Old 12-28-2001, 01:52 AM   #31
Regional Moderator
mr4-malta's Avatar
ok...i understand....yhe pro3 doesnt have such a good reputation with the racers....it has some flaws.....but if it isnt that good..howcome it is leading our championship (probably is the driver)and the first time i raced it i came 2nd place in mod and the best ive ever done with my yoke (which ive had for over a year) is 4th or 5th (probably 5th)...maybe cause the mr4 wasnt setup...cause it is a good car too..
question to daniz24 or anyone who can help,
have you noticed the play/slop on the bottom king pin....cause i shime all round...the rear is slop free.....but the front has even after i shimed it..i noticed the bottom king pin screw litteraly moving side to side ....is this common with the pro3's ...or is it mine...
mr4-malta is offline   Reply With Quote
Old 12-28-2001, 07:58 AM   #32
mr4 i have noticed the exact same thing with my pro3 and it has not even been run yet i just finished building it a couple days ago.
There a some lateral movement on the bottom kingpin on both sides up front. Ne1 have any ideas how to fix?
Jarrod Langlois is offline   Reply With Quote
Old 12-28-2001, 09:38 AM   #33
Regional Moderator
mr4-malta's Avatar
spaz,i went to the track today...the car was perfect.. also i changed the wheel base length whilst shimming up the rear ...i made the wheel base shorter (by puting shims on the rear of the rear arm ) that made it improve and also the reduction of the slop has helped too.... i ran against a friend of mine..he is a fast tc3 guy at the track....the cars where pretty equal....he tried my pro3 out and he liked it....
the king pin thing...ive tried shiming that up too.....but that didnt work... anyone got idea's?
Old 12-28-2001, 10:33 AM   #34
Mr4 is the king pin thing a big deal do u think.
im ganna try adjusting the wheel base at the track this week. i also noticed some play forward and back in the rear hub carriers after shimming it to the specs in the directions. is that normal.
Old 12-28-2001, 10:42 AM   #35
Regional Moderator
mr4-malta's Avatar
spaz, after shimming mine i have no play at the rear....i calculated i put 1mm in the front and 3-4mm at the rear of shims... and i have no play at all (well just some but thats the arm flex...i dont think you are reffering to that....? )
about the kingpin thing...i think that it isnt that good...should be sorted out...anyone!!? got any idea's?
Old 12-28-2001, 11:01 AM   #36
k thx, i only have a little bit of play so i may just put one small extra shim in. im lookin at the king pin thing i have no i dea what could be done about it yet. i find somthing hopefully.
Old 12-28-2001, 11:19 AM   #37
epoxy the flange pipes in the hub carriers.
Gavin
gavin is offline   Reply With Quote
Old 12-28-2001, 11:44 AM   #38
Regional Moderator
mr4-malta's Avatar
ok, but can you explain further.....
Old 12-28-2001, 11:52 AM   #39
You already know where the play is in the hub carrier(between the flange pipe and hole for it in the hub carrier) Fill that gap with epoxy. Thats all that needs to be done.
Gavin
Old 12-28-2001, 11:59 AM   #40
hey peep's, hows it goin, i got a pro3 too
i know this is a stupid question but whats epoxy?
thanks
da demon
<demon~racer> is offline   Reply With Quote
Old 12-28-2001, 12:46 PM   #41
ya i was kind of thinkin along the lines of epoxy or somthing like it maybe ill try it
Old 12-28-2001, 12:54 PM   #42
Regional Moderator
mr4-malta's Avatar
ok i will probably CA them...nice and easy
another place of slop is the bearing in the front hubs...there is also slop there...geez... this car is full of slop..(bad parts assembly) i hate to say it....
Old 12-28-2001, 01:00 PM   #43
Regional Moderator
mr4-malta's Avatar
to fix the front slop on the bearings.....get a q-tip with more CA (super glue) and rub it around the inside of the hub..let it dry put the bearing back in and you should have a nice tight fit...
Old 12-28-2001, 01:08 PM   #44
thx malta i too noticed the slop in the bearings in the front hub ill try that. there is alot of slop everywhere.
Old 12-28-2001, 01:28 PM   #45
Regional Moderator
mr4-malta's Avatar
Talking
i just did one side with the whole treatment....the difference is huge the side i did is nice and snug just as it is supposed to be....im pleased...all this stuff works...try it!
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
