Old 11-05-2002, 12:34 PM   #1141
newracer's Avatar
R/C Tech Charter Subscriber
well the HPI forum is gone...
taken from HPI's site
November 5, 2002.
We are in the process of changing to a new support system. Our goal is to help answer questions about HPI cars in an organized and easy to use format. The new system will not be an unlimited forum like we had in the past, it will be an interactive FAQ system. For those times when you want to chat with your buddies, we are hoping to have a live chat room to take care of those needs. If you are having forum withdrawals, see our LINKS section for a list of alternative forums that are just like our old forum.
We are on our way to Japan for the HPI Challenge World Finals, so the launch of the new support system will be delayed until after we return next week. If you have a question about an HPI product, please give our Customer Service department a call.
Thanks for your patience,
HPI Staff
newracer is offline   Reply With Quote
Old 11-05-2002, 06:52 PM   #1142
purplepro3's Avatar
Default 1way cups
Thad: I have not had a problem with the current cups but i noticed that the cvd bone is barely inside the cup. I am comparing this with my old pro2 where the bone settles halfway through the cup. Also, i noticed that the HB/Ova Pro3 diff have corrected this issue by making the cup longer, hence the bone is effectively more recessed inside the cup.
purplepro3 is offline   Reply With Quote
Old 11-06-2002, 09:45 AM   #1143
popsracer's Avatar
Default Pro3 questions
Am I to understand that there is now a new style of oneway diff for the front of the Pro3?
Which one is better?
Have any of you guys found a clip-on motor heatsink that will fit the stock Pro3 chassis. I already have the aluminum motor mount but am looking for a little more protection when running taller gearing.
Thanks,
popsracer is offline   Reply With Quote
Old 11-06-2002, 09:55 AM   #1144
lem2's Avatar
Default Re: Pro3 questions
Thanks,
Hi!! There is no way you can place a heat sink on the motor!
What i did: made the hole for the motor on the underside of the chassis bigger, placed an alumiun rear brace (looks more airy)and aded alum motor mount to add a little heat dessipation!
The alum motor mount from Jet is better in removig heat since its a 3 piece unit.
Lem
lem2 is offline   Reply With Quote
Old 11-06-2002, 10:04 AM   #1145
popsracer's Avatar
Default Pro3 Heatsinks
Lem2;
I really don't want to cut any of the chassis away. I already have the HPI aluminum motor mount and counter shaft mount.
I do pretty good with the car in sportman stock where ever I race it (usually top 3). Just looking for that slight edge over the competition.
SOMEWHERE I read that somebody got a small heatsink that fit, but I didn't write the information down. Did the Aluminum rear brace help the car in any way or is it just eye candy.
Thanks,
Old 11-06-2002, 10:16 AM   #1146
popsracer's Avatar
Default Another question
What motor are any of you racing in stock class? AND what final drive ratio are you running with that motor.
I am running a P2K2 with a 6.99 final drive. (spur~pinion x 2.25)
Thanks,
Old 11-06-2002, 10:28 AM   #1147
lem2's Avatar
Default Hi
I only race stock class and i am still a novice driver.
I also use p2k2 pro and use a 78spur (48p) and a 26Tpinion
still depends on the track though, i sometimes go as high as 27t
pinion or go down to 24.
I tried placing a trinity heat sink on the Pro 3, i can squeeze it in but I have to cut some portion of the top brace, which caused additional flex, wanted to do it with the aluminum brace but, i might be just throwing money away!!
I use aluminum upper bulkhead support so i will do away with the plastic dif covers, the air seems to flow freely when i started to use them, It just like hara's car.
Lem
here's hara's car: http://isweb24.infoseek.co.jp/area/k...pro3/index.htm
Old 11-06-2002, 10:57 AM   #1148
popsracer's Avatar
Default Hara's car
I have met Hara twice and Unimo once. Very nice and willing to share any information with you. I didn't have a Pro3 at the time though.
I really like the diffs on Hara's car. Probally not avalible in the US, right. Looks like he's running a raised roll center in the front. What do you think?
Old 11-06-2002, 11:08 AM   #1149
rc-zombies's Avatar
Default Re: Hara's car
I met both of them too.. very nice and helpfull racers. They help me tune my Pro3. Most of the HB stuff Hara uses is available in the US. contact Ricky's Rc Car. they most of everything except for the Delrin Diff. and Tower Hobbies has HB parts as well.
Yes Hara is using the new 1mm up suspension arm mounts in the front. I just got mine a few weeks ago..also let you adjust kick-up angle. Also got the HB 2.5deg rear mounts as well.
Old 11-06-2002, 11:12 AM   #1150
lem2's Avatar
Default Popsracer
Hi!!! Yep parts in Hara's car are hard to find!!!
But i have them!!!! Got them at www.rainbowten.co.jp or at shopping.rcmodel.hk they are fast and relatively cheap!!!
Hope that helps!!!
the square arm mounts and kick up is cheaper than HB. but they are made by the same company (hehehehehehe)
Old 11-06-2002, 11:18 AM   #1151
rc-zombies's Avatar
They are only a few dollar difference....at least with the HB parts you get tuning instructions..on the Square all you get is the part in a bag...and square won't be selling the new arm mounts..1mm and 2mm up front arm mounts,
2.5, 3.0, and 3.5 deg rear arm mounts.
Old 11-06-2002, 11:25 AM   #1152
lem2's Avatar
Default rc-zombies
Hi!! what will be the benefit of the new arms mounts?
sorry for my ignoramous question--thanks
Old 11-06-2002, 11:32 AM   #1153
rc-zombies's Avatar
The new arm mounts let you adjust roll center and kick-up angles.
Hara is currently racing with the 1mm higher mounts in front with 0 deg. angle.
and using the 2.5 rear toe-in blocks 0.5deg. angle...
This is what he used in the 2002 JMRCA.
Old 11-06-2002, 05:27 PM   #1154
rc-zombies's Avatar
A non-HPI sponsored forum has been set-up
for HPI users. Hope everyone here will join it...
http://forums.rcinfo.co.uk/
Old 11-07-2002, 07:04 AM   #1155
purplepro3's Avatar
Originally posted by Thad Garner
purplepro3,
It will have a different cup to accept the smaller one-way bearing.
-What problem are you guys having with the current one-way cup?
i guess my question is answered. look at how the cvd bone fits in this photo. it is deeper in the cup
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
