Old 04-03-2003, 12:18 PM   #1726
rc-zombies's Avatar
Ray...
Darn it..I just threw away all my setup sheets after I sold my car...
Your tire choice is good..they should work fine..27's in the am. 33's in the afternoon. You may want to carry some 33's with green inserts if the weather starts to warm up.
Since you're limited to stock kit. and springs..
the stock set-up should work fine...
run 45wt oil front, 40wt rears.
camber:
1deg front
1.5deg rear
6 deg C-blocks.
toe-in:
0 front
2 rear.
gearing:
start with 110/38 and work from there on track layout.
110 is the optimum spur gear for the car.
if the track is really smooth..try 0deg kickup in the rear..that may increase your rear traction.
hope this helps..if I'm forgetting something let me know..
Old 04-03-2003, 12:26 PM   #1727
rayhuang's Avatar
I dont think I got the instruction book. Can you tell me where to put all the links on the tower and and on the knuckles and rear hub? no rush!!!
Also-is that Associated weigt oil or HPI oil?
rc-zombies-thanks!!!
Old 04-03-2003, 12:32 PM   #1728
rc-zombies's Avatar
download instructions at:
http://www.hpiracing.com/instructions/instruct-p3.htm
Shocktower..
front: shocks in inner hole
Rear: shocks in middle hole.
camber links..see manual for stock settings.
Oil..I used Trinity ...I think they are all about the same...
Old 04-24-2003, 09:09 AM   #1729
popsracer's Avatar
Default Keeping the thread active
Guys;
Just wanted to say that my Pro-3 is so dialed now that I haven't made any changes in the last 4 races. The long time Stock racers at our tracks are even starting to get nervous. Just need a little more Motor or Battery, but the handling is perfect.
As a note, I'm am still using the Stock plastic Tub Chassis with the HPI Upper Deck.
popsracer is offline   Reply With Quote
Old 04-24-2003, 09:41 AM   #1730
sosidge's Avatar
Well I'm really pleased with the extra consistency I'm getting from the car with the graphite arms fitted - I used to lay the car on the track and the balance would be different every meeting, and every race, but now it's much more consistent, the only change I've made in the last couple of weeks has been to go a bit stiffer on the back one night to free the car up. Took the rear toe-in hub carriers off though, they were giving me too much rear grip, which made the car confident, but slower on our tight, slippy track. New 3300 cells are working well too, I actually have some punch for the first time in a few months!
Old 04-24-2003, 11:29 AM   #1731
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up .
Wow Haven't see this thread in a while ... Nice to see it pop up now and then
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-27-2003, 07:37 PM   #1732
newracer's Avatar
R/C Tech Charter Subscriber
I had a good outing with my pro3 today. Yoday was the first day of our parking lot season. I qualified 6th in the A and finsihed 2nd. I could have given 1st a run but I got a horrible start and had to move up from almost dead last. By time I got to second 1st was almost a 1/2 a lap ahead. Maybe next weekend.
newracer is offline   Reply With Quote
Old 04-30-2003, 02:12 PM   #1733
Well done Newracer,
Through your set up on the board and were you racing on asphalt. I'm interested to see your setup.
HPI 1 is offline   Reply With Quote
Old 04-30-2003, 02:15 PM   #1734
rc-zombies's Avatar
The 2003 Reedy Race will probably be the last race you'll see the Pro3 race in a major event. R.I.P.
Pro4 is coming soon..
Old 04-30-2003, 09:00 PM   #1735
newracer's Avatar
Hop ups
PRP chassis and upper deck
aluminum motor brace
aluminum battery holder
heatsink motor plate
aluminum spur gear holder
aluminum pully mount
aluminum CVD's
graphite front and rear shock towers
Ti turnbuckles and hingepins
low friction belts
Xpress torque/camber rods
Setup
Front
pink springs/ 40wt oil, stock piston #3?
shock mounts-outer hole on bottom, lower inner on top
4 degree C-hubs
gold swaybar
camber link upper middle
-1 degrees camber
0 toe
lower arm mount- 2 degrees, I think?
ride height 5.5mm
Rear
green springs/40wt oil, stock piston #3?
shock mounts-inner hole on bottom, outer top on top
0 degree hubs
silver swaybar
camber link upper hole on hub, inner middle on tower
-1 degrees camber
1-2-9 lower arm block
ride height 5.5mm
I need to go a little stiffer as my chassis was rubbing a little on the high speed corners
no one ways
38/110 gearing
HPI Mondeo body
Electronics
Hitec DCX rx with 3D radio
Hitec 5925MG servo
Novak TC2, stock profile
XIIP tuned, P2K based motor with Putnam brushes and springs
Promatch 2400's
The track is 50x120, blown off and sprayed with sugar water
Old 05-01-2003, 05:32 AM   #1736
Accord's Avatar
Send a message via AIM to Accord
I have a Pro 3 and am running it on a carpet track. Does anyone have any tips for setting up the Pro 3 for use on a carpet track?
Accord is offline   Reply With Quote
Old 05-01-2003, 06:02 AM   #1737
sosidge's Avatar
Stiff springs, heavy damping, 3 or 4 degree front caster, remember to adjust ride height and shock length as the tyres wear.
Old 05-01-2003, 07:40 PM   #1738
Thanks Newracer!
Old 05-01-2003, 08:12 PM   #1739
Default Pro3 spare parts????
RC-ZOMBIES.... You have PM....
Silent Strike is offline   Reply With Quote
Old 05-02-2003, 10:56 PM   #1740
newracer's Avatar
I just got the Jet Aluminum steering bellcranks. What ballstuds have people used with them?
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
