Old 08-05-2003, 03:49 AM   #1831
lee82gx's Avatar
Of course,the outside wheel(right side when turning left) is the one that holds most of the traction.
forward momentum will push most weight to go against a turn,meaning most weight goes to the right side on a left turn.
sounds like a source of trouble to me,but i tot sway bars dont influence handling that much?
and also,since one side is not fastened,u should have NO antisway for both sides...????
lee82gx is offline   Reply With Quote
Old 08-05-2003, 12:03 PM   #1832
popsracer's Avatar
Default Pro-3 handling problems
Look for something to be different on one side of the Car.
A sticky Bearing, Shock lengths not equal side to side, a bent Hinge Pin, a Tire with a partially unglued sidewall, Chassis Tweak.
Unless you're racing Oval, it is very important for all of the settings to be equal on both sides of the Car. Shock lengths are especially important on a Car without Droop Screws, like the Pro-3.
popsracer is offline   Reply With Quote
Old 08-07-2003, 07:59 PM   #1833
Speed Demon's Avatar
No.. it's not the holder with the ball-cup at the lower arms..
It's the holder at the front bulkhead that's gone..
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 08-07-2003, 08:09 PM   #1834
lee82gx's Avatar
dude i just bought myself a used FTTC3..
let me rebuilt it and get some batteries..then we race!
why dont u remove the whole front sway bar and see how it goes?
Old 08-07-2003, 08:19 PM   #1835
That's good... how much ?
I actually quite bz... I only found out the holder missing when I reach home... so,, up to today I haven't test it yet....
Old 08-07-2003, 08:23 PM   #1836
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Hey Guys,
Getting ready for an HPI Challenge in my parts where I will be running Pro Electric (Mod Motor) - I was planning on a 13x2 D3.5 motor....The track in a asphalt parking lot track fairly open with an 80' straight...Could someone give me a starting point for gearing???
Thanks!
John
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 08-12-2003, 04:41 PM   #1837
Regional Moderator
if there is a andrew that emailed me for transponder holders for the pro 3 please email me again my computer crashed and i have lost your mailing info to send your transponder holders out.
Ko Racer is offline   Reply With Quote
Old 08-12-2003, 06:41 PM   #1838
popsracer's Avatar
Default transponder holders for the pro 3
The Associated TC3 uses a similar lexan transponder holder that will fit and is easier to find.
Mount it to your steering servo, with double stick Foam Tape.
Old 08-13-2003, 06:17 AM   #1839
Regional Moderator
Default Re: transponder holders for the pro 3
Originally posted by popsracer
Ko Racer;
hi pops.... i dont need any i use to make woven graphite trans holders when i ran hpi and there is a guy name andrew that wanted some and i was trying to find him because i have lost his email addy when my computer crashed . i have them ready to mail to him just need to get hold of him to get info .
Old 08-16-2003, 02:46 PM   #1840
SuperRooster's Avatar
Send a message via AIM to SuperRooster
Default need help
ok does anyone have a setup for a loose parking lot track i will be using the woven graphite chassis and upper deck
SuperRooster is offline   Reply With Quote
Old 08-16-2003, 04:42 PM   #1841
TigeRyan's Avatar
Ok, I'll ask again...anyone have a starting gear ratio for a medium sized outdoor track running a 13x2???
Old 08-17-2003, 03:13 AM   #1842
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
SRooster-I rin no onw ways on a loose track. right now, i have the yellow(new) springs all the way around, 40 wt, and 2 deg camber. That's a start.
TigeRyan-116/37
charlie_b is offline   Reply With Quote
Old 08-17-2003, 10:58 AM   #1843
popsracer's Avatar
Default Pro-3 update
Guys;
I recently changed the Droop settings on my Pro-3 to full Droop Front and Back. Really smoothed out the handling of the Car and with no noticable bad side effects.
Now I will be able to go up 1 rate on the springs even. (currently Rear: #6844, RED, Front: #6846, GREEN) and maintain the same level of traction. (Medium bite Asphalt)
Will keep everyone updated.
Old 08-17-2003, 04:57 PM   #1844
Trader Rating: 19 (100%+)
Popsracer -
Does full droop refer to lengthening the shocks as far as possible? I'm not sure of how droop is correctly adjusted on the pro 3. Thanks.
Vmax is offline   Reply With Quote
Old 08-17-2003, 05:09 PM   #1845
popsracer's Avatar
Default Droop on the Pro-3
Vmax;
Before I added the HPI upper deck, the Car worked better with less droop F & R. With less Chassis twist now, the added droop just makes the Car so much easier to drive, smoother and faster in the corners.
My Shocks have the Foams compensators removed, Firm Bladders installed and NO spacers what-so-ever inside the shocks.
Right now the Shock ends are screwed all the down, then adjusted to be equal length with Dial Calipers. (to .0005)
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
