Old 03-09-2008, 07:18 PM   #1
Dorikin's Avatar
Default TRF415 Lipo Fitment
Can anybody here reccomend a large lipo that will fit into the 415 without any fitment issues (ie no grinding bulkhead etc) without stick deck?
I know that orion 3200's hard case shouldnt be a prob but something larger would be more suitable for longer run-times, this is not for race car btw...
Cheers
Dorikin is offline   Reply With Quote
Old 03-09-2008, 07:24 PM   #2
JimmyMac's Avatar
Try posting in the 415 thread. Also post what version 415 you have. That makes a huge difference as well... But look to the 415 thread first....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-09-2008, 08:08 PM   #3
Dorikin's Avatar
TRF415MSX & MSXX
Figured here there would be more precise answers. Not to mention good thread for future reference. Couldnt find anything specifically relating to this.
Old 03-09-2008, 08:53 PM   #4
Trader Rating: 26 (100%+)
the orion 3200 does not fit in the 415 msx without grinding a bit
eddie10 is offline   Reply With Quote
Old 03-09-2008, 09:25 PM   #5
Travis S's Avatar
Trader Rating: 46 (100%+)
I have an MSX with the MSXX stick pack conversion kit. With the stick pack kit it should fit any lipos that are under 21mm tall. You should be able to get the L,W,H of a pack on the net.
I am not sure of any lipos that you can run without grinding that bulkhead or getting that stick pack kit.
Travis S is offline   Reply With Quote
Old 03-09-2008, 09:52 PM   #6
Dorikin's Avatar
Ah thanks for the answers. Well the MSX ive got now and an MSXX is on its way. Havnt actually compared the two next to eachother yet...
How about the non cased lipos?
Is there any possibility of squeezing them under the bulkhead without grinding it?
Old 03-09-2008, 10:07 PM   #7
Travis S's Avatar
I am guessing it would need to be another 2mm shorter so 19mm or maybe 20mm tall tops.
Old 03-10-2008, 08:27 PM   #8
secretsg's Avatar
Orion should have put the plugs on the other side of the pack. You can squeeze in a 3200 upside down on a MRE chassis. I'm guessing the yeah racing lipo packs with the stick pack style wires should work. I'll be ordering some to find out
secretsg is offline   Reply With Quote
Old 03-10-2008, 09:46 PM   #9
larrio's Avatar
MRE here with the Orion 3200 lipo. I had to grind down a small portion of the aluminum bulkhead. Nothing else will fit in the Orion lipo series (or most other hardcased batteries for that matter).
larrio is offline   Reply With Quote
Old 03-11-2008, 09:47 AM   #10
PutAwayWet's Avatar
The standard MSXX is pretty much softcase-only for lipos. Even grinding away the scallop won't open up many options. But with a PPD plate, a softcase 5000 like the MaxAmps, and a bit of lead bullion, you can make it work. Provided, of course, you're permitted to run softcases at your track.
Otherwise just get the stick pack conversion, which is a good move anyway, as the 2.5mm lower deck renders the chassis hugely more resistant to tweaking. With the conversion your battery options open up greatly.
PutAwayWet is offline   Reply With Quote
Old 03-11-2008, 11:26 AM   #11
mkdut's Avatar
Trader Rating: 19 (100%+)
Even with the Maxamps softcase 5000 you may need to grind away a little of the bulkhead. It will fit with 1 mm or so to spare but a hard crash if the battery is not secured well could force the battery into the bulkhead. Additionally you might need to use a shorter screw on the top deck on that battery side.
mkdut is offline   Reply With Quote
Old 03-13-2008, 07:38 PM   #12
Dorikin's Avatar
The Orion 4800 platinum has same height as the 3200 orion hardcase... both are 23mm which may be appx 1mm too much from what I can see if the bulkhead is ground down. Option though, would there be any possibility to maybe remove some of the hard casing in that area to accomodate for the 1mm
I doubt there would be any danger to exposing that area of the lipo in case of a crash. But fitment issues might still occur.
Taken from Orion website... what you guys think?
Dimensions 3200mAh:
Length - 137.5mm
Width - 46.7mm (17.5mm radius sides to emulate stick pack shape)
Height - 23mm (20.5mm height between bumps)
Weight - 198g (6.6 oz.)
True 20C
Platinum 4800mAh:
Length - 137.5mm
Width - 47mm
Height - 23mm
Weight - 258g (9.1 oz.)
True 15C
Old 03-13-2008, 08:16 PM   #13
Travis S's Avatar
The Orion 4800 platinum has same height as the 3200 orion hardcase... both are 23mm which may be appx 1mm too much from what I can see if the bulkhead is ground down. Option though, would there be any possibility to maybe remove some of the hard casing in that area to accommodate for the 1mm
Dimensions 3200mAh:
Length - 137.5mm
True 20C
Platinum 4800mAh:
Length - 137.5mm
Width - 47mm
Height - 23mm
True 15C
The 3200 has the cell humps and that measurement is from the bottom of one of the humps to the top (The humps sit into cell slots making the top of the lipo about 2-3mm lower then a 4800 that sits flat on top of your chassis because it doesn't have the humps.
I had the TRF415 MSX with and without stick pack kit. The issue is not just the rear bulkhead but the bigger issue is the center post. AKA BN6 on page 8 http://www.tamiyausa.com/pdf/manuals/49381ml.pdf or part # 3454351. This is what caused the no fitment for Orion 4800. The bulkhead clears fine but the pack would hit this. Both stock and stickpack conversion.
I have no idea if you could grind the case down and I wouldn't want to try it. I would just find something under 21mm and stick with that.
TrueRC Lipo 10C and 15C 8000mah Lipo Fitment in RC10T4 or XXXTCR Cain Electric Off-Road 2 09-09-2008 08:14 PM
LiPo fitment thread academygaz Electric On-Road 44 09-06-2008 12:13 PM
What 2wd buggies have no issues with lipo fitment Cain Electric Off-Road 17 01-03-2008 09:17 PM
Mini t and 11.1 lipo fitment ?? Gen Micro and Mini Scales 2 11-08-2007 05:38 PM
FS: Tamiya TRF415 MSX MRE, Trakpower 4900 LIPO, Werks Clutch for Revo/T-maxx secretsg R/C Items: For Sale/Trade 3 10-14-2007 04:59 PM
