Old 08-31-2003, 11:43 PM   #1876
Registered User
Aku-Man, too bad im low on cash right now. If anyone has a PRP upper deck for sale, let me know.
Only $20, worth to spend. BTW, I'm using Jet upper deck. It is about $14. I want to try out PRP for stiffness. I might sell my Jet after I get PRP.
Aku-Man is offline   Reply With Quote
Old 08-31-2003, 11:46 PM   #1877
Registered User
Here's Jet upper deck.
Old 08-31-2003, 11:50 PM   #1878
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Hmm..I was wondering where to get Square stuff? I really like the aluminum battery hold down. Any clue where to get it? Thanks
DOMOisCOOL is offline   Reply With Quote
Old 09-01-2003, 12:29 AM   #1879
Send a message via ICQ to Mingfinity
Try to contact CONTROLCENTER in this forum.
They have the JET version that is the same as the SQUARE one
I am wondering if JET does made this part for Square.
Mingfinity is offline   Reply With Quote
Old 09-01-2003, 09:48 AM   #1880
Mingfinity, that'd be great.
STEP 1
Old 09-01-2003, 09:50 AM   #1881
STEP 2
Old 09-01-2003, 09:51 AM   #1882
STEP 3
Old 09-01-2003, 09:52 AM   #1883
STEP 4
Old 09-01-2003, 10:17 AM   #1884
popsracer's Avatar
Default I'm just afraid that the belt might snap.
Guys;
If your fingers are thin (mine are fat), you can get pull the clip easier by hand. For me a pair of Needle Nose is quicker.
All you have to do is lift the pack, slide it left and out through the left side. Slides right through the Belt with no problem.
If you've soldered Wires to your Pack(s), then they will catch on the Belt as you remove it. This is one reason I went to the small Euro connectors (Eagle Brand), Looks cleaner too.
popsracer is offline   Reply With Quote
Old 09-01-2003, 10:41 AM   #1885
Regional Moderator
when i was running the pro3 i had my packs just like mingfinity
has his and they worked out great. there was a guy in hong kong that told me to try it and it was one the best things i did
those where the days
Ko Racer is offline   Reply With Quote
Old 09-01-2003, 07:06 PM   #1886
DOMOisCOOL's Avatar
Thanks Everyone for helping me!!!
Just came back from the track from practicing.
Wow am I impressed. These Pro 3's can take a beating! Only thing that happened was that my rear right CVD popped out.
Since the onroad track practices with both Nitro and Electric, a RC10GT came full throttle down the straightaway and T boned me! Nothing happened except the body got bent in and my ESC went loose.
Old 09-01-2003, 08:02 PM   #1887
Registered User
Default carbon fiber chassis
Anybody try out HPI Woven chassis? How was it compare to HB Hara chassis? The thickness for HPI is 3.3mm and HB is 2.2mm. Which one is better?
Old 09-15-2003, 10:56 AM   #1888
Regional Moderator
mr4-malta's Avatar
hi guys...can someone give me a baisic gearing for a 21t stock on the pro3 using 48pitch gears....i used to race mod over a year ago but after a years break i forgot things like gearings....so can some one do me a fav and suggest a gear ratio...i will be using 3300 cells
thanks
mr4-malta is offline   Reply With Quote
Old 09-15-2003, 11:02 AM   #1889
rc-zombies's Avatar
Default Re: carbon fiber chassis
I've had both chassis... and couldn't tell the difference.. they both handled extremely well... the HB 2.2 chassis will probably do good for outdoor parking lot races... and the thicker HPI 3.3mm chassis for High traction asphalt or carpet tracks.
Old 09-15-2003, 11:17 AM   #1890
popsracer's Avatar
Default How Free is your Drivetrain?
Guys;
I've got my Car handling just about perfect, but can't seen to find the overall speed like the shaft drive Cars. My Motor and Batteries are top notch, so I feel that the drive train is the weak link.
Seems like even with all of the free-up tricks, I can only get a few revolutions of the whole drive train when spinning the spur gear (no motor). I've seen plenty shaft drive Cars spin for several seconds.
I must be missing something, but just can't find the problem.
Anyone have some suggestions to add?
Thanks,
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
