Old 02-26-2008, 12:04 PM   #1
Default Brushless Motor not working
hi everyone i have brought a gtb brushless esc with a 4.5 turn brushless motor and after all the programming i hae done i cant seem to get it to work properly it only seems to get pulses of power and sounds really rough, also the esc gets quite hot and the battery does also, what can i do ????
any help will be appreciated
thaks Jordan
jordan.norwood@ is offline   Reply With Quote
Old 02-26-2008, 01:59 PM   #2
tfrahm's Avatar
Send a message via AIM to tfrahm
This is a bit of a wild guess, but if you get the three power wires out of order on the motor, it will sound terrible and not "run"... Make sure you have them in the right sequence, etc...
Second thing -- make sure the sensor wires are not damaged and that the white plug is FULLY seated into the ESC's socket.
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 02-26-2008, 02:33 PM   #3
yep the wires are the right way round, then sensor wire does work as i have tried a different motor on it.
i just thought thier would be something i could do to the motor that is a quick fix??
Old 02-26-2008, 02:50 PM   #4
tfrahm's Avatar
Just about the only other thing (besides a defective motor) would be if the rotor wasn't shimmed properly -- if it can move too much in/out of the can, the sensors can have trouble determining rotor position/rotation, etc. and that can make the motor stutter, etc.. However, your problem sounds more severe than that...
You might try posting your problem in this thread -- Steve is a BIG help on brushless motors/issues:
http://www.rctech.net/forum/showthread.php?t=50964
Old 02-26-2008, 03:53 PM   #5
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
Start simple. Make sure the motor screws mounting the motor to car, are not too long..
ALBERTO is offline   Reply With Quote
Old 02-26-2008, 04:15 PM   #6
SWTour's Avatar
...make sure also no solder is bridged across the wires on the motor...and that the wires are not touching each other. (seen that happen on more than one occasion)
Does the ESC work with a different motor?
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Anybody heard if KO is working on a brushless esc? porschejim911 Electric On-Road 5 09-09-2007 04:40 AM
epic stock motor not working BADDMAN Electric Off-Road 2 04-15-2007 06:33 PM
WTB: Any Nitro Motor (Working) .12-.18 Feint Motion R/C Items: Wanted to Buy 2 05-30-2006 09:43 PM
New STS motor not working ScottishRacer Nitro On-Road 16 02-22-2004 01:14 PM
New STS motor not working ScottishRacer Rookie Zone 3 02-20-2004 05:56 PM
