Old 07-08-2003, 07:01 PM   #1
Default REduce voltage
i have a puwer supply that suppose to have an output of 12v/7amp but when i connects it to a charger it said the output is at around 16-16 volt, not sure how much current it have. Anyway i want to reduce the voltage to about 12-13 volt so i can use it with my charger.
Does anyone know a cheap way of doing this ? i prefer to buy a device that is already design to do this...
zoombie is offline   Reply With Quote
Old 07-09-2003, 05:26 AM   #2
ohh come one..some one plz help/////
Old 07-09-2003, 06:11 AM   #3
sosidge's Avatar
Sounds like you have a low-quality power supply. A quality regulated 12v supply will normally put out either 12v or 13.8v - 16 is way over. All I can suggest is returning your supply, or buying a better one.
Old 07-09-2003, 09:55 AM   #4
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
but there has to be a way to down your voltage
if there's a way to make it go higher like a comp supply. you use resistors.
Calvin Ng is offline   Reply With Quote
Old 07-09-2003, 05:47 PM   #5
hehehe...thats not a cheap solutions
Old 07-09-2003, 05:56 PM   #6
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You should be able to adjust the voltage, open it up and see if there is anything you can adjust it with underneath the casing. I used to use a 5 dollar 4 volt 20 amp power supply for powering my lathes (wish I could find another one, they were nice, and cheap) but even on that I could adjust the voltage a bit, and it was as cheap as you can get.
Old 07-09-2003, 06:06 PM   #7
nah...nothing to reduce the voltage..its fix..i know there is such a thing call voltage reggulator but dont know how to use it...
Old 07-09-2003, 06:12 PM   #8
Send a message via AIM to Johnnytc3
you prolly have a bad IC chip, this is what regulates the voltage to consistent levels, or you might have some bad pass transistors(which i doubt bc the voltage drops when you apply a load if it is bad). Anyhow, if you have a volt meter you can open it up and test each component, IC, Capacitors, etc... just be careful, if you kill yourself its not my fault.
Johnnytc3 is offline   Reply With Quote
Old 07-09-2003, 06:20 PM   #9
thats going to be a bit hard to do since i dont know wat each component does wat...and i'm not going to die trying
NiCD/NiMH Voltage vs Lipo Voltage bryanleec Radio and Electronics 10 02-06-2008 06:08 PM
Any way to recondition packs to reduce resistance? glitchy Electric Off-Road 4 11-27-2007 12:48 PM
RC 18 T for sale and price reduce for All my RC Trade_EZY Malaysian R/C Racers 7 07-20-2006 08:18 AM
RC 18 T for sale and price reduce for All my RC Trade_EZY Singapore R/C Racers 0 07-18-2006 08:53 AM
how do I reduce the push on my tourer? jsmenna Rookie Zone 13 02-18-2003 11:04 PM
