Old 08-17-2003, 05:55 PM   #1846
SuperRooster's Avatar
Send a message via AIM to SuperRooster
Originally posted by charlie_b
SRooster-I rin no onw ways on a loose track. right now, i have the yellow(new) springs all the way around, 40 wt, and 2 deg camber. That's a start.
TigeRyan-116/37
Hey thanks today a ran without the one way. I used wt all around 3deg in the frond 2deg in the back and used black progressive springs in the front and white progressive springs in the back. It actually ran pretty good but i think im going to go a litttle stiffer for shock oil
SuperRooster is offline   Reply With Quote
Old 08-18-2003, 08:38 AM   #1847
lee82gx's Avatar
Hi guys,so how many of u will still be running the Pro3 in view of the Pro4 coming out?
Over here in my area,most seasoned RC'ers are letting of their Hara's and V-specs!
lee82gx is offline   Reply With Quote
Old 08-22-2003, 08:37 AM   #1848
Carbon_Fibre3's Avatar
i've decided to get my pro 3 outa the cupboard, brush the dust off, n c wot its made of. When my pro 4 arrives though.. back into retirement it shal go, and ill keep racing my xray, and use pro 4.
Carbon_Fibre3 is offline   Reply With Quote
Old 08-22-2003, 09:22 AM   #1849
newracer's Avatar
R/C Tech Charter Subscriber
I am going to try and keep myself from buying the Pro 4 but I'll probably get it.
newracer is offline   Reply With Quote
Old 08-30-2003, 02:52 PM   #1850
DOMOisCOOL's Avatar
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Default Anyone else find this annoying?
Well I have the HPI graphite upper deck. It is impossible to take the battery out without taking the upper deck out. Anyone else find this annoying?
DOMOisCOOL is offline   Reply With Quote
Old 08-30-2003, 03:44 PM   #1851
Jimmy Fukuyama's Avatar
Default Re: Anyone else find this annoying?
The secret is to trim down the front battery mount by cutting the around the outside of it and shimming the upperdeck by 1mm. You shouldn't have any problem after that.
Jim
Jimmy Fukuyama is offline   Reply With Quote
Old 08-30-2003, 05:05 PM   #1852
DOMOisCOOL's Avatar
Thanks Jimmy. Do you have a pic of this?
Old 08-31-2003, 06:23 AM   #1853
sparky123's Avatar
Default pinion sizes
any 1 know what size pinions there are for the pro3 as the wheels are spinning when ever i floor it.
sorry if that is a stupid question but i just got given a plain plastic one and i love it.
what do you guys reckon to be the best hop up for the pro 3?
any help is appreciated
sparky123 is offline   Reply With Quote
Old 08-31-2003, 11:32 AM   #1854
popsracer's Avatar
Default Pro-3 & Battery changing
DOMOisCOOL;
I use the Small Euro Plug on my packs in my Pro-3 and the batteries go in and out just fine.
Just remove the holder and the pack will slide out from the front and to the left. Only takes a few seconds longer than without the Upper Deck.
BTW, my Car has been dialed lately.
popsracer is offline   Reply With Quote
Old 08-31-2003, 12:28 PM   #1855
DOMOisCOOL's Avatar
Im using GP 3300 (with deans on them) and they're impossible to get out. The rear aluminum motor block blocks the way.
Old 08-31-2003, 12:45 PM   #1856
popsracer's Avatar
Default DOMOisCOOL;
Let me take a few pics and I'll post them later today.
Old 08-31-2003, 12:58 PM   #1857
DOMOisCOOL's Avatar
Thanks pops
Old 08-31-2003, 01:43 PM   #1858
popsracer's Avatar
Default Pro-3 Pictures
I use a pair of Needle Nose Pliers to remove the clip, slide the Battery Holder out to the left, then just do the same with the Pack.
As long as your Electronics are mounted as far back as they can go, everything should fit fine.
Old 08-31-2003, 01:45 PM   #1859
popsracer's Avatar
Here is the next one:
Old 08-31-2003, 02:05 PM   #1860
If you want to maintain the weight distribution flexibility that is afforded by being able to move the electronics around you can make the top deck easily removable by replacing the screws holding on the deck with threaded studs and using nuts to easily and quickly remove the deck to replace the batteries. With a setup like this I can remove the deck and replace the batteries in less than a minute. There is also a top deck made by a third party vendor that is designed such that the batteries are easily removable.
calvin is offline   Reply With Quote
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
