Old 03-11-2008, 03:41 PM   #1
Send a message via MSN to k£v!n
Default New Reedy Li-Po Battery Packs
Source - http://www.rc-area.co.uk/blog/?p=2743
“Utilizing state-of-the-art technology, Reedy is proud to introduce reliable and powerful 7.4V 20C Li-Po battery packs designed specifically for use in R/C cars and trucks. A unique hard case design helps protects the battery from damage. Integrated locking nubs simulate sub-c cell profiles to allow the battery to be easily installed in slotted touring car chassis. By simply flipping the battery over, perfect installation in off-road vehicles is achieved. Reedy makes available a choice of two capacities to suit enthusiasts’ application and budget requirements. Both come equipped with 14AWG silicone wire and a Tamiya® style connector. The 5000mAh Pro model comes equipped with 12AWG wire only so that the user can install his favorite plug. Reedy Li-Po batteries offer many advantages over traditional Ni-MH batteries:
* Exclusive case design helps protect the battery from damage while allowing easy installation in touring car and off-road chassis
* Up to 30% longer runtime than NiMH batteries of equal capacity
* Lighter than Ni-MH batteries of equal capacity
* No limit to the number of consecutive uses
* Improved cell efficiency results in less energy lost as heat and greater power output
* Battery can be charged well in advance of use with no loss in performance
* Reduced maintenance
* Longer lifespan (up to 10 times!) reduces battery costs
* Balancing connector included - no complicated wiring required!
Specifications:
3200mAh
Length: 139mm
Width: 46mm
Height: 23.1mm excluding nubs /25.1mm including nubs
Weight: 198g
Discharge: 64A continuous, 80A-128A burst
Passes UN T1-T8 testing
5000mAh
Length: 139mm
Width: 46mm
Weight: 265g
Discharge: 100A continuous, 125A-175A burst
Passes UN T1-T8 testing”
k£v!n is offline   Reply With Quote
Old 03-11-2008, 03:54 PM   #2
nice batteries.. but the lead is on the wrong side.
Sabin is offline   Reply With Quote
Old 03-11-2008, 03:57 PM   #3
Yay! An actual picture. If the leads exit the case out the top (bottom?) they'll work for me. Well, maybe not, if it has the "bumps"
This is the OG thread, fwiw.
http://rctech.net/forum/showthread.p...ighlight=reedy
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 03-11-2008, 04:14 PM   #4
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
its doesnt matter what side the leads are on cause if you dont like it you can flip it over and not use the cell bumps, and bamn its just like any other lipo
Presto !!
wallstreet is offline   Reply With Quote
Old 03-11-2008, 04:17 PM   #5
wallstreet's Avatar
And with the wires coming out where they do and you dont use the cell numbs its actualy optimal for any car as the leads(wires) will never interfear with any bulkheads or battery straps so you will never have to try and fish your speedo wires through bulkheads and or battery straps.
Old 03-11-2008, 05:43 PM   #6
Presto !!
yea that would work. but then what's the point of having the nubs in there if you're just gonna flip it over? CF chassis probably won't be a problem but it might interfere with installing into a tub chassis.
Old 03-11-2008, 06:37 PM   #7
wallstreet's Avatar
added bonus
"nubbed" for your pleasure
Old 03-11-2008, 07:02 PM   #8
Verndog's Avatar
Trader Rating: 16 (100%+)
Coming out the end is better then the side IMO. More options and generally more clearance. Why do you say wrong side? Thats the same side you would solder a NiMh on in a sedan. With the exit location on end, I think offering a top exit and bottom exit option would be a smart idea though.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 03-12-2008, 05:09 AM   #9
yea. the connectors usually point straight up. The big reason why I said that is because I think it might interfere with mounting.
Now, had they ran the leads straight up like a NIMH pack, there'd be no problem. This.. i'm a little concerned about.
Old 03-12-2008, 10:41 AM   #10
Tech Legend
Wild Cherry's Avatar
As please as I`v been with my year old Carbon`s 3200, I`m replacing um with the Reedy Li-Po....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Reedy 7.4V 20C LiPo Battery Packs k£v!n Radio and Electronics 5 01-30-2008 09:13 AM
REEDY GP3300 Battery Lot! Five (5) Six-cell packs!! StickyFingaz R/C Items: For Sale/Trade 4 09-05-2007 11:14 PM
Reedy matched GP3300 battery packs w/ case SA22C'ya R/C Items: For Sale/Trade 4 01-22-2007 04:40 PM
5 Matched Reedy Battery Packs for $50 Shipped!! SA22C'ya R/C Items: For Sale/Trade 9 10-09-2006 10:17 PM
New REEDY Battery Packs + MORE ewaleson R/C Items: For Sale/Trade 2 01-26-2003 09:50 PM
