removing glue?
ok i was rushing to glue up some sorex 36s for a qualifier and i went over board with glue and some dripples down the tire over the contact patch. my qestion is can i remove this with acetone? will it eventually scrub off the tire? or should i throw away the tires and try again?
cheers |
my self i would not use acetone as its harsh and some rims like sorex get eaten by it. ( or used to when i ran rubber). i would go to your local hobby shop. if they carry BSI or MERCURY ADHISIVES they have a debonder that you can use. leave it sit on the glue for about 10 min and it will wipr right off
YOU CAN USE MY "BRAND NEW" SOLDERING TIP TO MELT IT OFF...! (RIGHT PAUL???):eek: :p :nod: :lol: J/K
I've done this before, getting a little glue on the contact patch. I just used a very fine grit sand paper or ideally emery cloth.
I've had this happen too. Just dip a rag in acetone and wipe the glue with it. The acetone will soften the glue and you should be able to remove a fair amount of it. After that just put the car on the track and run it to get rid of the rest.
Originally Posted by Swanny
(Post 4209730)
Originally Posted by tbeardmore
(Post 4209425)
