Old 07-11-2003, 04:18 AM   #1
Default Tread Pattern Rubber tyres???
Hello fellow enthusiasts,
I was just curious if anyone uses rubber tyres with tread pattern on them like the Proline V-Rage, Fury etc..
I see these tyres in the shops but I have not noticed anyone using them.
I would like to know what is their application and on what surfaces are they good on. Does anyone out there use them??
Look forward to your Input.
CustomfibreR/C is offline   Reply With Quote
Old 07-11-2003, 03:27 PM   #2
X
XX
XXX
XXXX
XXXXX
XXX
XXX
XXX
XXX
ANYONE??????
Old 07-11-2003, 03:49 PM   #3
Herminator's Avatar
Send a message via ICQ to Herminator
Treaded tyres are rarely used by anyone that races, they're more for people who just run in the street or for show. If you're racing you're going to want to use racing tyres which means slicks. Although if it gets wet there are some tyres that work and have tread, but there are also slicks that work in the wet
The only treaded tyres I like are Pit Schumizu D20 24mm treaded tyres, they work very well in the wet and even when greasey, which is normaly a time most tyres strugle. I also like CS22's for the wet but in the greasey stage they can strugle a bit.
Herminator is offline   Reply With Quote
Old 07-11-2003, 03:57 PM   #4
Hmmm,
I thought this might be the case. Same scenario as real racing cars...
Rubber Tyres Birky Rookie Zone 16 06-13-2013 05:01 PM
Tread pattern? R40Victim Nitro Off-Road 11 03-12-2008 09:20 PM
New to Rubber Tyres Rody Electric On-Road 7 08-21-2005 02:21 AM
Foam tyres or rubber tyres at IFMAR? habicht Electric On-Road 1 06-16-2005 11:02 AM
HPI rubber tyres new or used penggoy R/C Items: Wanted to Buy 1 05-02-2003 04:51 PM
