pro3
#767
RCCadet - was that an ironic post, or do you not bother to read threads before answering?
#769
can i use this
http://www2.towerhobbies.com/cgi-bin...1&I=LXWB72&P=7
to replace the plastic pulley behind the spur gear adapter? if not, what brand makes an aluminum pulley for that application? thanks for any info
#770
No you can't, the pre3 needs 16 teeth, which HPI don't make.
I believe some of the far east manufacturers make such a part.
#772
Marvi
Hi!!! I have one like that but it has a connection for the spur gear!
I got one made by Cross Racing, I have a spare HPI aluminum gear and spur gear adaptor.
Marvi, wer u from??
Lem
Manila Philippines
09178384618
Marvi, wer u from??
Lem
Manila Philippines
09178384618
Originally posted by marvi
can i use this
can i use this
#773
RC cadet - if you run it you'll undergear the front with respect to the rear, which is something no-one would sensibly do, creating oversteer and an innefficient car in a straight line.
If looks are more important than performance to you, get the wrong-sized pulley.
#775
thanks for the replies
lem2: im also from manila. ill contact your cell re the aluminum parts. thanks
#776
#777
Nice duck
#778
Regional Moderator
Diva
very nice pro 3 i really like the parts from square
and jet that you have on it. it looks alot like mine but i did the purple.
#779
Yahooooooooooo!!!!!!
My PRP upper deck finally arrived!!!
The craftmanship is superb!!! And comparing it to the HB 2.4 upper deck that I had, the Kai chassis that I am using now is stiffer PERIOD!!!
It was stiff that I removed the aluminum front and rear bulkhead!!
and the chassis remained stiff no torsional flex right to left front to rear!!!!
Battery placement (stick pack) was easy!!! (will invest next on side by side packs!!!
and the best part was spacers, screws (black n purple) were included) and I could place torque rods!!!!! )like the ones onhe TAO4-r/pro.
Can't wait to try it out!!!!!
now. . . . . . if only anyone of you could tell me where to buy "driving skill" i will buy it imediatley!!!!!!! hehehehehehehe
Peace to all men!!!!!
#780
Have fun Lem2
