wide bumpers are a good idea though to support the front of the body.
Casterracing ZX1.5R
Old 03-14-2008, 02:05 PM   #10
JayBee's Avatar
Trader Rating: 31 (100%+)
The best stuff I've used to date is the sticky chassis protective film. Attach part of it to the section of the body you wanna protect and use a hair dryer to form it into place. It goes pretty much anywhere & where it doesn't, Shoe goo it.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-14-2008, 02:17 PM   #11
Superkarter's Avatar
Also make sure the wheel wells are smooth, i sand mine with 800 grit wet and dry after cutting. As any sharp points or corners are the first place a crack will appear
Superkarter is offline   Reply With Quote
Old 03-14-2008, 02:26 PM   #12
slammin's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to slammin
I stick drywall tape on the nose and around the front fenders and then put a layer of shoe goo over it to hold it in place.
RC Addicts AR
Agama A8t
Agama A215e
Agama A215
Agama A215T
slammin is offline   Reply With Quote
Old 03-14-2008, 02:48 PM   #13
FOXY923's Avatar
+1, works great. Make sure you let it cure before running the body though, otherwise there was no point wasting your time.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 03-14-2008, 02:57 PM   #14
LOW ET's Avatar
Trader Rating: 97 (100%+)
the shoe goo doesn't affect the paint? (water colors)
LOW ET is offline   Reply With Quote
Old 03-14-2008, 03:03 PM   #15
FOXY923's Avatar
Not that I've noticed. Make sure the paint is dry first of course.
I use a popcycle stick to spread the shoe goo over the mesh tape. Get as close to the edges of the wheel wells as possible.
RACE 4FUN
How to protect inside of the body? nwilcox88 Painting, Designs, Graphics and Photography 0 03-30-2006 10:53 PM
Best Front Downforce Body? dmayhew25 Electric On-Road 13 07-11-2005 02:42 PM
Wanted: XXX-S Front shock body,shaft .28 Tag R/C Items: Wanted to Buy 1 10-20-2003 07:08 PM
Mtx-2 Front Lola Body mount plate warlord385 R/C Items: Wanted to Buy 0 01-14-2003 03:59 AM
