Old 07-05-2003, 07:34 AM   #1
Default Brushless run times
Hi Gang
I have been outa this for a while but used to run a F1 and a what they are calling a vintage RC10 . What would the approx run time be on a brushless setup and how much of a bearing would battery choice have on the ruun times?
I am running a 4tec right now with a 10 turn double on a cyclone speed control and 2400 battery sticks and am only getting about 2.5 min run time. Any suggestions without spending a wad on batteries of how to get a longer run time?
I know this isisnt a brushless system now but why upgrade is another thing im looking at
Jeff
Stang 69 is offline   Reply With Quote
Old 07-05-2003, 11:07 AM   #2
RC4SALE's Avatar
WHAT IS YOUR ROOL OUT...PINION,SPUR,& TIRE SIZE..?
MOTOR TEMP AFTER A RUN?
RC4SALE is offline   Reply With Quote
Old 07-05-2003, 05:35 PM   #3
I wanna say my spur gear is 48 and the pinion gear is 24 tre size im not sure of and motor is semi warm as far as exact temp goes im not sure.
Sorry so vauge but im still fairly new hehehe
Jeff
Old 07-05-2003, 06:16 PM   #4
your problems are----
1. TOOOOO tall on the pinion, it comes geared at 24 (pinion) /81 (spur) and this is for it's wimpy 20 turn motor
2. To much drivetrain drag, this is one thing on the car that will be hard to fix because the belts are absolutely way too stiff.
3. Your motor is worn out and needs rebuilt.
4. Your batteries aren't getting fully charged.
If you go out and get a brushless system you will only fix one of these problems......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 07-05-2003, 10:38 PM   #5
This is possiable I have a peak charger coming this week
motor is new and has less than 5 runs on it was broken in witht eh water like directions state
I dont think this is it because i got longer run times with a 15 turn
What gearing would you suggest?
Jef
Old 07-05-2003, 11:07 PM   #6
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Soak your belts in rubbing alcohol overnight, it will soften them up quite a bit. Used to have to do that with my XX4 Street Weapon because of how tight the drivetrain was.
Old 07-06-2003, 08:27 PM   #7
Probably between 18-20....
Old 07-06-2003, 10:08 PM   #8
Ok I will try the 18 to 20 pinion gear and let ya all know. Thanks for you patients with this old newbie
Jeff
F/S Mini LST2 w/ LiPo & Brushless Run 3 times!! Ephidelt490 R/C Items: For Sale/Trade 13 08-12-2008 06:29 PM
brushless run times spudly12 Electric Off-Road 5 04-25-2008 08:39 AM
Novak XBR/13.5 brushless system used 4 times $135.00 shipped vintagetamiya R/C Items: For Sale/Trade 4 04-18-2008 08:54 AM
Brushless Run Times? Drift_Buggy Micro and Mini Scales 3 01-12-2007 10:02 PM
run times h22ah Electric On-Road 13 04-15-2004 05:21 PM
