Old 10-30-2002, 12:32 PM   #1126
rc-zombies's Avatar
Originally posted by Ko Racer
your better off staying here on this forum
its one of the fasest growing forums online.
and i say if hpi usa changed europe is next
rc-zombie you can be the rc tech hpi pro
I'll be here..not going anywhere...
Old 10-30-2002, 01:31 PM   #1127
newracer's Avatar
R/C Tech Charter Subscriber
Originally posted by Thad Garner
The forum is going to be changed to some sort of QA format?
It should be more helpful.
that sucks!!!
I guess I won't be visiting the HPI site very much anymore.
newracer is offline   Reply With Quote
Old 10-31-2002, 03:56 AM   #1128
Smile
Whoa, a reply from the guru himself Thanks Thad, that sure simplify things for me.Couple of things Thad if you don't mind 1) if i'm using the stock shock towers which hole should i use and 2)should i run this setup full time 4WD, centre one way or just front one way(By the way i have the centre slipper) and most importantly 3) do i need to use the sway bar? Front, back or both? and which hardness to use. Will follow the setup to a T and hope it improves my standing.
Cheers and thank you once again Thad
Dragoonz09 is offline   Reply With Quote
Old 10-31-2002, 08:03 AM   #1129
purplepro3's Avatar
Default Plate Chassis
Thad et. al.: I have the Kai now which is about 3mm (not too sure) and in conjunction with the HB 2.4mm upper deck and HPI aluminum rear brace, flex is totally removed. Now I am thinking of getting the HB (2.2mm) to introduce a bit of flex.
What do you think Thad???
purplepro3 is offline   Reply With Quote
Old 10-31-2002, 08:10 AM   #1130
lem2's Avatar
Default PP3
you still need flex on your Pro3?
shift to PRP uper deck!!!! hehehehehehe
Sir, will you race on Sunday for the series?
Will just get the red springs there!!!
lem2 is offline   Reply With Quote
Old 10-31-2002, 09:04 AM   #1131
Thad Garner's Avatar
Dragoonz09,
1. Rear- center hole(#2) front- outer most hole (#1) both F/R arms I run the bottom of the shock in the A hole (outer) I rarely change from this setting but for lower bite conditions I usually move the top of the front shock in one hole(#2) This adds more chassis role and weight transfer.
2. I always run “double” one-ways. Only once did I run my car full time 4wd. That was because the track was super dusty and had no grip.
3. Yes, it especially important to run sway bars with a stiffer chassis. I use black bars F/R. If you need more steering take off the front if you need less steering take off the rear.
purplepro3,
If your track has a ton of traction I would stick with your current chassis configuration. But if you’re racing on a loose parking lot track I would give the HB chassis a whirl.
If you want to try just a minor adjustment in flex you could always loosely mount the upper deck with o-rings and washers under the screws… I would probably try this first
Thad Garner is offline   Reply With Quote
Old 10-31-2002, 07:57 PM   #1132
popsracer's Avatar
Default Hey Thad
Hey Thad,
Is HPI going to have the message board back up or are they going to abandon running a board. Alot of us racers have really enjoyed the HPI board.
popsracer is offline   Reply With Quote
Old 10-31-2002, 08:22 PM   #1133
purplepro3's Avatar
Thad: thanks for the tips. I remember that o-ring trick from my old pro2 I might try using the stock battery brace first to introduce a bit of flex, i am currently using the Square aluminum battery brace.
Lem2: I'll race this Sunday...but i am still undecided which class...mod or stock???
Old 11-01-2002, 03:52 AM   #1134
Talking Cheers Thad
Thanks Thad, That's a good one, A hole Got the setup down to the wire, if Jean Marc's Spring choices( progressive yellow front and rear) cannot suit my carpet gtrack condition, what would be your recommendation of springs with the black swaybar front and rear? Thanks once again.
Old 11-01-2002, 06:54 AM   #1135
lem2's Avatar
Default PP3
see you on sundaythen, please bring the springs!!!!
thanks!!!
Old 11-03-2002, 02:15 AM   #1136
Default Hey Thad
Hi Thad,
Just got my set of PRO2 anti-sway bars but dude there's no black bar. Only red,green and purple. Red being the softest and purple the hardest. I'm following Jean Marc's carpet setup so i would like to know which of these bars would be appropriate for the front and rear. Thanx a billion Thad
Old 11-04-2002, 07:30 PM   #1137
purplepro3's Avatar
Default New Front 1way 72436
Will the new Pro3 front 1way (HPI #72436) have redesigned cup joints to have to cvd bone fit more securely???
Old 11-04-2002, 09:43 PM   #1138
rc-zombies's Avatar
most likely the oneway outdrive cups will be the same as the original version. who knows..I could be wrong..
Old 11-04-2002, 10:46 PM   #1139
purplepro3's Avatar
i hope they change it. accdg. to hpi japan, they used a smaller bearing so the cup joint should be different.
Old 11-05-2002, 08:12 AM   #1140
Dragoonz09,
Start with the reds. If you need more steering go stiffer in the rear.
purplepro3,
It will have a different cup to accept the smaller one-way bearing.
-What problem are you guys having with the current one-way cup?
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
