Old 08-31-2003, 02:08 PM   #1861
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Thanks popsracer!
I think I have to rearrange my electronics position. The large cap. on my GT7 takes up a lot of space
DOMOisCOOL is offline   Reply With Quote
Old 08-31-2003, 02:24 PM   #1862
popsracer's Avatar
Default Upper Decks
Guys;
The reason I choose an HPI Upper Deck over any of the others was:
1) Looks. Plainly is the best looking upper deck out there.
2) It's one piece.
3) HPI always supplies everything needed to install. No hunting down screws, spacers, etc.
The Deck was designed to remove the Pack(s) without disassembly.
And I doubt the average racer will notice a 1/4" difference in Electronics placement.
popsracer is offline   Reply With Quote
Old 08-31-2003, 02:42 PM   #1863
It's not worth an argument but if you're using the tub chassis possible electronic placement is affected by a whole lot more than a 1/4" if you want to be able to slide out the batteries with the deck installed. You can alter the weight distribution drastically if you have the full range of the tub available in which to mount the electronics rather than just the back half.
calvin is offline   Reply With Quote
Old 08-31-2003, 02:54 PM   #1864
DOMOisCOOL's Avatar
Do you think it is easier to slide out the batt. if I would buy the CF chassis?
Old 08-31-2003, 03:00 PM   #1865
About the same. The biggest problem with the woven graphite chassis is finding a place to mount all your electronics. The wings seem to be real small when you try to mount everything.
Old 08-31-2003, 03:04 PM   #1866
DOMOisCOOL's Avatar
Hmm..
Well heres my step by step :
Old 08-31-2003, 03:04 PM   #1867
DOMOisCOOL's Avatar
Step 2:
Old 08-31-2003, 03:05 PM   #1868
DOMOisCOOL's Avatar
Last step:
Old 08-31-2003, 03:06 PM   #1869
DOMOisCOOL's Avatar
It is fairly easy now. I'm just afraid that the belt might snap.
Old 08-31-2003, 10:12 PM   #1870
popsracer's Avatar
Default Upper Decks
DOMOisCOOL;
Well I have the HPI graphite upper deck. It is impossible to take the battery out without taking the upper deck out. Anyone else find this annoying?
Not that it really matters, but that does not look like an HPI Upper Deck.
Old 08-31-2003, 10:28 PM   #1871
DOMOisCOOL's Avatar
Well its the HB one. But I think its similar.
Old 08-31-2003, 10:31 PM   #1872
Registered User
If you want stiff upper deck, get team prp and you can remove the battery from top without remove the upper deck.
Aku-Man is offline   Reply With Quote
Old 08-31-2003, 10:36 PM   #1873
Registered User
DOMOisCOOL,
I think that way of removing battry is bad because you stretching the belt.
Old 08-31-2003, 10:37 PM   #1874
Send a message via ICQ to Mingfinity
There IS another easier way to do that.
I will try it to show it to you guys tonite.
you can trim down the battery brace post and remove the upper brace from the steering assembly. You can snap the battery strap pin from the ) side of the upper deck, so that you can do it by your hand instead of using some tools.
Mingfinity is offline   Reply With Quote
Old 08-31-2003, 11:32 PM   #1875
DOMOisCOOL's Avatar
Mingfinity, that'd be great.
Aku-Man, too bad im low on cash right now. If anyone has a PRP upper deck for sale, let me know.
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
