Old 01-09-2003, 01:58 PM   #1411
rc-zombies's Avatar
Spec-V is only worth around $280.00+/- and are no longer available...for $480.00 they are selling the Hara Edition Kit.
If you're in the US and interested in a Hara Edition kit PM me.
Old 01-09-2003, 09:43 PM   #1412
lee82gx's Avatar
Default NO!!!!
there are currently 4 specs of Pro3
Spec S.Basic asian spec.dogbones+no turnbuckles
Spec R.US spec.CVD+turnbuckles
Spec V.Graphite chassis+turnbuckles+MANY options like front one way
ANDDDDDDDDDDD
HARA EDITION=fully upgraded=carbon fibre allround+titanium+aluminium+delrin diffs etc
specS is $130
Spec R is discontinued i think.
Spec V is >260
Hara $500.
Many of us dont think it's worth the $480 to get a Hara edition.
lee82gx is offline   Reply With Quote
Old 01-10-2003, 06:55 PM   #1413
SuperRooster's Avatar
Send a message via AIM to SuperRooster
anyone know of any good carpet setups if so post them the one im useing now i dont really like doesent stick to the carpet.
thanks
SuperRooster is offline   Reply With Quote
Old 01-11-2003, 06:30 AM   #1414
sosidge's Avatar
Default Carpet setup
Try this as a starting point...
Everything standard except
HB top deck fitted
Front
Jaco Blue foams
25mm Yellow springs (~390g/mm)
80wt shock oil
3deg caster block w/1mm spacer
Camber set to even wear (1-2deg)
Rear:
Jaco Blue foams
27mm Grey springs (~340g/mm)
60wt oil
HB 1deg toe in blocks (probably not necessary, but I couldn't be bothered to take them off)
May be worth trying a higher rear roll centre (camber link on upper hub carrier hole) if track is tight.
Old 01-11-2003, 07:00 AM   #1415
thanks anyone else
Old 01-11-2003, 02:14 PM   #1416
nozauta619's Avatar
Thumbs up thanks....
thanks sosidge...
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Old 01-12-2003, 03:20 AM   #1417
lee82gx's Avatar
Default Left front wheel wobbling
anyone notice that the front left wheel of the Pro3 wobbles?i think it's bcos of the amount of links (from knuckle to servo = 4) and the wobbling/shaking is thus 4 times that of the right side.at high speeds i find the wobbling a litlle worrisome.
Any tips to reduce it?Im using all stock except titanium turnbuckles.
Old 01-12-2003, 05:28 AM   #1418
sosidge's Avatar
A little play in the steering linkages is good - it helps the car run in a straight line.
If you want to cut down the play, you'll have to fit tighter ballcups - I think the RPM one's will fit on, if not you'll have to but a set with different balljoints as well.
Check your problem isn't wear or damage to the wheel bearings or components themselves.
Old 01-12-2003, 07:09 AM   #1419
lee82gx's Avatar
Right now it's a little.the wheel can wobble about 1 degree more than any other wheel from end to end(as viewed from the top).but im afraid it will end up like another Pro3 i have that is wobbling like mad at full throttle.front right wheel shows none of this.
I think i wanna try using the flanged-ball connection like the one used on the shock towers...is that a good option?
Old 01-12-2003, 08:31 AM   #1420
sosidge's Avatar
Those flanged balls are bulky, so may not fit, and not such a tight fit either (don't know what ends you would use on them anyway).
Old 01-12-2003, 08:45 AM   #1421
lee82gx's Avatar
havent tot of none-fitting.both ends i guess.
Old 01-12-2003, 07:18 PM   #1422
popsracer's Avatar
Default Pro3 wobbles
lee82gx;
Try some shock O-rings between the ball cup and stud to take up the slop. Works really good in the steering and on the shock balls. The soft blue or clear ones work the best.
popsracer is offline   Reply With Quote
Old 01-12-2003, 07:38 PM   #1423
lee82gx's Avatar
great idea.will try at once
Old 01-12-2003, 10:57 PM   #1424
STARSCREAM's Avatar
havent checked in with you guys in a wile....
so as always.......HPI SUCKS!!!!!!!
lap ya later, barnos....get a real car......
STARSCREAM is offline   Reply With Quote
Old 01-12-2003, 11:10 PM   #1425
lee82gx's Avatar
come over here and i'll show u what HPI can do.
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
