Old 03-04-2008, 07:14 AM   #16
rhammer's Avatar
Default Weller
I own a weller 40 watt. Either that or the 80 watt version. You have to be careful though with the higher wattage that you don't get the cells too hot. It is easy to damage them by over heating.
rhammer is offline   Reply With Quote
Old 03-04-2008, 07:46 AM   #17
Originally Posted by hobbipro View Post
Where are you buying these Hakko from? I'm on my 3rd weller now because no one carries the replacement tips anymore, and yes, they pit and fall apart quickly. There was an electronics store, but it closed up shop last year, the only thing left is radio shack.
Ace Hardware stores usually carry the replacement tips for the 40W Weller iron. They're around $9 - $10 a pair.
AreCee is offline   Reply With Quote
Old 03-04-2008, 07:56 AM   #18
EricW's Avatar
Why play games, just use a
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 03-04-2008, 07:56 AM   #19
chicagokenji's Avatar
Home Depot sometimes has the 40 watt tip replacements. Last time I bought 3 of them, 6 months ago. About 4 bucks each.
chicagokenji is offline   Reply With Quote
Old 03-04-2008, 08:23 AM   #20
timmay70's Avatar
This is why to use the 80w fattie. If you prep all your cells at once (I sand the ends with 220 grit and pre-tin), then dip the ends of the battery bars in flux, the soldering operation time total for each bar should be around 1.5 - 2 seconds per joint, max.
As with all soldering operations, a clean tip goes a long way. Keep a moist sponge near by to wipe it off between operations. The weller tips nickel coating is not that thick, but with a little care their life can be extended. I had one last 4 months before it started to get pitted. By contrast, I've had the tip on my Hakko for 2.5 years and it's as good as new. It may be more expensive, but you do get what you pay for...
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 03-04-2008, 03:12 PM   #21
RCpurplecow's Avatar
so I take it this is the one I should get.
Weller 80 Watt
http://www.amazon.com/Weller-80-Watt...4668632&sr=8-1
thanks
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 03-04-2008, 05:31 PM   #22
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Yep that will do the job. I am using a weller 100w. Remember You are always better of using large amount of heat for short amounts of time rather then holding a small amount of heat for a long time.
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 03-04-2008, 06:19 PM   #23
tpczx6's Avatar
been using this for a few years and help on saving the tip snice I can turn down the heat.
http://www.amazon.com/Weller-WLC100-...04679755&sr=1-
I also have an 80w weller fo when I going to do more then one pack I just plug it into the station and use it.
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 03-04-2008, 07:34 PM   #24
C_O_jones's Avatar
Frys.com HAKKO 936 for $89.95
Frys has stores all over.
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 03-04-2008, 08:23 PM   #25
ta_man's Avatar
Trader Rating: 151 (100%+)
Haven't seen anyone mention the weller 4033S. This is a iron plated 45W unit with an 1100 degree F tip temperature. It has a 3/8" or so chisel tip and will solder a battery bar in a second or so. The tip is about $29 but it needs a separate handle.
They do die eventually - I think I am on my second one since starting in RC about 6 years ago. The iron plated tip doesn't wear or corrode - the heater just deteriorates and eventually it doesn't get as hot as it used to. I don't leave it on all the time. I just use it for soldering stuff and unplug it. You can get them from Mouser electronics www.mouser.com
ta_man is offline   Reply With Quote
Old 03-04-2008, 08:36 PM   #26
The monster 80watt Weller used in the stained glass hobby definitely puts out the heat but the tip is to big. I wish it came with a tip about 2/3rd's the size.
My Hakko 936 has been good over the years but doesn't hold the heat like it used to. I've been thinking about ordering a new one. Maybe next winter.
kcobra is offline   Reply With Quote
Old 03-04-2008, 08:51 PM   #27
SpidarX's Avatar
I just had to get a replacement tip for my 40 watt weller. I had my local hobby town order it. For those looking for replacement tips for the 40 watt weller, the tip is an MT10. Also, I know that Ace hardware can order weller tips.
SpidarX is offline   Reply With Quote
Old 03-04-2008, 09:19 PM   #28
glassdoctor's Avatar
Just a heads up on the Hakko... they have them pretty cheap on their site, only $93 for the one with the big iron. THat must have changed because it used to be hard to find them for under $100
and check this out: they even have "skins" for it. Seems that Hakko likes the r/c market.
http://www.hakkousa.com/AHPDirect/images/936-skins2.jpg
glassdoctor is offline   Reply With Quote
Old 03-07-2008, 01:17 AM   #29
totalazneclipse's Avatar
Trader Rating: 15 (100%+)
The shop I go to said that the guys they get the hakko from is back ordered >.< . But for now just for batteries, I guess Im going to pick up a weller 80 watt and hope nothing little comes unsoldered until i get my hakko.
As far as the weller 40 watt tips go, around my area they're like $9-10 if you can find them. Sadly, a new iron with the large tip and the two others is like $20.
Everyone says to go with the Hakko, they really must be doing something right
All Speed Hobbies
www.allspeedhobbies.com
totalazneclipse is offline   Reply With Quote
Old 03-07-2008, 08:28 AM   #30
Scottrik's Avatar
Trader Rating: 245 (100%+)
I've got two of the Hakko 936's (one in my race kit, one on my bench) and there really is nothing like 'em...except I DO employ an 80 watt Weller (from Home Depot) for batteries. The 936-108 with the 5mm tip works pretty good on batteries and I'll use it in a pinch to repair a pack for someone, etc but the Weller is the ONLY way to fly for assembling a pack or five (or six, or...). That tip holds a LOT of heat.
Originally Posted by todd8603 View Post
Stained glass hobbyists apparently pay less than us. $100 for this item in hobby shops and $80 in stained glass supply houses. $20 savings not much but 20% in my pocket is preferable to me.
Yeah? When does your local stained glass supply house schedule races?
With the 80W Weller, properly tinned, you just touch the iron to the bar and it floats on almost instantly. If you hold the iron on the cell 2 seconds you're doing something wrong. Much closer to a second.
Ace can also order the monster tip for the 80W. It is in their supply catalog but most stores don't stock it. I just picked one up there last fall.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Best Soldering Iron? snoopyrc Radio and Electronics 30 11-21-2010 10:52 PM
Soldering Iron wallstreet Electric On-Road 3 04-08-2005 08:19 AM
Soldering Iron Flash-R.C. Electric On-Road 10 01-30-2005 05:31 PM
soldering iron help! centax error! Electric On-Road 17 03-15-2004 08:56 AM
Soldering iron over gear Electric On-Road 17 11-28-2002 08:51 PM
