Old 12-13-2002, 07:56 AM   #1306
lem2's Avatar
Default Upper Deck
Life was a lot easier after I switched from HB Upper Deck to
Team PRP!!!! Just stick your bats in regardless if its a stick pack or side by side.
The set up of the car might also change everytime you remove the upper deck.
M not being paid by this, its just that it works! Regardles if it looks ugly or not---it works!!!
Trying my locked diff tom!!!
PurplePro3- I'll be your wing man tomorrow!!!!!
Season's Greetings to all!!!
lem2 is offline   Reply With Quote
Old 12-13-2002, 06:53 PM   #1307
lee82gx's Avatar
Yup yup.that's why i got a Jet Upper deck.USD17 only.looks ugly as hell but battery removal is unaffected.
lee82gx is offline   Reply With Quote
Old 12-13-2002, 07:48 PM   #1308
racer's Avatar
Default TC3 / Pro 3 steering rack???
would it be possible to put a TC3 steering rack on a Pro 3???
if so, anyone know if pictures are availiable?
Thanks in advance!
racer is offline   Reply With Quote
Old 12-13-2002, 07:48 PM   #1309
popsracer's Avatar
Default Ugly is UGLY
I don't care how good she is, Ugly is Ugly and you wont find one on my car. I'll wait to buy a smaller ESC, then install my Beautiful HPI upper deck.
Instead of Beer and Pretzels, I'd rather Wine and Dine.
popsracer is offline   Reply With Quote
Old 12-13-2002, 07:53 PM   #1310
popsracer's Avatar
Default TC3 rack on a PRO-3
Racer;
Why don't YOU show US how to do it. Some pictures too please.
Old 12-13-2002, 07:57 PM   #1311
racer's Avatar
not sure when i will get around to do it. but will give it a try. will post pics if successful
Old 12-13-2002, 08:02 PM   #1312
popsracer's Avatar
Default Just playing around
Racer;
I was just having some fun with you. I really don't think there is anything to be gained with the TC3 Steering Modification. Mine works excellent with a high speed steering servo (Hitec 5925).
Old 12-13-2002, 08:13 PM   #1313
racer's Avatar
that' cool, no problem with that. just that i visited Kai's webpage and have seen the TC3 type steering most of their cars.
anyways, like tinkering with my car. so will give it a try.
Old 12-16-2002, 06:20 AM   #1314
sosidge's Avatar
oops down on the second page again
Old 12-16-2002, 06:58 AM   #1315
lee82gx's Avatar
sosidge u really love ur pro3 huh?cheers
actually now im more sure of my direction in rc.
so i want to race at club9stick) level.Here's my equipment(most are humble)
Futaba 2phka , s30003 , LRP sprinter speedo , thinking of getting a tamiya silver can , unmatched 2000+2400's.
car has front one way , adjustble shocks , centre one way , heat sink and upperdeck.we mostly run on smooth asphalt.
so , are my equipments enuff?to at least finish respectable(with practice of cos).
i know i'll need some spring sets but im not really sure what colours are right.also what HPI/tamiya tyres should i use?
Lastly:whats the difference(except smoothness) between my speeo and a $100 one?
Old 12-16-2002, 09:54 AM   #1316
popsracer's Avatar
Default What's your History
Lee82gx;
What is your experience actually RACING R/C Cars. I'm asking because you may want to start off with the standard Front Diff and countershaft pullies instead of the One-Ways. The Car is Very easy to Drive with the stock set-up and could be a handful with the one-ways installed.
Here's my set-up for medium bite asphalt tracks:
Front;
6 deg. Caster Blocks, 0 deg kick-up, 5mm ride height, 0 deg toe, HPI #6849 (pink) springs, 45wt shock oil, 2 mm droop adjusted with spacers and shock length. Shocks and Camber links in the stock kit positions.
Rear;
2 deg. Toe-in block (2-2-9) mounted normal, 5mm ride height, HPI #6847 (blue) springs, 40wt shock oil, 3mm droop, Shocks and Camber links in kit positions.
This has worked really well at the club level racing. I recently installed the front one-way diff to gain more on-power steering and soon as I can RE-organize my electronics. I will install the HPI upper deck. The car handles very nice but won't hold as tight a line as the other cars. I think that the upper deck will solve this. Also I am comparing to the EXPERT Stock drivers at the track.
Old 12-16-2002, 10:04 AM   #1317
popsracer's Avatar
Default Missed the tire question
Lee82gx;
Your pretty safe with just about any tire. Electric cars put way less strain on the grip of the tire, so you can run just about any decent RACE compound.
I don't know anything about the Tamiya tires. As for HPI, I would run any of the "R" series tires matched to the average track temperature. Use HPI 24mm "RED" or "GREEN" inserts as a starting point.
If they are availible in your country, Sorex and Yokomo tires will provide a wider range of temperatures that they work in compared to the HPI tires.
Old 12-16-2002, 12:56 PM   #1318
J_Longbrake's Avatar
Trader Rating: 20 (100%+)
Does anyone happen to know the website for the company that paints Hara's bodies? Thanks
J_Longbrake is offline   Reply With Quote
Old 12-16-2002, 01:36 PM   #1319
Send a message via AIM to kenix Send a message via Yahoo to kenix
Brain Speed Graphix
http://www002.upp.so-net.ne.jp/bsg/
kenix is offline   Reply With Quote
Old 12-16-2002, 02:12 PM   #1320
Sweeet, Thanks
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
