Old 03-21-2002, 03:39 PM   #361
would you accept a money order?
Jarrod Langlois is offline   Reply With Quote
Old 03-21-2002, 03:42 PM   #362
rc-zombies's Avatar
sure no problem.. email me for mailing address.
Old 03-21-2002, 05:53 PM   #363
MiSFitSLvR's Avatar
Send a message via AIM to MiSFitSLvR
well i read that thing on team orions web site and am still confused. can someone just explain caster in simple terms? i know what the castor block is. i am not worried about front castor because that is easy to adjust. i am just worried about what rear castor is and how to adjust it.
thanks for helping me out guys.
MiSFitSLvR is offline   Reply With Quote
Old 03-21-2002, 06:12 PM   #364
OSherman's Avatar
Well....in the rear of the car there is not a 'castor' setting. But there is something called 'squat', or should i say "anti-squat"....this setting is found in the relative angle of the lower a-arm to that of the ground. The only way that i have found to be able to adjust this on the wonderful PRO3 is through a little custom machining of the rear toe/hinge-pin blocks that were before mentioned in another post.
They call it "anti-squat" because of the up/down loads (squat) that are eliminated. In other words, the next time you run your car and give it full throttle from a stand till, you will notice that the rear end will sag (the sag is what is called squat); the "anit-squat" setting reduces that sag.
Anti-squat also helps the rear suspension to soak up some of the bumps while going down the road. (If you look at the front end of most off-road buggies, you will notice the angle of the front a-arms. They have that extreme angle partly because of the brutal bumps and ruts on the track; to help soak up/lessen the impacts.)
hope this helps...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 03-22-2002, 09:05 AM   #365
MiSFitSLvR's Avatar
hey thanks guys for all of your help...i finally figured it out. i now have 8* of caster. i just ordered 1 full set of spare arms, my upper deck from HB, and some more shock oils. next i need to get tires, and batteries. right now i only got 1 3000 pack and 1 2000 pack. i am going to sell the 3000 and get a few 2400's so i can race. i also ordered a new speedo(gm v4) i will tell you how my car goes when i get it to the track.
later guys
Old 03-22-2002, 09:41 AM   #366
rc zombies my email is all messed up do you aim?
Old 03-23-2002, 06:46 AM   #367
Send a message via ICQ to Tsubasa Sakai
Now you can order Jet new Pro3 products from Control Centre.They are aluminium 2,3,4 degree front C-hub.
http://controlcentre.rctech.net
Tsubasa Sakai is offline   Reply With Quote
Old 03-24-2002, 07:42 AM   #368
rczombies you have mail
Old 03-25-2002, 05:06 PM   #369
STARSCREAM's Avatar
ooooohhhhh!!!!! what a bummer.....
the top Hpi car at the roar carpet nats was hpi's Thad Garner who finished 34th in mod sedan........
sorry, once again I dont loose to any hpi cars.......not even close!
STARSCREAM is offline   Reply With Quote
Old 03-25-2002, 06:23 PM   #370
purplepro3's Avatar
BLAZN420: and you were at what place if i may ask?
purplepro3 is offline   Reply With Quote
Old 03-25-2002, 10:22 PM   #371
Tech Legend
Wild Cherry's Avatar
Rite behind me....
34th????
Thats not all that bad....
Wild Cherry is offline   Reply With Quote
Old 03-26-2002, 11:26 AM   #372
i thought i heard before that there is mod you can do to the rear hinge pin support block on the pro3 to increase antisquat. can anyone help me out? thanks
Old 03-26-2002, 02:16 PM   #373
OSherman's Avatar
To increase anti-squat?...hmmm..not sure, but try to just filp the block upside-down...I tried it just to see if it was possible when i first got my wonderful PRO3, and if i remember right, i think it did just that...
•KO Propo America
•EXOTEK
Old 03-26-2002, 02:18 PM   #374
OSherman's Avatar
BLAZ and Cherry--> so how did we do at the Carpet races?...hope you had fun..
•KO Propo America
•EXOTEK
Old 03-26-2002, 03:38 PM   #375
STARSCREAM's Avatar
carpet nats were insane......everyone was there.....It was like a Cleveland race or a Reedy tc race......
all of us from the Seattle area did real good to, including a national championship in stock sedan......the top 20 in mod sedan were all factory rides except Andrew Cartwright from Seattle finished 13th.....He beat guys like Todd Hodge from Losi and Billy Easton.....Andrews the man!!!!
Chris Tossolini won Mod sedan and Josh Cyrul won 12th mod.....
Seattles own Travis Schreven won stock sedan and Brett Sisley was second also from Seattle......
Hpi didnt do good at all, they need to get some more good american drivers, if they can...
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
