Old 03-09-2008, 12:28 PM   #1
Exclamation Please help!.
Ive got a TT-01D chassis mazda rx 7, and ive got all the items you need like receiver transmitter etc. ive got everything in the right place but my teu 101 bk e.s.c keeps flashing red when i turn on the car. Ive tried to set it to my transmitter but it dosent work. please reply with help. thanks.
jasono is offline   Reply With Quote
Old 03-09-2008, 12:37 PM   #2
Skitee's Avatar
You said you've connecte everything but just in case...
You need to plug the red plug from the ESC into the battery port on the receiver, if you don't then the ESC won't respond.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 03-09-2008, 12:53 PM   #3
ye i have done that but i still get an alarm and red flashing lights
Old 03-09-2008, 01:52 PM   #4
Default please help!.
ive got an acoms 2 channel receiver. are these wires in the right place ?
steering servo = CH.1
e.s.c (white/red/black wire) = CH.2
e.s.c (black/red wire) = BATT
Old 03-09-2008, 02:51 PM   #5
Skitee's Avatar
Ok. Yes that sounds right. If you're sure you have the polarity correct on those channels. Have you set the ESC yet ? It isn't setup at all when you power it up the first time. The instruction maual does cover the setup procedure. Make sure that your radio is switched on and that the crystals you're using are working.
Old 03-09-2008, 03:03 PM   #6
Smile reply
thanks, but i have also tried to set up my esc but it doesnt work. the only thing i see as a problem is that both my receiver and transmitter and a crystal band 1, but whalst on the box i ordered it from shown that the transmitter had a cryastal band 2 and receiver band 1. Ive followed the instuctions on setting the esc and ive done all it told me to like press set whalst full throttling and full reversing. it says that after you full reverse and press switch that the alarm and flashing stops and that the set up is complete but it dosnt stop for me so the set up cant complete.
Thanks for helping
Old 03-09-2008, 03:04 PM   #7
Default .
oh by the way, how do i know if the crystals are working ??
Old 03-09-2008, 03:19 PM   #8
Skitee's Avatar
If you only have that one set of crystals it makes it more difficult to check. Most of teh time crystals are marked RX for receivers and TX for transmitters, check that you have the correct crystal in the right place. While you're at it make sure that both crystals are marked with the same frequency.
When you're speaking of pushing the switch I assume you're talking about the set button on the ESC and not the power switch.
Old 03-09-2008, 04:19 PM   #9
Default .
both crystals are band 1 and ye its the set button on the esc tht im pressing but nothing happens, i still just get an alarm and repeatable red flashing lights
