Old 07-26-2002, 12:22 PM   #931
Send a message via AIM to PRoYokOmoWaCuR
I have the Team Prp chassis and upperdeck on mine and it's great! i can remove stickpacks easily. i was going to get the hb upperdeck but after reading all the posts and messages made me stick to my prp upperdeck. the chassis is great to!
PRoYokOmoWaCuR is offline   Reply With Quote
Old 07-26-2002, 03:03 PM   #932
onaMISSION's Avatar
anyone have a good setup for high traction permnet indoor track? Its socal raceway if anyone races there.
Any setup for high traction would be nice
Thanks,
dan
onaMISSION is offline   Reply With Quote
Old 07-26-2002, 03:06 PM   #933
onaMISSION's Avatar
oh its for stock, so gearing help would be nice(p2k or a p2k2)
Old 07-26-2002, 03:15 PM   #934
rc-zombies's Avatar
High traction setup... here's mine and having good luck with it.
40wt oil all around
firm bladders
Prolinear #6852 grey or #6751 orange on all 4 shocks.
inner hole on shocks towers front and rear.
3 deg C-blocks. w/3mm spacer
Camber: 1deg. front, 2deg .rear.
Camber link: front stock. Rear: inner lower hole on tower and middle hole on hub.
Swaybars: Front-black, Rear: none.
Tires: Sorex 32R or 28R w/firm inserts type A
I'm running the HB chassis and upperdeck.
P2k2 pro w/108/35 gearing. you may have to gear up or down depending on track layout. I'm going to try the Fantom MVP this weekend. feels like the motor has lots of torque and accelleration.
Good luck... and win some races.
Old 07-26-2002, 03:31 PM   #935
Send a message via AIM to kenix Send a message via Yahoo to kenix
Hello rc-zombie,
Using your setup. my track is small and has lots of turns.
What would you recommend going up a gear or down from your gear ratio of 108/35? (running a p2k 2 pro)
BTW: I haven't even put any electronics yet on the Pro3.
So I guess I'm not selling it yet*
Best Regards,
Kenix
*situation subject to change without notice
kenix is offline   Reply With Quote
Old 07-26-2002, 03:59 PM   #936
rc-zombies's Avatar
Play around with a short wheelbase. this should help in getting around the turns quicker. Maybe start with a 34 pinion if you have a 108 spur.
If you plan to sell it someday and want to keep the bottom of your chassis scratch free put on some AE protective sheeting. but if you plan to seriously race with it...leave it off.
Old 07-27-2002, 09:46 AM   #937
lem2's Avatar
Default turning??
get the 3 degree C-hub!!!!
lem2 is offline   Reply With Quote
Old 08-01-2002, 07:10 PM   #938
purplepro3's Avatar
hi guys!!! how do i get more rear grip by only changing rear shock angle and/or rear camber link position? thanks.
purplepro3 is offline   Reply With Quote
Old 08-01-2002, 10:18 PM   #939
shrekair's Avatar
Trader Rating: 9 (91%+)
softer spring, tilt the shocks inwards. depends on where in the corner u need the grip, and how u want the car to respond
shrekair is offline   Reply With Quote
Old 08-02-2002, 06:37 AM   #940
purplepro3's Avatar
i need grip on exit because the rear loses traction when i hit full throttle. i will level the ride height soon...right now, the rear is 1mm higher. any other suggestions?
Old 08-02-2002, 07:38 AM   #941
sosidge's Avatar
Try leaning the shock in at the top, this makes the car feel a bit more "planted".
Also try running with the camber link in the upper hub carrier hole (i.e. more angled) - this also makes the car feel more "planted" and consistent.
Old 08-02-2002, 08:22 AM   #942
lem2's Avatar
Default purplepro3
that has been my problem-- since we almost have the same car.
I corrected mine by making the rear shock tower stand, it the rear reacts more quickly, than by leaning it inwards.
I use orange at the rear and 40wt. and yes it is 1 to 2 mm higher than the front bcz, its a bit soft (malambot).
I run at pearl and they noticed that my car is more planted than theirs.
Hope it works for you as it did for me
Old 08-02-2002, 08:31 AM   #943
shrekair's Avatar
if its on exit, stiffen the rear spring, that will allow you to pile onto the throttle and the spring will be able to take the load. it will turn a little harder going in aswell, you could then try adding a little castor to balance it out. level your ride height. u could also lengethen the wheel base in the rear.
Old 08-02-2002, 08:46 AM   #944
purplepro3's Avatar
thanks guys, at least i know that i am in the right train of thought. i remember in the pro2, raising the roll center reduces body roll hence they use softer springs to get grip. putting the outer camber link on the upper hole of the hub carrier does the opposite, lowers roll center and increases body roll. right? i'll try laying down the shocks by moving the upper hole inwards.
my set-up is:
Front: 40W, #4 piston, 6852 (grey) springs, 0 toe, -1.5 deg camber, 4 deg C-hub, 2mm spacer on outer camber link, stock inner camber link (this is what gives the car aggressive turn in), 5mm ride height
Rear: 40W, #3 piston, 6850 (yellow) springs, -2 deg toe, -1 deg camber, stock camber link position, stock shock positions, 6mm ride height
lem2: i find the 6841 (orange) spring too soft. my springs start at 6844 (red) - 6849 (pink), 6850 (yellow) and 6852 (grey). i have the 6851 (blue) but mysteriously broke one. i am trying to set-up the car on the newer and harder spring sets for agility.
Old 08-02-2002, 08:54 AM   #945
shrekair's Avatar
it shouldnt matter which car, i do that for any of my onroad cars.
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
