Advices on tb01
#61
TB01 or TA04
for onroad, i would choose the TA04R. i think it has the most hopups for the money - ball diffs, aluminum threaded shocks, full ball bearings, universals, molded graphite chassis (not sure on this), graphite upper brace, aluminum motor heatsink, nice rims, belted tires & molded inserts. you dont have to add much for it to be race worthy. in our lhs, the TA04R is about twice as expensive as the TB01. but to equal the TA04R's equipment would mean buying lots of hopups - in the end, the TB01 will be more expensive than the TA04R.
however, if you will be running in dirty tracks, the TB01 has the advantage of a sealed drivetrain. In our local asphalt track (very deteriorated and unmaintained), where we run rally every week, a TA04R or any other open belt driven car will have pebbles stuck in its gears and pulleys. hope this helps
#62
Originally posted by blixelX
just wanna check out what is mod motor... coz i was thought that those motors come with the chassis is called stock motor and those selling outside with lower turns are mod motors... then read some threads that said that those 23T oso a stock motors...
Mabuchi RS540SH kit motor is a 27turn, 0 degree timing motor.
(more +ve timing gives more power for the same motor, but sucks more current)
Any "ROAR Stock" (ROAR is an American RC racing association) motor is 27turn with 24 degree FIXED timing, with bushings. Newer motors are Rebuildable ie you can take them apart for servicing, but you cannot change parts or the timing without making it very obvious.
Then you have the Japan-stock... a pretty recent invention, they are 23turn fixed timing. However Japan does not allow rebuildable motors for racing! You can buy rebuildable 23turn stockers, but they are illegal for Japan stock racing. Japan also requires stick batteries *only*, and they must be commercially-manufactured ones, not DIY.
Anything that is outside of that... is "Modified".
Most mods will allow timing change, most run ballbearings.
All mods should allow disassembly for servicing.
Roughly speaking...
16+ turn = mild Mod
10-15 turn = pretty hot Mod
under 10 turn = super hot Mod
#63
thz WC... may try to get 23T motor, since many ppl using it and very good review on it... may get a tamiya for first try coz using tamiya chassis... haha... which 1 is good?? type R, T, S, SS??
#64
Re: TB01 or TA04
Originally posted by marvi
....aluminum threaded shocks,
....full ball bearings, universals,
....molded graphite chassis (not sure on this)
Shocks... the earlier TA04Rs had "TRF shocks" (58276 HKS TRB001 Altezza, 58282 TA04-R Chassis Kit, 58291 HKS CLK).
The latest one (58297 RaybrigNSX 2002) has the fluorine-coated ones.
Tamiya's alloy shocks are the best in the business!
04R has full ball bearings... but they're all only metal-shielded.
The TA04PRO comes with full set of Tamiya's blue-sealed ones.
in our lhs, the TA04R is about twice as expensive as the TB01. but to equal the TA04R's equipment would mean buying lots of hopups...B]
That is always the case...
For my runner, I made the move to 04 with the PRO before the 04R came out. It has gradually collected most of the hopups to R spec. Would have saved some $$$ by just getting a 04R and putting a carbon chassis on that, but too late for that - no regrets anyway. TA04 is a great chassis design.
There is also the TA04-TRF with everything you could want...
... and very soon, there's also TRF's TA04R Tuned Chassis Kit!!
...buying lots of hopups - in the end, the TB01 will be more expensive than the TA04R.
Enjoy the TB01 for what it is... try resist putting on too many eye-candy options on it and save the $$$ towards your next car. My TB01 (NSX2000) only has bearings on it (ok, it comes standard with the aluminium shaft & plastic gears - save 130g!!). It really does not need anything more.
#65
saw 72T and 88T spur gears that for TB01... r these really suitable for tb01?? from the manual it just show 61T, 58T, & 55T, whats the pinion size will fit the 72T and 88T spur gear??
