Old 03-14-2002, 06:02 AM   #271
sosidge's Avatar
Ralf - I used to run carpet, and this was what I was using - without one-way.
Body: Protoform Stratus
Motor p2k on about 29/81 or peak 12x1 on about 21/81
GMV12 speedo
KO 713 FET servo
Integy Sanyo 3000's
Front:
Blue Jaco foams (24mm)
Blue tamiya springs (stiff)
40wt oil
6deg caster blocks
Camber links in upper outboard hole, and upper inner inboard hole
Camber set for even tyre wear, erring on the negative side.
Toe in - about 1 deg.
All other settings as kit
Rear
Blue TRC foams (supposedly a little softer)
Blue tamiya springs
60wt oil
Camber links in upper outboard hole and upper inner inboard hole
Toe in 1deg (stock motor), 2deg (mod motor)
Other info:
Fibre-lyte top-deck fitted
shock bladders fitted
various other little tweaks that don't really do anything
Things worth trying as well are maybe slightly stiffer front oil (I ran 60wt last time I went down there - made the steering response a bit smoother), as well as less caster - try the new 3 or 4deg blocks from Japan, which are also out now in europe.
Old 03-14-2002, 07:42 AM   #272
Thank you Sosidge,
Did you try your set-up with Rubber tires ?
Ralf is offline   Reply With Quote
Old 03-14-2002, 08:40 AM   #273
Regional Moderator
R/C Tech Charter Subscriber
hello sosidge
hey do you have a set up for the new 4 degree c-hubs?
i havent heard any setups for them yet and just got mine the other week and havent tried them out.
thanks for any help!!!!
pro3racing
Ko Racer is offline   Reply With Quote
Old 03-14-2002, 10:45 AM   #274
STARSCREAM's Avatar
Mikey R,
still havent told me where you race so I can spank ya while Im down there next month..... you must be scared or something...
well, you should be.....
STARSCREAM is offline   Reply With Quote
Old 03-14-2002, 07:19 PM   #275
purplepro3's Avatar
HASBEEN420: when you spank, you are obviously coming from behind
purplepro3 is offline   Reply With Quote
Old 03-15-2002, 05:17 AM   #276
sosidge's Avatar
Ralf - sorry, foams only.
Pro3racing - haven't run the new caster blocks - i'm just assuming that cos the 6deg are an improvement on the 8deg, the 3 and 4 degs would probably be better again.
Might put an order in for the 3 or 4 degs today as it happens.
Old 03-15-2002, 06:52 AM   #277
Thank you Sosidge,
I will try different set-up with rubber tires and with the new caster blocks.
Old 03-15-2002, 07:55 AM   #278
Regional Moderator
purplepro3,
hey how did those transponder mounts work out ????
i can send you some other type if those didnt do it
just let me know.
sosidge, thanks for the info the 3 degree are great!
blazn420 , hey if you are ever on the east coast let me know
i take you up on a race.and will show you what a
pro3 can do to you.
Old 03-15-2002, 11:53 AM   #279
could you guys tell me where i can get the 3 degree blocks
Jarrod Langlois is offline   Reply With Quote
Old 03-15-2002, 11:54 AM   #280
Regional Moderator
www.rcmodel.com.hk/
they have them instock most of the time
Old 03-15-2002, 11:57 AM   #281
k thx
Old 03-15-2002, 12:01 PM   #282
do you know if i can run a turnbuckle rod from the battery stap to the rear motor brace with a top deck?
Old 03-15-2002, 12:04 PM   #283
rc-zombies's Avatar
Yes you can. This was one of HPI's early tuning tips. See the HPI pro3 tuning guide for others.
Old 03-15-2002, 12:07 PM   #284
rc-zombies's Avatar
Originally posted by pro3racing
www.rcmodel.com.hk/
All the shops in HK are all out of stock on the 3deg C-blocks. I know 'coz I bought the last few. You might be able to find the 4deg. The new blocks sell out very quickly. You can try to pre-order them.
Old 03-15-2002, 12:31 PM   #285
Regional Moderator
you bought the rest of them
tell me how many blue pro3's are you building
talk to you soon
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
