Bearing maintance >
Bearing maintance
Bearing maintance
Old 07-03-2003, 09:05 PM
OHBRAD's Avatar
Trader Rating: 19 (100%+)
Default Bearing maintance
Hi guys,
this how i have been looking after my bearing, please list other possible ways. Every 3 rd meeting i have been removing all my bearings, removing their seals both sides and soak them in Shellite ( lighter fluid), i leave over night, wishthem around and drain, i then give then another soak with fresh shellite and repeat the process.
I take them out dry them replace one side of the seal and place 4 drops of trinty royal bearing oil and close the other side.
I have used products like wd40 before also. But i am interested to hear when and how you all look after your bearing, and are there better types of bearings to use.
OHBRAD is offline
Old 07-03-2003, 09:29 PM
hellangel's Avatar
after cleaning them, i prefer to pack my bearings wif a light grease rather than oil...
reason being i want them to last longer... less wear... longer intervals between maintainence...
i lose out a bit on acceleration and top speed but it's very minimal...
hellangel is offline
Old 07-03-2003, 09:41 PM
fatdoggy's Avatar
I just remove the seals, blast them with motor spray, spin then and continue the process till they spin freely, then a drop or two of royal oil, wack the seals back on and you good to go. Light grease it to thick and if your a racer forget it. Another thing is that trinity ball bearing oil is also thicker so use royal oil for best results.
fatdoggy is offline
Old 07-03-2003, 09:55 PM
glide 1's Avatar
Default .
I take the seals off both sides, soak them in kerosene then blast them with a compressor. Do this twice then drop them into a bowl of methanol to clean, then drop a few drops of royal oil then blast again with compressor and let it spin using force of the air. You should here the bearing whine similar to a motor spooling up. I found that this is also a good test to see that the bearing is still ok... the higher the 'whine' the better the bearing. Re-oil then pop seals back in.
ps hold the bearing securely while blasting with comp. also aim the nossle on the balls at an angle to get it to spin...may need a little practice. Hope this helps
glide 1 is offline
Old 07-05-2003, 03:06 AM
Default bearings
I put dirty bearings in a plastic container (used to store films for cameras.)
I then blast them with WD 40.
Close the container, shake hard. You will see the amount of grime...
Remove the dirty oil, and reblast as necessary. The gritty feel must be gone.
I once used a very nice oil called break free (in the early 90's). Best oil I have ever used, but can no longer find it.
rccartips is offline
Old 07-05-2003, 04:08 AM
davioh's Avatar
i soak them in WD-40 and then drop some trinty royal oil and turn it a bit and drop another drop in
davioh is offline
Old 07-05-2003, 06:12 PM
Default Re: bearings
Break Free is used mainly for cleaning guns. You can find it at any gun shop or some sporting goods stores.
Headbanger is offline
Old 07-05-2003, 06:36 PM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I work with this stuffevery day in the military..on the Airplanes that I work on we have 5 gallon containers of it
-Dave
JDM_DOHC_SiR is offline
Old 07-05-2003, 07:08 PM
How do you get the seals off the bearings? I dont really take great care of my bearings and would like to know how to matenience them properly so I dont have to replace them as often. Would soaking them in denatured alcohol work once I get the seals off?
AE Racer is offline
Old 07-06-2003, 04:07 PM
GTMilenko's Avatar
hey guys, i've got a set of squat "ultimate dry bearings"
because they are dry, does this meen i don't need to lube them?
thanks for your help
GTMilenko is offline
Old 07-06-2003, 05:11 PM
Korey Harbke's Avatar
There should be a very thin retaining clip that holds the seal in. Just take an Xacto knife and try and pick it out. Then just spray the bearing out and re lube it with light oil and go run the car.
-Sushi Boy
Korey Harbke is offline
Old 07-06-2003, 05:15 PM
StephenSobottka's Avatar
I take the seals off my bearing and put them into an ultrasonic cleaner. i then spray off with 100% alch and relube them with sonic drops from hurricane
StephenSobottka is offline
Old 07-06-2003, 05:19 PM
Man those are some good bearings! were did you get them from ...I have a set in my CUda right now and I love them to death!! als they only need a small drop of Royal Oil... to get the most from them
-Dave
Old 07-06-2003, 06:19 PM
xxxtracer32's Avatar
on some bearings that have only a seal that can be removed on one side and a the other side i metal how would you clean those?
just remove one side and blast away?
xxxtracer32 is offline
Old 07-06-2003, 06:35 PM
yep u got it