#66
The original spur gears are 0.6 pitch, whilst the 78 and 88 tooth spur gears are 0.4 pitch. The latter are smoother running (but not suitable for rally as they can get chewed up quickly from vibrations and dirt and stones getting stuck in the spur gear). To switch from 0.6 to 0.4, you are going to need new pinion gears too which are also 0.4 (or 64 pitch).
#67
any1 try the 0.4 pitch spur gear and pinion on a TB01 b4?? how many T pinion is suitable for a 0.4 pitch 78T spur gear??
will it (0.4 pitch) run smoother than 0.6 pitch spur gear?? when using 0.4 pitch, will it consumes more power (battery drains faster)?
#68
is the gear ratio formula for 0.4 pitch same as the 0.6 pitch??
The actual numbers might change, but we all know 10/2 = 15/3
They can be used on the TB01 only if you get the alloy motor mount.
The plastic motor mount with A/B/C/D will not support 0.4 gears.
will it (0.4 pitch) run smoother than 0.6 pitch spur gear?? when using 0.4 pitch, will it consumes more power (battery drains faster)? [/B]
It should use/lose LESS energy (noise = energy).
But I doubt if you will notice the difference.
However, 0.4 gears have smaller teeth (= more fragile to stones etc) and where the gears are, they will be damned difficult to get the mesh right. Smaller teeth make proper meshing even more important, and harder.
Don't forget that you have to lose the A/B/C/D system to adjust gearmesh, and it will be totally up to you. Too tight or too lose will both destroy the gears.
Personally, don't bother with 0.4 gears - larger gears work just fine for me. Even on TA04PRO/EvoIII, can convert them to larger teeth gear rather than stick with the tiny fragile 0.4 gears.
#69
thz WC... ur explaination is very clear... nice... learnt something today...
yah, i noticed that belt may use a bigger pinion and spur gear compared to shaft... am i correct??
#70
(I say 'usually', have run a older Yokomo YR4M2 whose layshaft is in front of the motor...)
Unfortunately, for bigger spur, you need bigger pinions to get the same high gearing ratios...
With TA04, the only spur available in AV is the 87t... which is pretty big and no good if you want any ratio higher than ~6:1. For that you gotta use 3rd party gears, and the TA04 is good in that it can directly accept "industry standard" spurs.
Do note there are metric & imperial standards...
--- 0.4 & 0.6 "module" gears are Metric.
--- 48dp & 64dp "pitch" are Imperial.
They should not be intermixed, you'll cause meshing problems.
#71
Originally posted by WC
Belt cars usually have the layshaft up top so yeah, there's usually more room for a bigger spur. Whereas the TBs put their spur on the centre shaft, so you haven't got much space to play with.
man, get prepared, sure hav lots of question to ask u in the future... haha...lol... thz man...
#72
hey man, any reccomendation for a tamiya type R in a tb01?? whats the gear ratio should be used? any hop up should be added to make it more stable??
#73
Personally, I don't recommend using a Type R in a TB-01. Last time I tried one of these motors, it burnt out after 6 runs. If you have already bought one, I suggest keeping the ratio between 6 to 6.5. I have found the Type T to be the most durable.
#74
yah, just knew that there r brushes in the motor, how i know when the brushes need to be replace? do i need to take it out and check monthly or weekly? can i notice without un-screw the motor?
#75
Don't bother changing unless your motor performance has dropped a lot, or maybe the brush is more than 30-40% gone (ie only 60-70% remaining). If your brush turns *blue* it means it is overheated, but this shouldn't happen unless you've overgeared it badly and really cooked it.
You should check the brushes every so often, maybe every 10-20 packs? Check both brushes, not just 1. You probably have to take motor out of the car, most cars don't have enough space around motor and TB01 is one of worst for that.
Personally... don't worry too much about the brushes, they'll look after themselves.
Worry more about Lubrication.
Yeah, you need to keep those motor bushings OILed!!
Every 2-3 runs, you should oil the bushings.
Use a thin oil, like your mum's Singer sewing machine oil.
You can buy "special" bushing oil too, but who's kidding who?
(Do NOT use silicone shock oil as lubrication.)
Next time you're at Hobby Shop, ask also about "Motor Spray".
