Old 12-02-2002, 11:52 PM   #1261
purplepro3's Avatar
Default Spec S
http://www.hpiracing.co.jp/contents/kits/pro3/title.jpg
purplepro3 is offline   Reply With Quote
Old 12-02-2002, 11:53 PM   #1262
purplepro3's Avatar
Originally posted by purplepro3
depends on what pro3 version you have. i would recommend the following:
HB upper deck
pro-linear springs (depending on your track)
heatsink motor mount
graphite arms (use the rear hub carrier that comes with this)
spur gear and pinion to properly gear your 27T motor
If you have the Spec S, I'd recommend these hop ups.
Old 12-03-2002, 12:06 AM   #1263
lee82gx's Avatar
mine is spec S
so what should i get huh?I have spur hub , motor and trunbuckles on order.
lee82gx is offline   Reply With Quote
Old 12-03-2002, 12:09 AM   #1264
purplepro3's Avatar
Default Get these
HB upper deck
turnbuckles & ball cups.
Old 12-03-2002, 05:06 AM   #1265
sosidge's Avatar
Default Re: NO NO
Originally posted by lee82gx
Now Im confused.spec V is lower spec or higher spec.??????
Mine is the lower spec one ,no turnbuckles and god knows less what else.
SO, what do u guys suggest now?I have ordered shock nuts and a 14T motor(supportable by my ESC) , and also the alu. spur hub.what else is recommended?
No turnbuckles = Spec S.
The Spec S's I've seen have a label on the box, which makes it quite clear what model it is.
Your first upgrade should be adjustable upper arms - I don't know if HPI make an all-in-one set - you'll have to hunt around the option parts lists on their website.
If the car has dogbone driveshafts, you should also upgrade the front ones to CVD's - shiny, not aluminium.
Old 12-03-2002, 10:25 AM   #1266
popsracer's Avatar
Lee82gx:
The Rod ends for the adjustable links may have come with your kit on one of the plastic parts trees in your kit already. They look like the bottom end of the shocks only larger. Then all you need is the turn buckles. Might as well get the Ti ones if your kit came with plastic links.
popsracer is offline   Reply With Quote
Old 12-03-2002, 02:18 PM   #1267
popsracer's Avatar
Default Better picture
Everyone;
OK, HERE is a better picture of my Pro-3.
HPI Pro-3: paid $119 usd New
Hop-ups: Aluminum Motor plate, Alum. Countershaft mount, Alum. 2-piece Spur Gear Hub, Front swaybar set and the full set of 27mm Springs for tuning.
Forgot; I just added the Front One-way Diff.
Old 12-03-2002, 03:47 PM   #1268
purplepro3's Avatar
popsracer: ever thought of an upper deck? i could stil remember my pro3 in that form and it was quite lazy on the turns.
Old 12-03-2002, 05:25 PM   #1269
lee82gx's Avatar
Are all the purple aluminium parts good?actually i've been looking at some jet-racing parts and some r quite cheap(price).
can different brands be mixed around some?
BTW nice car dude
Old 12-03-2002, 05:29 PM   #1270
rc-zombies's Avatar
BTW nice car dude
Yes..different brands can be mixed around... you don't have to stay with one specifice brand.
On both my Pro3's... I have Jet, Square, Tobee, Cross, HB and HPI all mixed in. you will not be able to tell the difference who makes what....
see my cars at:
http://groups.msn.com/RCZOMBIES/pictures
Old 12-03-2002, 06:25 PM   #1271
popsracer's Avatar
Default Pro-3 Upper Deck
Purplepro3;
I HAVE the HPI upper deck, but my ESC is a Tekin G-9 and there isn't enough room to remove the batteries without lifting the upper deck away. So I took it off the car without ever racing it.
I don't want to risk tweeking the chassis at the Track when there just isn't enough time between heats to correct it. If I buy another speed control, then I can move the Electronics further back on the chassis to change the batteries out on that side. Until then, the car works pretty well without it and I just spent $800 on a Robi motor Dyno.
Old 12-03-2002, 06:51 PM   #1272
pops try the prp chassie and upper deck there is enough room for tekin. and the batts come up through the top, really easy to get the batts out.
teamAE is offline   Reply With Quote
Old 12-03-2002, 09:38 PM   #1273
lee82gx's Avatar
zombie ,
i think i want to make mine just like urs.i have a long way to go though....
kudos.
Old 12-03-2002, 09:54 PM   #1274
popsracer's Avatar
Default Pro-3 upperdeck
teamAE;
I REALLY don't want to spend MORE money on something that I already have (an upper deck). I will check it out just the same. The Tekin is over 3 years old (works fine), but maybe it's time to replace it.
I don't know, will have to think about this. I'm going to run the Car some more just the way it is and make a decision later.
Thanks, will check out the PRP deck (Penguin Racing Products).
Old 12-03-2002, 11:19 PM   #1275
purplepro3's Avatar
popsracer: i think PRP is different from Penguin
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
