Old 03-20-2002, 04:27 PM   #346
MikeR's Avatar
Trader Rating: 15 (100%+)
Nice- Thanks... printing it out now.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-20-2002, 04:37 PM   #347
MiSFitSLvR's Avatar
Send a message via AIM to MiSFitSLvR
isnt 8 degrees a lot of rear castor? wouldnt that slow you down a lot? does anybody have or know where i nac get a good setup for the track in perris CA? i know you raced there mike, so what setup did you use?
lmk thanks
Kurt
MiSFitSLvR is offline   Reply With Quote
Old 03-20-2002, 05:00 PM   #348
MikeR's Avatar
W'sup- K
Think they were reffering to front 8d caster.
This is what I ran for that temprature
Base set-up for my car....
Sorex 36r echo red insert (100f track temp)
1.5camber all corners
8 front caster
45wt oil #2 pistons all corners
serpent orange front spring/ back spring ? (pulled from my parts box- slightly softer than front) Had a med (not soft not hard) feel that felt equal front to back (sorry if vague)
4.5mm ride hieght
no one-way
no top plate
High roll center in back
High roll center in front
Lower holes for outside pins
1-2-9 block in rear- 0 rear toe hubs
The track was a little dusty in the first few rounds but came alive in the main.
I usually run this same set-up at all tracks and just change tires for the weather or change the rear shock angle or add oneways- works really well for me.
Old 03-20-2002, 08:51 PM   #349
DJ_GenR8's Avatar
Graphite parts....finally!
DJ_GenR8 is offline   Reply With Quote
Old 03-20-2002, 09:25 PM   #350
MiSFitSLvR's Avatar
i know this is kinda a dumb question...but what is castor? i thought it was the same as toe in in the rear. lmk
Old 03-20-2002, 10:09 PM   #351
MikeR's Avatar
Kurt- Go here http://www.team-orion.ch/rccarhandling/index.asp
will tell ya the birds and the bees of suspension tuning
Old 03-21-2002, 08:24 AM   #352
MiSFitSLvR's Avatar
so how do you adjust casator???
Old 03-21-2002, 09:16 AM   #353
nova racer's Avatar
you have to replace the C-hubs on the pro3 they are marked now if you already have the 2-deg front kick up in then you add that to the other number that is on the caster block to get the correct caster deg. like if you have 8 deg front caster blocks and 2 deg kick up then you have a total of 10deg caster.
nova racer is offline   Reply With Quote
Old 03-21-2002, 11:06 AM   #354
what after market chassis would you guys recommend for the pro3 im trying stiffen it up as much as i can for carpet racing i have just been running the carbon composite chassis that hpi makes but i want somthing a little stiffer. just bought the carbon fiber shock towers, top deck ,aluminum bulkheads and layshaft mount. anything else i should get?
Jarrod Langlois is offline   Reply With Quote
Old 03-21-2002, 11:34 AM   #355
rc-zombies's Avatar
Woven narrow graphite chassis. avialable from RcModel in HK.
http://shopping.rcmodel.com.hk/eshopping/default.htm
also get the new 3 or 4 degree C-blocks. you will be able to exit corners alot faster. I have 1 set of 4deg. C-blocks to sell if you're interested. let me know by friday.. goes into auction on monday.
Old 03-21-2002, 11:42 AM   #356
k thx, maybe ill get those c hubs, how much. also what are the new hubs released, just 3 and 4 degree?
Old 03-21-2002, 11:57 AM   #357
that chassis is nice im thinkin i might get in a couple weeks. who makes it ?
Old 03-21-2002, 12:29 PM   #358
rc-zombies's Avatar
It was released about a month or 2 ago. Just 3 and 4 degrees are released. Most of the HS in HK are out of stock on the new C-hubs. They expect more in by mid-end of April. Asking $10.00 shipped.
Don't know who makes the chassis. Looks like a great copy of the Kai chassis that had limited released last year.
Old 03-21-2002, 01:22 PM   #359
alright 10 bucks shipped. do you have email or anything. i think i might either get the penguin chassis or that narrow carbon graphite one plus some other hop ups from rcmodel do you know what the average shipping is from there or is it calculated individually on weight. thx
Old 03-21-2002, 01:50 PM   #360
rc-zombies's Avatar
email me at [email protected]
you can use that address for PayPal also.
It cost around $10.00 for registered airmail from HK just for the chassis. $15.00 EMS priority. 3-4 day delivery air is 7-10days.
Shipping is based on weight.
Personally I think the Narrow chassis is better. The HB narrow chassis is very similar in design but won't be released til May or June.
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
