Old 07-12-2003, 08:19 PM   #1
Aurra Sing's Avatar
Default KO Mars... difference between D/R and Steering Travel
To all KO Mars EX-1 users:
What is the difference between "Dual Rate" (goes up to 100) and "Steering Travel" (goes up to 150)? I was using Level 2, then when you use Level 4, you have the "Steering Travel" option which seems to do the same thing except you can exceed 100%. If they are the same thing, why didn't they just make it just one option.
[edit]S.T. goes all the way up to 150, not 110.[/edit]
Aurra Sing is offline   Reply With Quote
Old 07-13-2003, 12:05 AM   #2
Cole Trickle's Avatar
On my KO Presto, the dual Rate and Steering Travel appears to be the same....
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 07-13-2003, 10:02 AM   #3
highwayman's Avatar
Default Re: KO Mars... difference between D/R and Steering Travel
steering travel should always be set to the max of 150... the D/R will then be used to set how much travel both the wheels can turn, this is accomplished by the dial just above your thumb
highwayman is offline   Reply With Quote
Old 07-13-2003, 04:20 PM   #4
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Alright guys, the Steering travel, should not always be set to the Maximum, what it does do is limit the servo so your wheels dont turn to far and blow out the server, then you go to the dial with your thumb and adjust how much or that steering travel you need available for the track/handling conditions.
Mike Patterson
=MisFitz= NuKe is offline   Reply With Quote
Spektrum Module for KO EX10/Mars/ Mars R Crawler R/C Items: For Sale/Trade 4 04-20-2008 05:19 PM
KO EX10/Mars S/Mars R Spectrum Module & Receiver Crawler R/C Items: For Sale/Trade 7 01-26-2008 08:08 AM
KO MARS AND MARS R 40MHZ MODULE(RF103F) WITH RECEIVER KR-301F AND CRYSTAL SET (RARE) Sigearhead R/C Items: For Sale/Trade 2 05-03-2007 06:19 PM
long travel or short travel for the revo? rmiles87 Monster Trucks 3 02-22-2006 06:00 AM
How to get more steering throw out of a Ko Mars Radio. rcpilot Electric On-Road 5 10-05-2003 08:24 PM
